path: root/include/configs/walnut.h
2015-11-21eeprom: Zap CONFIG_SYS_I2C_MULTI_EEPROMSMarek Vasut
This option only complicates the code unnecessarily, just use CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are only five arguments to eeprom {read/write} if this is defined. If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all six arguments. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2014-01-24powerpc: ppc4xx: remove redundant CONFIG_4xx definitionMasahiro Yamada
We do not have to define CONFIG_4xx in board config headers because it is defined in arch/powerpc/cpu/ppc4xx/config.mk. include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx". I believe it is a typo because "CONFIG_4x" is not used at all in other files. So, I also deleted "CONFIG_4x" in include/configs/JSE.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-06-06ppc4xx: Unify AMCC's board config files (part 3/3)Stefan Roese
This patch series unifies the AMCC eval board ports by introducing a common include header for all AMCC eval boards: include/configs/amcc-common.h This header now includes all common configuration options/defines which are removed from the board specific headers. The reason for this is ease of maintenance and unified look and feel of all AMCC boards. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-08ppc4xx: Add fdt support to all remaining AMCC PPC4xx eval boardsStefan Roese
This patch adds fdt (flattened device tree) support to all remaining AMCC eval boards. Most newer boards already support device tree. With this patch, all AMCC boards now enable device tree passing from U-Boot to Linux arch/powerpc kernels. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-06Replace "run load; run update" with conditionalized "run load update".Detlev Zundel
The latter version stops when "run load" fails for whatever reasons rendering the combination *a lot* more secure. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various [v-z]* named board config ↵Jon Loeliger
files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-02-07[PATCH] Update some AMCC 4xx board config files (set initrd_high)Stefan Roese
Some boards that can have more than 768MBytes of SDRAM need to set "initrd_high", so that the initrd can be accessed by the Linux kernel. Signed-off-by: Stefan Roese <sr@denx.de>
2006-08-07Add commandline history support to all AMCC eval boardsStefan Roese
Patch by Stefan Roese, 07 Aug 2006
2005-10-20Add NetConsole Support for AMCC eval boardsStefan Roese
Patch by Stefan Roese, 20 Oct 2005
2005-08-02Coding style cleanupWolfgang Denk
2005-08-01Major cleanup for AMCC PPC4xx eval boards.Stefan Roese
Patch by Stefan Roese, 01 Aug 2005
