path: root/include/configs/xilinx-ppc.h
2015-05-28ppc: xilinx-ppc: Move to generic board supportRicardo Ribalda
Generic board support seems to work just fine. Tested on ml507 with bitstream generated on the latest ISE software. Tested-by: Georg Schardt <schardt@team-ctech.de> Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-10-08ml507: Fix Xilinx uartlite driver hangRommel Custodio
The default configuration for ml507 will generate a hang() in the Xilinx uartlite driver. userial_ports[] in drivers/serial/serial_xuartlite.c does not get initialized properly. CONFIG_SERIAL_BASE is unused. XILINX_UARTLITE_BASEADDR is used instead. Signed-off-by: Rommel Custodio <sessyargc+uboot@gmail.com>
2010-12-17xilinx-ppc4xx-generic: Use common u-boot.ldsRicardo Ribalda Delgado
Use common ppc4xx linker script for xilinx ppc440 and ppc405 related boards. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12mtd: MTD related config header changes (mtdparts command)Stefan Roese
By changing the cmd_mtdparts to only use the MTD infrastructure and not the direct interface to the CFI NOR FLASH driver we now need to add the MTD infrastructure to all boards using those mtdparts commands. This patch adds those components: CONFIG_MTD_DEVICE (for all FLASH types) plus CONFIG_FLASH_CFI_MTD (for NOR FLASH) To all board maintainers: Please test this on your platforms and report any problems/issues found. Thanks. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ron Madrid <info@sheldoninst.com> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Martin Krause <martin.krause@tqs.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Ricardo Ribalda <ricardo.ribalda@uam.es>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-10-31ppc4xx: Merge xilinx-ppc440 and xilinx-ppc405 cfgRicardo Ribalda Delgado
Xilinx ppc440 and ppc405 have many similarities. This patch merge the config files of both infrastuctures Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
