path: root/include/configs/wandboard.h
2015-10-02I2C: mxc_i2c: make I2C1 and I2C2 optionalAlbert ARIBAUD \\(3ADEV\\)
The driver assumed that I2C1 and I2C2 were always enabled, and if they were not, then an asynchronous abort was (silently) raised, to be caught much later on in the Linux kernel. Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4 are. To make the change binary-invariant, declare I2C1 and I2C2 in every include/configs/ file which defines CONFIG_SYS_I2C_MXC. Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed (CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE) config options. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-07-10imx6: standardise OCOTP and fuse config to mx6_commonPeter Robinson
According to README.mxc_ocotp the OCOTP is a stanard i.MX6 SoC feature so centralise the config in mx6_common.h so functionality is standard across all boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-06-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-06-08wandboard: Add board revision detection supportFabio Estevam
There are two revisions of wandboard: version B1 and C1. Add the revision detection support, so that the correct dtb file can be automatically loaded. Based on the patch from Richard Hu <hakahu@gmail.com>. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Tested-By: Vagrant Cascadian <vagrant@aikidev.net>
2015-05-26mx6: standardise CONFIG_CMD_CACHEPeter Robinson
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: generic MMC config options to mx6_commonPeter Robinson
Move all standard mx6 MMC configs to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: standardise filesystem and boot optionsPeter Robinson
Move all standard filesystem, partition and fdt options to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move generic miscellaneous and overwrite optionsPeter Robinson
Move generic miscellaneous options that are standard across most, if not all, mx6 boards to central mx6_common define to ensure consistent features. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: centralise common boot options in mx6_common.hPeter Robinson
Define common LOADADDR and BOOTDELAY to ensure a consistent experience across mx6 boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move MXC_GPIO define to mx6_common.hPeter Robinson
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move standard ATAG configs to mx6_common.hPeter Robinson
Define the standard ATAG consfigs in mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move generic imx6 options to mx6_common.hPeter Robinson
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move all standard includes to mx6_common.hPeter Robinson
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h, config_cmd_default.h includes are used fairly universally across imx6 boards so include them in mx6_common.h by default. We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-21wandboard: Switch to SPL supportFabio Estevam
Currently we need to build one U-boot image for each of the wandboard variants: quad, dual-lite and solo. By switching to SPL we can support all these variants with a single binary, which is very convenient. Based on the work from Richard Hu. Tested kernel booting on the three boards. Signed-off-by: Richard Hu <hakahu@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Vagrant Cascadian <vagrant@aikidev.net> Reviewed-by: Stefano Babic <sbabic@denx.de>
2015-04-23driver/i2c/mxc: Enable I2C bus 3 and 4York Sun
Some SoCs have more than two I2C busses. Instead of adding ifdef to the driver, macros are put into board header file where CONFIG_SYS_I2C_MXC is defined. Signed-off-by: York Sun <yorksun@freescale.com> CC: Heiko Schocher <hs@denx.de>
2015-03-13wandboard: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-01-19wandboard: Use 32bit color depth for Fusion LCDOtavio Salvador
The Fusion LCD needs the 32bit color depth to properly work; the default is different on the 3.10.17 kernels and it is better to ensure it work out of box using proper default color setting. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2014-10-30board: wandboard: add usb storageJeroen Hofstee
Cc: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-01wandboard: Select CONFIG_CMD_FUSEFabio Estevam
Select CONFIG_CMD_FUSE so that the fuse API commands can be used. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-05-09wandboard: Pass video kernel arguments for HDMI and LCDOtavio Salvador
This checks if the 7" WVGA produced by Future Eletronics is detected and pass the needed kernel arguments for it to work. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2014-05-09wandboard: add Future Eletronics 7" WVGA LCD extension boardOtavio Salvador
This adds support for the 7" WVGA produced by Future Eletronics and make it dynamically detect if it is connected or not based on the touchscreen controller. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2014-04-28wandboard: Convert to generic boardFabio Estevam
Enable CONFIG_SYS_GENERIC_BOARD, so that we get rid of the following warning on boot: "Warning: Your board does not use generic board. Please read doc/README.generic-board and take action. Boards not upgraded by the late 2014 may break or be removed." Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2014-01-13wandboard: Set default environment to use zImageJohn Weber
Change the default environment to use zImage instead of uImage, this requires changes to the default environment to load a file named zImage instead of uImage, and to use the 'bootz' command instead of 'bootm' when booting the kernel. The zImage works for FSL Linux's kernel fork versions 3.0.35, 3.10.9, and 3.10.17; this also works fine for mainline kernels. Signed-off-by: John Weber <rjohnweber@gmail.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2014-01-03ARM: mx6: Change the FDT loading address to avoid overlapingOtavio Salvador
This patch fixes allow for the DeviceTree and initrd relocation fixing the boot of FSL 3.10.9-1.0.0-alpha kernel. This changes following boards: - mx6sabreauto - mx6sabresd - wandboard - udoo - nitrogen6x - cgtqmx6eval The reasoning, as explained by Hui Liu, is: ,---- | The FDT blob will be placed at DDR physical addr: 0x11000000. When Linux kernel | Boot up, it will decompress the compressed kernel image and place the decompressed | kernel image at the low end of the DDR memory and start running from it. If the | decompressed kernel image is bigger for example than 16M, it may over written the | fdt blob which u-boot loaded to the DDR memory @0x11000000 with fdt_addr=0x11000000 | | To expand the fdt_addr from 0x11000000 to 0x18000000, which can avoid the override | Since we will not likely have one kernel image larger than 128MB. `---- Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2013-12-17ARM: mx6: Update non-Freescale boards to include CPU errata.Eric Nelson
The CPU errata expressed in include/configs/mx6_common.h apply to all i.MX6DQ and i.MX6DLS parts. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefan Roese <sr@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-09-20wandboard: Use imx6dl-wandboard.dtb for the solo versionFabio Estevam
The wandboard solo version should boot the 'imx6dl-wandboard.dtb' file, since dual-lite and solo variants are the same SoC with only the number of cores being different. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-31Merge git://git.denx.de/u-boot-armStefano Babic
Conflicts: board/freescale/mx6qsabrelite/Makefile board/freescale/mx6qsabrelite/mx6qsabrelite.c include/configs/mx6qsabrelite.h Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-07-27mx6: Factor out common HDMI setup codePardeep Kumar Singla
Instead of duplicating HDMI setup code for every mx6 board, factor out the common code Signed-off-by: Pardeep Kumar Singla <b45784@freescale.com> Acked-By: Eric Nelson <eric.nelson@boundarydevices.com>
2013-07-24wandboard: Use splash image at screen center by defaultOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-12wandboard: Change default environment to cope with OE changesOtavio Salvador
OpenEmbedded has change partitioning layout of generated image so it does not raise warnings during the boot regarding unkown partition being used for U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-06-26Add support for Wandboard QuadTapani Utriainen
Add support for the Quad version of Wandboard; fix compile warning resulting from having 2G of memory. Signed-off-by: Tapani Utriainen <tapani@technexion.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2013-06-06ARM: imx: Fix incorrect usage of CONFIG_SYS_MMC_ENV_PARTFabio Estevam
When running the "save" command several times on a mx6qsabresd we see: U-Boot > save Saving Environment to MMC... Writing to MMC(1)... done U-Boot > save Saving Environment to MMC... MMC partition switch failed U-Boot > save Saving Environment to MMC... Writing to MMC(1)... done U-Boot > save Saving Environment to MMC... MMC partition switch failed U-Boot > save Saving Environment to MMC... Writing to MMC(1)... done U-Boot > save Saving Environment to MMC... MMC partition switch failed This issue is caused by the incorrect usage of CONFIG_SYS_MMC_ENV_PART. CONFIG_SYS_MMC_ENV_PART should be used to specify the mmc partition that stores the environment variables. On some imx boards it is been incorrectly used to pass the partition of kernel and dtb files for the 'mmcpart' script variable. Remove the CONFIG_SYS_MMC_ENV_PART usage and configure the 'mmcpart' variable directly. Reported-by: Jason Liu <r64343@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <r64343@freescale.com>
2013-06-03wandboard: Add Boot Splash image with Wandboard logoOtavio Salvador
2013-06-03wandboard: Enable HDMI splashscreenFabio Estevam
2013-04-25wandboard: Add boot selection supportOtavio Salvador
Adds support for 'bmode' command which let user to choose where to boot from; this allows U-Boot to load system from another storage without messing with jumpers. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-25wandboard: Add support for Carrier Board MicroSD cardOtavio Salvador
Allow use of the carrier board MicroSD card available in the Wandboard; this allow for loading alternative system from the other card for testing or upgrade proposes. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-25wandboard: Add update_sd_firmware supportOtavio Salvador
This allow for easy update of firmware in the SD card from a running U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-25wandboard: Use env storage info for mmcdev/mmcpartOtavio Salvador
This makes environment and mmcdev/mmcpart in sync with SYS_MMC_ENV_DEV and SYS_MMC_ENV_PART settings. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-03wandboard: Remove CONFIG_SYS_FSL_USDHC_NUMFabio Estevam
CONFIG_SYS_FSL_USDHC_NUM is not used for wandboard. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-03wandboard: Remove duplicate 'mmc dev'Fabio Estevam
No need to call 'mmc dev' twice. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-03-20Add initial support for Wandboard dual lite and solo.Fabio Estevam
Wandboard is a development board that has two variants: one version based on mx6 dual lite and another one based on mx6 solo. For more details about Wandboard, please refer to: http://www.wandboard.org/ Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
