Move this option to Kconfig and tidy up existing uses.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2
means the autoboot with no delay, with no abort check even if
CONFIG_ZERO_BOOTDELAY_CHECK is defined.
To sum up, the autoboot behaves as follows:
[1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y
autoboot with no delay, but you can abort it by key input
[2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n
autoboot with no delay, with no check for abort
[3] CONFIG_BOOTDELAY=-1
disable autoboot
[4] CONFIG_BOOTDELAY=-2
As you notice, [2] and [4] come to the same result, which means we
do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the
cases only by CONFIG_BOOTDELAY, like this:
[2] CONFIG_BOOTDELAY=-1
disable autoboot
[3] CONFIG_BOOTDELAY=-2
This commit converts the logic as follow:
--> CONFIG_BOOTDELAY=-2
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Christian Riesch <christian.riesch@omicronenergy.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
As the old ethernet PHY is not available any more, the x600 board has
been redesigned with the Micrel KSZ9031 PHY. This patch adds support
to autodetect the PHY and configure the Micrel PHY correctly.
This patch moves all appearances of CONFIG_SYS_I2C_DW from the config
header to the defconfig files.
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Select PHYLIB in drivers/net/Kconfig. And remove CONFIG_PHYLIB
from legacy board header files.
This fixed the warnings when both ALTERA_TSE and ETH_DESIGNWARE
are selected.
Reported-by: Pavel Machek <pavel@denx.de>
Acked-by: Chin Liang See <clsee@altera.com>
Acked-by: Pavel Machek <pavel@denx.de>
Tested-by: Pavel Machek <pavel@denx.de>
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
To reduce the size of the U-Boot image on the x600 board, lets enable
the THUMB mode. This reduces the overall size to less than 0x6000
bytes. Fitting it again in the onboard NOR flash.
Cc: Viresh Kumar <viresh.kumar@linaro.org>
This board is equipped with a Micron NAND chip (MT29F1G08ABADAH4) that
needs 4-bit ECC. But the SPEAr600 only supports 1-bit HW ECC internally.
This patch enables the SW 4-bit BCH support for this board.
This patch brings the following changes to the x600 board support:
- Add USB EHCI support
- Add VFAT support for USB key file access
- Increase malloc size (for UBI / UBIFS usage)
- Enable Thumb mode to save some image space
- Remove unreferenced CONFIG_STACKSIZE
- Remove unreferenced CONFIG_SPL_NO_PRINTF
Cc: Vipin Kumar <vk.vipin@gmail.com>
The SPL implementation for SPEAr600 is older than the common SPL
infrastructure. This patch now moves the SPEAr600 SPL over to the
common SPL code.
Tested on the only SPEAr board that currently uses SPL in mainline
U-Boot, the x600.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
them from include/configs.
This patch moves the following config options to Kconfig:
CONFIG_AUTOBOOT_KEYED
CONFIG_AUTOBOOT_PROMPT
CONFIG_AUTOBOOT_DELAY_STR
CONFIG_AUTOBOOT_STOP_STR
AUTOBOOT_KEYED_CTRLC
[trini: Drop ip04 and pm9263 configs/ additions, those boards previously
set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over
all boards that did change. Make digsy_mtc_* string include seconds to
match others and not warn. ]
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed
from the configs.
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Move this to Kconfig and clean up board config files that use it. Also
rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists
Version 1:
Without this change the board support for these SPEAr boards would
be dropped soon. Generic board support seems to work just fine.
In preparation for the SoCFPGA support of the designware I2C driver,
convert this driver to the common CONFIG_SYS_I2C framework.
This patch converts all users of this driver, this is:
- ST spearxxx boards
- AXS101 (ARC700 platform)
I couldn't test this patch on those boards. Only compile tested for all
spear boards. And tested on SoCFPGA.
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Tested-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
Some boards still use xstr(). Replace remaining occurrences
of xstr() by commonly used __stringify().
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig.
Remove the redundant definition in config headers.
We are about to switch to Kconfig in the next commit.
But there are something to get done beforehand.
In Kconfig, include/generated/autoconf.h defines boolean
CONFIG macros as 1.
CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1.
Otherwise, when switching to Kconfig, the build log
would be sprinkled with warning messages like this:
warning: "CONFIG_SPL" redefined [enabled by default]
Guard the LOADMK functionality with config to provide
an option to enable or disable it.
Enable it for all platforms in mainline which enable CONFIG_CMD_FPGA.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Having CONFIG_SYS_I2C_BASE requires DW I2C driver to explicitly include
<arch/hardware.h> which other platforms may not have at all.
It's always good to have a driver platform-independent.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Tom Rini <trini@ti.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Armando Visconti <armando.visconti@st.com>
Now that the designware ethernet driver uses phylib we need to turn it
on here.
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
[trini: Fixup common/cmd_io.c]
UBI can mount volumes by name or number The current code forces you
to name the volume by prepending every name with "ubi:".
>From fs/ubifs/super.c
* There are several ways to specify UBI volumes when mounting UBIFS:
* o ubiX_Y - UBI device number X, volume Y;
* o ubiY - UBI device number 0, volume Y;
* o ubiX:NAME - mount UBI device X, volume with name NAME;
* o ubi:NAME - mount UBI device 0, volume with name NAME.
Now any name passed in any of the above forms are allowed.
Also update the configs that referenced ubifsmount.
This patch adds support for the X600 SPEAr600 based board. Its also
the first SPEAr600 board that uses the newly introduced SPEAr600
SPL support. Xloader is not necessary any more. By using the new
"u-boot.spr" make target, one image will generated containing both,
U-Boot SPL (with mkimage header as needed by the SPEAr BootROM, and
the main U-Boot with mkimage header.
Cc: Amit Virdi <amit.virdi@st.com>
