2005-04-04 | Patch by Steven Scholz, 4 Apr 2005: | wdenk | |
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT | |||
2005-04-02 | Prepare for SoC rework of ARM code: | wdenk | |
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files) | |||
2005-04-02 | Fix problems with SNTP support; | wdenk | |
enable SNTP support in some boards. | |||
2004-11-02 | Work around for Ethernet problems on Xaeniax board | wdenk | |
2004-10-19 | Add passing of the command line and memory size information to theLABEL_2004_10_20_0020 | wdenk | |
kernel on xaeniax board. | |||
2004-10-17 | Code cleanup for GCC-3.3.x compilers | wdenk | |
2004-09-28 | Patch by Vincent Dubey, 24 Sep 2004: | wdenk | |
Add support for xaeniax board |
