path: root/include/configs/whistler.h
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07arm: Tegra: Use ODMDATA from BCT in IRAMTom Warren
Walk the BIT and BCT to find the ODMDATA word in the CustomerData field and put it into Scratch20 reg for use by kernel, etc. Built all Tegra builds OK; Booted on Seaboard and saw ODMDATA in PMC scratch20 was the same as the value in my burn-u-boot.sh file (0x300D8011). NOTE: All flash utilities will have to specify the odmdata (nvflash --odmdata n) on the command line or via a cfg file, or built in to their BCT. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2012-07-07mmc: tegra2: rename tegra2_mmc.* to tegra_mmc.*Tom Warren
In anticipation of Tegra3 support, continue removing/renaming Tegra2-specific files. No functional changes (yet). Updated copyrights to 2012. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: whistler: store environment in eMMCStephen Warren
Store the environment in eMMC, at the end of the second boot sector. This should not conflict with any other eMMC usage: U-Boot is stored well below this location, and the kernel only uses the general area of the eMMC once booted, not the boot sectors. Note: This assumes the user plugged the standard 8MB MoviNAND card into J29/HSMMC/POP. If they didn't, the boot sector layout may be different. However, use of that particular card is standard practice as far as I know. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: remove CONFIG_USB_ETHER_SMSC95XX from boards without itStephen Warren
The SMSC95xx series may exist either directly on a main board, or as a USB to Ethernet dongle. However, dongles containing these chips are very rare. Hence, remove this config option, except on Harmony where such a chip is actually present on the board. The asix option remains, since it's a popular chip, and I actively use a dongle containing this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-07-07tegra: whistler: reduce and comment network cfg optionsStephen Warren
CONFIG_CMD_PING/NFS aren't required for Whistler to boot. Add some comments. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: flesh out bootcmdStephen Warren
This implements a useful bootcmd for Tegra. The boot order is: * If USB enabled, USB storage * Internal MMC (SD card or eMMC) * If networking is enabled, BOOTP/TFTP When booting from USB or MMC, the boot script is assumed to be in partition 1 (although this may be overridden via the rootpart variable), both ext2 and FAT filesystems are supported, the boot script may exist in either / or /boot, and the boot script may be named boot.scr.uimg or boot.scr. When booting over the network, it is assumed that boot.scr.uimg exists on the TFTP server. There is less flexibility here since those setting up network booting are expected to need less hand-holding. In all cases, it is expected that the initial file loaded is a U-Boot image containing a script that will load the kernel, load any required initrd, load any required DTB, and finally bootm the kernel. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: remove some cruft from CONFIG_EXTRA_ENV_SETTINGSStephen Warren
console isn't used by anything, and the kernel should be set appropriately by whatever script is booting the kernel, not imposed by the bootloader. mem might be useful, but the current value is pretty bogus, since it includes nvmem options that make no sense for an upstream kernel, and equally should not be required for any downstream kernel. Either way, this is also best left to the kernel boot script. smpflag isn't used by anything, and again was probably intended to be a kernel command-line option better set by the kernel boot script. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: Whistler board supportStephen Warren
Whistler is a highly configurable Tegra evaluation and development board. This change adds support for the following specific configuration: E1120 motherboard E1108 CPU board E1116 PMU board The motherboard configuration switches are set as follows: SW1=0 SW2=0 SW3=5 S1/S2/S3/S4 all on, except S3 7/8 are off. Other combinations of daugher boards may work to varying degrees, but will likely require some SW adjustment. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
