path: root/include/configs/xaeniax.h
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various [v-z]* named board config ↵Jon Loeliger
files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2005-08-04Adjust configuration of XENIAX boardWolfgang Denk
(chip select and GPIO required for USB operation)
2005-04-04Patch by Steven Scholz, 4 Apr 2005:wdenk
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2004-11-02Work around for Ethernet problems on Xaeniax boardwdenk
2004-10-19Add passing of the command line and memory size information to theLABEL_2004_10_20_0020wdenk
kernel on xaeniax board.
2004-10-17Code cleanup for GCC-3.3.x compilerswdenk
2004-09-28Patch by Vincent Dubey, 24 Sep 2004:wdenk
Add support for xaeniax board
