This value is not used by u-boot, and it should not. The load address
of an OPTEE image is defined by said image. Either a uImage or a FIT
will have a defined load address and entry point. Those values are the
correct ones, not CONFIG_OPTEE_LOAD_ADDR.
Commit f25006b96e9f ("optee: Add CONFIG_OPTEE_LOAD_ADDR") justifies
this config by requiring its presence in u-boot's .config for other
images as part of a larger build, claiming it is "the best way".
This argument is not persuasive. U-boot's configuration is driven by
platform requirements, not the other way around. It seems more likely
that the argument is conflating tooling issues with Kconfig. Yocto and
buildroot have excellent mechanisms for defining values across the
board (pun intended). u-boot's Kconfig is the wrong place to do it.
Furthermore, it is not "best" for u-boot because it hardcodes a value
which is then not used. In fact the load address that u-boot uses is
the one derived from the OPTEE image.
Confused yet? I sure was. To prevent future confusion, remove
Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
No iMX platforms have supported ATAG-based booting. They have however
re-used the CONFIG_SERIAL_TAG option as a way to enable support of
reading the OTP fuses and setting the serial# environment variable in
some cases. Change the warp7 support to use this symbol, use this for
updating the rest of the imx7 code, and update the imx8 conditionals.
Cc: Fabio Estevam <festevam@gmail.com>
Cc: NXP i.MX U-Boot Team <uboot-imx@nxp.com>
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
- In most of the codebase, we reference CONFIG_SYS_LOAD_ADDR and not
CONFIG_LOADADDR.
- Generally, CONFIG_SYS_LOADADDR is set to CONFIG_LOADADDR and then as
noted, we use CONFIG_SYS_LOADADDR.
CONFIG_SYS_I2C_MXC
CONFIG_SYS_I2C_MXC_I2C1
CONFIG_SYS_I2C_MXC_I2C2
CONFIG_SYS_I2C_MXC_I2C3
CONFIG_SYS_I2C_MXC_I2C4
CONFIG_SYS_I2C_SPEED
CONFIG_SYS_I2C_SLAVE
CONFIG_SYS_DFU_MAX_FILE_SIZE to Kconfig
Currently the config options CONFIG_SYS_DFU_DATA_BUF_SIZE and
CONFIG_SYS_DFU_MAX_FILE_SIZE are being set in include/configs/<board>.h
files and also in <board_name>_defconfig files without a Kconfig option. It
is easier for users to set these configs in defconfig files than in config
header files as they are a part of the source code.
Add Kconfig symbols, and update the defconfigs by using tools/moveconfig.py
script.
Suggested-by: Pratyush Yadav <p.yadav@ti.com>
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
Acked-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Acked-by: Matthias Brugger <mbrugger@suse.com>
Acked-by: Lukasz Majewski <lukma@denx.de>
Done via moveconfig.py
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
With commit 6b503f9e6549("warp7: Switch to DM USB").
These configs are not necessary
Signed-off-by: Joris Offouga <offougajoris@gmail.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
U-Boot binary has grown in such a way that it goes beyond the reserved
area for the environment variables.
Running "saveenv" followed by a "reset" causes U-Boot to hang because
of this overlap.
Fix this problem by increasing the CONFIG_ENV_OFFSET size.
Also, in order to prevent this same problem in the future, use
CONFIG_BOARD_SIZE_LIMIT, which will detect the overlap in build-time.
CONFIG_BOARD_SIZE_LIMIT does not accept math expressions, so declare
CONFIG_ENV_OFFSET with its direct value instead.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Acked-by: Pierre-Jean Texier <pjtexier@koncepto.io>
Tested-by: Pierre-Jean Texier <pjtexier@koncepto.io>
Acked-by: Joris Offouga <offougajoris@gmail.com>
Tested-by: Joris Offouga <offougajoris@gmail.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
If no CONFIG_OPTEE_LOAD_ADDR is provided i.e. you are not loading OPTEE
into memory in u-boot, then just set the non-existent CONFIG option to
zero, elsewise stringify(CONFIG_OPTEE_LOAD_ADDR) will return
"CONFIG_OPTEE_LOAD_ADDR" - which looks weird in the u-boot environment.
Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
In the Mbed Linux OS bootflow OP-TEE runs before u-boot and provides a DTB
overlay at 0x83100000.
This overlay should subsequently be merged into the main DTB before handing
over to the kernel.
This patch defines fdtovaddr at 0x83100000.
Reusing the loadaddr to load the boot script breaks some of the logic we
want to have around the bootscript/FIT load addresses. Making a dedicated
bootscript address allows us to differentiate the bootscript load address
from the Linux Kernel or OPTEE load address, thus ensuring that no matter
what the load sequence the bootscript and Kernel/OPTEE binary load
addresses do not conflict.
When obtaining the bootscript from a FIT image we need to specify the name
of the bootscript as defined inside of the FIT.
This patch makes a define that appends a "bootscr" parameter to the source
command when compiling up in FIT mode on warp7.
An environment variable is supplied to enable others to use a different
name than "bootscr" as the image name of the boot script in their FIT.
Share configs in mx7 to skip low level init if we are in the case where
OPTEE is loaded already (maybe by ARM Trusted Firmware) and that most of
the low level initialization is already done and that we may/should skip
it doing them here.
Fix the definition detection with size detection to decide whether to skip
it.
Signed-off-by: Jun Nie <jun.nie@linaro.org>
CONFIG_SUPPORT_EMMC_BOOT
As requested by Michal Simek <michal.simek@xilinx.com>, these boards
have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated:
xilinx_zynqmp_zc1275_revB
xilinx_zynqmp_zc1751_xm018_dc4
xilinx_zynqmp_zc1751_xm019_dc5
xilinx_zynqmp_zcu100_revC
xilinx_zynqmp_zcu102_rev1_0
xilinx_zynqmp_zcu102_revA
xilinx_zynqmp_zcu102_revB
xilinx_zynqmp_zcu104_revA
xilinx_zynqmp_zcu104_revC
xilinx_zynqmp_zcu106_revA
xilinx_zynqmp_zcu111_revA
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
Acked-by: Ramon Fried <ramon.fried@gmail.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
This commit switches to DM SERIAL for warp7 and warp7_bl33 defconfigs.
Signed-off-by: Pierre-Jean Texier <pjtexier@koncepto.io>
After DM conversion, U-Boot is larger than 512 KiB, so we need to increase
the "size" of the dfu_alt_info setting.
This patch converts the warp7 and warp7_bl33 board ports over to using the
DM PMIC model.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
This commit switches to DM I2C for warp7 and warp7_bl33 defconfigs.
If we have defined the OPTEE ram size and not OPTEE means that we are in
the case where OPTEE is loaded already (maybe by ARM Trusted Firmware) and
that most of the low level initialization is already done and that we
may/should skip it doing them here.
Signed-off-by: Rui Miguel Silva <rui.silva@linaro.org>
Cc: u-boot@lists.denx.de
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
This patch adds support for verifying a signed boot.scr. With this in place
it's possible for run-time Linux to update boot.scr to set different
variables such as switching between different boot partitions, pointing to
different kernels etc and for u-boot to verify these changes via the HAB
prior to executing the commands contained in boot.scr.
Tested-by: Breno Lima <breno.lima@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
This patch introduces the environment variable ivt_offset. When we define a
load address for Linux or DTB or any file the IVT associated with that file
is prepended. We extract the actual load addresses from u-boot.cfg and feed
these values into the code-signing process - hence we want u-boot to have
the real load addresses exported in uboot.cfg.
ivt_offset represents the addition or subtraction from the load address
that must happen to find an IVT header.
Doing secure boot on the WaRP7 using a common image format and the same
variable to represent the base address for each call means we can reduce
down the command to a single environment command.
This patch adds warp7_auth_or_fail as a wrapper around
"hab_auth_img_or_fail ${hab_ivt_addr} ${filesize} 0".
We need to know the name of a signed boot-script, its better to have a
separate variable for this then to simply append some fixed string to an
existing image name.
Assigning the UUID discovery path to a tweakable environment variable means
that later steps in the boot process - particularly a boot script can
change the target root partition of a particular Linux boot.
Retargeting the rootfs is an important feature when doing ping/pong
upgrades allowing a boot script to select ping or pong as necessary without
reprogramming the bootloader.
In order to sign images with the IMX code-signing-tool (CST) we need to
know the load address of a given image. The best way to derive this load
address is to make it into a define - so that u-boot.cfg contains the
address - which we can then parse when generating the IMX CST headers.
Reviewed-by: Ryan Harkin <ryan.harkin@linaro.org>
This patch makes the OPTEE_LOAD_ADDR available via u-boot.cfg for further
parsing by external tools.
This patch adds an environment variable called "hab_enabled" which gets set
to a boolean status indicating whether HAB is enabled or not.
Subsequent patches can use this environment variable to determine if its
necessary to run a given binary through the hab_auth_img console command.
use the generic filesystem command 'load' rather
than 'fatload' to avoid per-fs specific commands.
Signed-off-by: Pierre-Jean TEXIER <texier.pj2@gmail.com>
Acked-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
u-boot has a standard "serial#" environment variable that is suitable
for storing the iSerial number we will supply via the USB device
descriptor. serial# is automatically picked up by the disk subsystem in
u-boot - thus providing a handy unique identifier in /dev/disk/by-id as
detailed below.
Storing the hardware serial identifier in serial# means we can change the
serial# if we want before USB enumeration - thus making iSerial automatic
via OTP but overridable if necessary.
This patch reads the defined OTP fuse and sets environment variable
"serial#" to the value read.
With this patch in place the USB mass storage device will appear in
/dev/disk/by-id with a unique name based on the OTP value. For example
/dev/disk/by-id/usb-Linux_UMS_disk_0_WaRP7-0xf42400d3000001d4-0:0
Cc: Rui Miguel Silva <rui.silva@linaro.org>
Cc: Ryan Harkin <ryan.harkin@linaro.org>
This commit moves USB_FUNCTION_MASS_STORAGE config to Kconfig.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
We need to select an interface for the usb_ether gadget, and they haven't
been converted to Kconfig yet. Add a choice to make sure we have an option
selected, and convert all the users.
Reviewed-by: Łukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The USB Ethernet gadget option has not yet been moved to Kconfig, let's
deal with that.
While the USB Ethernet device address is already defined in Kconfig, the
host address isn't. Convert it.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
With d53ecad92f06 some unused interrupt related code was removed.
However all of these options are currently unused. Rather than migrate
some of these options to Kconfig we just remove the code in question.
The only related code changes here are that in some cases we use
CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename
and move the value local to the code in question.
Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi")
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
We convert CONFIG_PARTITION_UUIDS to Kconfig first. But in order to cleanly
update all of the config files we must also update CMD_PART and CMD_GPT to also
be in Kconfig in order to avoid complex logic elsewhere to update all of the
config files.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_BOARD_EARLY_INIT_F
Signed-off-by: Jagan Teki <jagan@openedev.com>
Enable USB gadget ethernet by default to have networking capabilities.
Tested using DHCP and TFTP to transfer kernel, DT, ramdisk.
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
