path: root/include/configs/warp7.h
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-06warp7: Use PARTUUID to specify the rootfs locationFabio Estevam
warp7 can run different kernel versions, such as NXP 4.1 or mainline. Currently the rootfs location is passed via mmcblk number and the problem with this approach is that the mmcblk number for the eMMC changes depending on the kernel version. In order to avoid such issue, use UUID method to specify the rootfs location. Succesfully tested booting a NXP 4.1 and also a mainline kernel. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-09-06warp7: Modify fdt_file environment variableBreno Lima
Use imx7s-warp.dts as fdt_file because this is the name that upstream kernel will deploy. Signed-off-by: Breno Lima <breno.lima@nxp.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-09-06warp7: Add PMIC supportVanessa Maegima
Add PMIC support. Tested by command "pmic PFUZE3000 dump". Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2016-07-28warp7: Move some USB configuration options to defconfigBreno Lima
Currently it's recommended to move some configuration options to the defconfig file. Move some USB related options to the defconfig file. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2016-07-19mx7_common: Put display board info config into board fileStefan Agner
CONFIG_DISPLAY_BOARDINFO should not be placed in mx7_common because some boards might need a different config such as CONFIG_DISPLAY_BOARDINFO_LATE. Move it to the board file instead. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-07-19usb: move CONFIG_USB_EHCI_MX7 to KconfigStefan Agner
Create an entry for "config USB_EHCI_MX7" in Kconfig and switch over to it for all boards. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-18warp7: Fix DFU supportFabio Estevam
Currently DFU is not working. Adjust CONFIG_SYS_MALLOC_LEN and dfu_alt_info so that we are able to flash u-boot.imx into the eMMC via dfu using the following method: => dfu 0 mmc 0 In the host PC: dfu-util -D u-boot.imx -a boot This is the same approach done in the mx6sl warp board. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-06-18warp7: Fix watchdog resetMarco Franchi
The latest version of warp7 board provides the connection of the WDOG1_B pin to the PMIC. Program the watchdog to enable the WDOG1_B output which causes a POR reset. Based on the imx7dsabresd code. Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-03mx7_common: Define CONFIG_SYS_MALLOC_LEN in the board fileFabio Estevam
Having CONFIG_SYS_MALLOC_LEN in mx7_common.h is not a good idea, because the malloc() pool size is board dependent. For example: if a certain board has support for splashscreen or DFU, it may be necessary to adjust CONFIG_SYS_MALLOC_LEN to a larger value. So define CONFIG_SYS_MALLOC_LEN in each board config file. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-04-03warp7: Pass the UART base definitionFabio Estevam
Since commit 5d69269deed0 ("mx7dsabresd: Define serial port locally") we need to specify the UART base address in each board config file, so do this to avoid a build error. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-03-26warp7: Add initial supportFabio Estevam
Add the basic support for Warp7 board. For more information about this reference design, please visit: https://www.element14.com/community/docs/DOC-79058/l/warp-7-the-next-generation-wearable-reference-platform Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
