path: root/include/configs/wandboard.h
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-09-20wandboard: Use imx6dl-wandboard.dtb for the solo versionFabio Estevam
The wandboard solo version should boot the 'imx6dl-wandboard.dtb' file, since dual-lite and solo variants are the same SoC with only the number of cores being different. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-31Merge git://git.denx.de/u-boot-armStefano Babic
Conflicts: board/freescale/mx6qsabrelite/Makefile board/freescale/mx6qsabrelite/mx6qsabrelite.c include/configs/mx6qsabrelite.h Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-07-27mx6: Factor out common HDMI setup codePardeep Kumar Singla
Instead of duplicating HDMI setup code for every mx6 board, factor out the common code Signed-off-by: Pardeep Kumar Singla <b45784@freescale.com> Acked-By: Eric Nelson <eric.nelson@boundarydevices.com>
2013-07-24wandboard: Use splash image at screen center by defaultOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-12wandboard: Change default environment to cope with OE changesOtavio Salvador
OpenEmbedded has change partitioning layout of generated image so it does not raise warnings during the boot regarding unkown partition being used for U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-06-26Add support for Wandboard QuadTapani Utriainen
Add support for the Quad version of Wandboard; fix compile warning resulting from having 2G of memory. Signed-off-by: Tapani Utriainen <tapani@technexion.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2013-06-06ARM: imx: Fix incorrect usage of CONFIG_SYS_MMC_ENV_PARTFabio Estevam
When running the "save" command several times on a mx6qsabresd we see: U-Boot > save Saving Environment to MMC... Writing to MMC(1)... done U-Boot > save Saving Environment to MMC... MMC partition switch failed U-Boot > save Saving Environment to MMC... Writing to MMC(1)... done U-Boot > save Saving Environment to MMC... MMC partition switch failed U-Boot > save Saving Environment to MMC... Writing to MMC(1)... done U-Boot > save Saving Environment to MMC... MMC partition switch failed This issue is caused by the incorrect usage of CONFIG_SYS_MMC_ENV_PART. CONFIG_SYS_MMC_ENV_PART should be used to specify the mmc partition that stores the environment variables. On some imx boards it is been incorrectly used to pass the partition of kernel and dtb files for the 'mmcpart' script variable. Remove the CONFIG_SYS_MMC_ENV_PART usage and configure the 'mmcpart' variable directly. Reported-by: Jason Liu <r64343@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <r64343@freescale.com>
2013-06-03wandboard: Add Boot Splash image with Wandboard logoOtavio Salvador
2013-06-03wandboard: Enable HDMI splashscreenFabio Estevam
2013-04-25wandboard: Add boot selection supportOtavio Salvador
Adds support for 'bmode' command which let user to choose where to boot from; this allows U-Boot to load system from another storage without messing with jumpers. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-25wandboard: Add support for Carrier Board MicroSD cardOtavio Salvador
Allow use of the carrier board MicroSD card available in the Wandboard; this allow for loading alternative system from the other card for testing or upgrade proposes. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-25wandboard: Add update_sd_firmware supportOtavio Salvador
This allow for easy update of firmware in the SD card from a running U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-25wandboard: Use env storage info for mmcdev/mmcpartOtavio Salvador
This makes environment and mmcdev/mmcpart in sync with SYS_MMC_ENV_DEV and SYS_MMC_ENV_PART settings. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-03wandboard: Remove CONFIG_SYS_FSL_USDHC_NUMFabio Estevam
CONFIG_SYS_FSL_USDHC_NUM is not used for wandboard. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-03wandboard: Remove duplicate 'mmc dev'Fabio Estevam
No need to call 'mmc dev' twice. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-03-20Add initial support for Wandboard dual lite and solo.Fabio Estevam
Wandboard is a development board that has two variants: one version based on mx6 dual lite and another one based on mx6 solo. For more details about Wandboard, please refer to: http://www.wandboard.org/ Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
