Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
[trini: Re-run migration after also including CMD_MEMTEST]
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
Migrate the option CONFIG_SPL_FRAMEWORK and make this gate most of the
current set of options we have in Kconfig. We will need to have some
options available for SPL and !SPL_FRAMEWORK so this is important. In a
few cases we re-order existing options so that we have less escapes from
the SPL_FRAMEWORK guard.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
This board is based on the Atmel sama5d3 eval boards.
Supporting the following features:
- Boot from NAND Flash
- Ethernet
- FIT
- SPL
Signed-off-by: Ben Whitten <ben.whitten@lairdtech.com>
Signed-off-by: Dan Kephart <dan.kephart@lairdtech.com>
