path: root/include/configs/woodburn_sd.h
2016-11-18spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORSSemen Protsenko
This option isn't used for anything, so get rid of it. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-03-31woodburn_sd: Remove CONFIG_BOOT_INTERNALFabio Estevam
CONFIG_BOOT_INTERNAL is not used anywhere, so let's remove it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-10-26MX35: add support for woodburn boardStefano Babic
The woodburn board is based on the MX35 SOC. Support for both external (NOR) and internal (SD Card) boot mode are added. It uses the generic SPL framework to implement the internal boot mode. The following peripherals are supported: - Ethernet (FEC) - SD Card - NAND (512 MB) - NOR Flash In the internal boot mode, a simple imximage header is generated to set the address in internal RAM where the SOC must copy the SPL code. The initial setup is then demanded to the SPL itself. Signed-off-by: Stefano Babic <sbabic@denx.de>
