path: root/include/configs/wandboard.h
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-28arm: Clean up MACH_TYPE_xxx usage after re-sync of mach-typesTom Rini
With the latest mach-types values we have many instances where we no longer need to define a value and a few cases where the name (but not value) have changed slightly. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-29arm: imx: wandboard: fix compile error if CONFIG_VIDEO is deactivatedSven Ebenfeld
When I tried to deactivate VIDEO support for the Wandboard, it still tried to initialize the Framebuffer and so on. That is the reason for the added ifdefs. CONFIG_VIDEO is enabled in the configuration as default and therefore nothing changes for the default user. The structs mx6dl_i2c2_pad_info and mx6q_i2c2_pad_info are only available when CONFIG_IPUV3 are set and should not be tried to access, when that define is not defined. Signed-off-by: Sven Ebenfeld <sven.ebenfeld@gmail.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONFIG_CFB_CONSOLE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-04wandboard: Remove videoargs scriptFabio Estevam
The videoargs script is kernel version dependent and since wandboard uses distro config, there is no need to handle videoargs locally. In case such video related settings are needed, then the proper location would be the distro extlinux.conf or boot.scr files. So remove 'videoargs' script. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-19wandboard: move environment partition farther from u-boot.imgAlexey Brodkin
Recently I started to notice that u-boot.img built for Wandboard by some toolchains becomes so large that it basically overlaps with U-Boot environment area on SD-card. According to http://wiki.wandboard.org/index.php/Boot-process#sdcard_boot_data_layout Wandboard's SD-card layout is as follows: ------------------------------>8--------------------------- Acked-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Fabio Estevam <fabio.estevam@nxp.com> ========================================================== 1. 0x00000000 Reserved For MBR 2. 0x00000200 512 Secondary Image Table (optional) 3. 0x00000400 1024 uBoot Image (Starting From IVT) 4. 0x00060000 393216 start of uboot env (size:8k) 5. 0x00062000 end of uboot env 6. 0x00100000 1048576 Linux kernel start 7. 0x0076AC00 7777280 start of partition 1 ------------------------------>8--------------------------- So for U-Boot we have 383kB (392192 bytes). But in up to date U-Boot for Wandboard we build separately a) SPL b) u-boot.img which gives us a bit more detailed SD-card layout: ------------------------------>8--------------------------- ========================================================== 1. 0x00000000 Reserved For MBR 2. 0x00000200 512 Secondary Image Table (optional) 3. 0x00000400 1024 SPL 4. 0x00011400 70656 u-boot.img 5. 0x00060000 393216 start of uboot env (size:8k) 6. 0x00062000 end of uboot env ... ------------------------------>8--------------------------- >From that layout we may calculate amount of space reserved for u-boot.img. It's just 315kb (322560 bytes). Now if I build U-Boot with Sourcery CodeBench ARM 2014.05 produced u-boot.img is already more than we expected (323840 bytes instead of "< 322560"): ------------------------------>8--------------------------- ls -la u-boot.img -rw-rw-r-- 1 user user 323840 Jul 5 07:38 u-boot.img ------------------------------>8--------------------------- Funny enough if I rebuild U-Boot with ARM toolchain available in my Fedora 23 distro u-boot.img becomes a little bit smaller: ------------------------------>8--------------------------- ls -la u-boot.img -rw-rw-r-- 1 user user 322216 Jul 5 07:39 u-boot.img ------------------------------>8--------------------------- What's worse this problem might not affect people most of the time because what happens people would just copy u-boot.img on SD-card and live in happiness with it... well until somebody attempts to save environment in U-Boot with "saveenv" command which will simply overwrite the very end of u-boot.img. That will lead to unusable SD-card until user dd u-boot.img on SD-card again. I may foresee this issue in the future to become more visible once we add more features in U-Boot for Wandboard or just existing code base becomes bulkier and people will consistently get larger u-boot.img files produced. IMHO there's an obvious solution for all that - just move U-Boot's env to the very end of the gap between U-Boot and the first real partition on the SD-card. This patch will follow 8fb9eea5653796 ("mx6sabre_common: Fix U-Boot corruption after 'saveenv'"). So env is still not in the very end of the gap (obviously 256kb is way too much for U-Boot's env) but at least we have now the same partitioning for i.MX6 boards. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Peter Korsgaard <peter@korsgaard.com> Cc: Wolfgang Denk <wd@denx.de>
2016-07-12wandboard: enable SATA with imx6qGilles Chanteperdrix
Signed-off-by: Gilles Chanteperdrix <gilles.chanteperdrix@xenomai.org>
2016-02-02wandboard: fix variable name so PXE boot worksPeter Robinson
All boards that support PXE booting use the pxefile_addr_r variable. Standardise wandboard with this variable as pxe_addr_r isn't used anywhere else so it's a typo. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
2015-11-13imx6: fix warnings due to switch to distro environmentStefano Babic
wandboard and mx6cuboxi have warnings because BOOT_DELAY is defined twice. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Vagrant Cascadian <vagrant@debian.org> CC: Otavio Salvador <otavio@ossystems.com.br> CC: Fabio Estevam <fabio.estevam@freescale.com>
2015-11-12arm: imx: Switch Wandboard to use config_distro_bootcmd.h.Vagrant Cascadian
This allows for more flexible and standardized boot across multiple platforms. Remove redundant legacy boot environment. Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
2015-10-02I2C: mxc_i2c: make I2C1 and I2C2 optionalAlbert ARIBAUD \\(3ADEV\\)
The driver assumed that I2C1 and I2C2 were always enabled, and if they were not, then an asynchronous abort was (silently) raised, to be caught much later on in the Linux kernel. Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4 are. To make the change binary-invariant, declare I2C1 and I2C2 in every include/configs/ file which defines CONFIG_SYS_I2C_MXC. Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed (CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE) config options. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-07-10imx6: standardise OCOTP and fuse config to mx6_commonPeter Robinson
According to README.mxc_ocotp the OCOTP is a stanard i.MX6 SoC feature so centralise the config in mx6_common.h so functionality is standard across all boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-06-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-06-08wandboard: Add board revision detection supportFabio Estevam
There are two revisions of wandboard: version B1 and C1. Add the revision detection support, so that the correct dtb file can be automatically loaded. Based on the patch from Richard Hu <hakahu@gmail.com>. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Tested-By: Vagrant Cascadian <vagrant@aikidev.net>
2015-05-26mx6: standardise CONFIG_CMD_CACHEPeter Robinson
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: generic MMC config options to mx6_commonPeter Robinson
Move all standard mx6 MMC configs to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: standardise filesystem and boot optionsPeter Robinson
Move all standard filesystem, partition and fdt options to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move generic miscellaneous and overwrite optionsPeter Robinson
Move generic miscellaneous options that are standard across most, if not all, mx6 boards to central mx6_common define to ensure consistent features. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: centralise common boot options in mx6_common.hPeter Robinson
Define common LOADADDR and BOOTDELAY to ensure a consistent experience across mx6 boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move MXC_GPIO define to mx6_common.hPeter Robinson
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move standard ATAG configs to mx6_common.hPeter Robinson
Define the standard ATAG consfigs in mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move generic imx6 options to mx6_common.hPeter Robinson
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move all standard includes to mx6_common.hPeter Robinson
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h, config_cmd_default.h includes are used fairly universally across imx6 boards so include them in mx6_common.h by default. We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-21wandboard: Switch to SPL supportFabio Estevam
Currently we need to build one U-boot image for each of the wandboard variants: quad, dual-lite and solo. By switching to SPL we can support all these variants with a single binary, which is very convenient. Based on the work from Richard Hu. Tested kernel booting on the three boards. Signed-off-by: Richard Hu <hakahu@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Vagrant Cascadian <vagrant@aikidev.net> Reviewed-by: Stefano Babic <sbabic@denx.de>
2015-04-23driver/i2c/mxc: Enable I2C bus 3 and 4York Sun
Some SoCs have more than two I2C busses. Instead of adding ifdef to the driver, macros are put into board header file where CONFIG_SYS_I2C_MXC is defined. Signed-off-by: York Sun <yorksun@freescale.com> CC: Heiko Schocher <hs@denx.de>
2015-03-13wandboard: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-01-19wandboard: Use 32bit color depth for Fusion LCDOtavio Salvador
The Fusion LCD needs the 32bit color depth to properly work; the default is different on the 3.10.17 kernels and it is better to ensure it work out of box using proper default color setting. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2014-10-30board: wandboard: add usb storageJeroen Hofstee
Cc: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-01wandboard: Select CONFIG_CMD_FUSEFabio Estevam
Select CONFIG_CMD_FUSE so that the fuse API commands can be used. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-05-09wandboard: Pass video kernel arguments for HDMI and LCDOtavio Salvador
This checks if the 7" WVGA produced by Future Eletronics is detected and pass the needed kernel arguments for it to work. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2014-05-09wandboard: add Future Eletronics 7" WVGA LCD extension boardOtavio Salvador
This adds support for the 7" WVGA produced by Future Eletronics and make it dynamically detect if it is connected or not based on the touchscreen controller. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2014-04-28wandboard: Convert to generic boardFabio Estevam
Enable CONFIG_SYS_GENERIC_BOARD, so that we get rid of the following warning on boot: "Warning: Your board does not use generic board. Please read doc/README.generic-board and take action. Boards not upgraded by the late 2014 may break or be removed." Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2014-01-13wandboard: Set default environment to use zImageJohn Weber
Change the default environment to use zImage instead of uImage, this requires changes to the default environment to load a file named zImage instead of uImage, and to use the 'bootz' command instead of 'bootm' when booting the kernel. The zImage works for FSL Linux's kernel fork versions 3.0.35, 3.10.9, and 3.10.17; this also works fine for mainline kernels. Signed-off-by: John Weber <rjohnweber@gmail.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2014-01-03ARM: mx6: Change the FDT loading address to avoid overlapingOtavio Salvador
This patch fixes allow for the DeviceTree and initrd relocation fixing the boot of FSL 3.10.9-1.0.0-alpha kernel. This changes following boards: - mx6sabreauto - mx6sabresd - wandboard - udoo - nitrogen6x - cgtqmx6eval The reasoning, as explained by Hui Liu, is: ,---- | The FDT blob will be placed at DDR physical addr: 0x11000000. When Linux kernel | Boot up, it will decompress the compressed kernel image and place the decompressed | kernel image at the low end of the DDR memory and start running from it. If the | decompressed kernel image is bigger for example than 16M, it may over written the | fdt blob which u-boot loaded to the DDR memory @0x11000000 with fdt_addr=0x11000000 | | To expand the fdt_addr from 0x11000000 to 0x18000000, which can avoid the override | Since we will not likely have one kernel image larger than 128MB. `---- Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2013-12-17ARM: mx6: Update non-Freescale boards to include CPU errata.Eric Nelson
The CPU errata expressed in include/configs/mx6_common.h apply to all i.MX6DQ and i.MX6DLS parts. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefan Roese <sr@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
