path: root/include/configs/vpac270.h
2015-09-11arm: Remove vpac270_nor_128 boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-02pxa: balloon3/colibri_pxa270: fix environment optionally being nowhereMarcel Ziswiler
I couldn't quite figure out whether or not CONFIG_SYS_ENV_IS_NOWHERE actually ever worked but nowadays this is called CONFIG_ENV_IS_NOWHERE. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2015-03-02pxa: balloon3: remove nowhere used symbol CONFIG_SYS_MEM_BUF_IMPMarcel Ziswiler
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-01-13ARM: pxa: Fix OneNAND window access on VPAC270Marek Vasut
Access the OneNAND 1KiB window on the VPAC270 as an SRAM instead of accessing it as a burst-RAM. This fixes a problem where the board failed to reboot sometimes as the CPU couldn't start executing from the OneNAND 1KiB window. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15serial: pxa: Make use of default_serial_console in serial_pxaMarek Vasut
Make use of the newly implemented weak default_serial_console in the serial_pxa driver. This removes all reimplementations of this function from board files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06PXA: Rename CONFIG_PXA2[57]X to CONFIG_CPU_PXA2[57]XMarek Vasut
2011-12-06PXA: Unify vpac270 environment sizeMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2011-12-06PXA: Enable command line editing for vpac270Marek Vasut
2011-12-06PXA: Adapt Voipac PXA270 to OneNAND SPLMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> V2: Add missing u-boot-spl.lds, convert bitshifts to division, convert to spl_onenand_load_image()
2011-11-15PXA: vpac270: Enable the new generic MMC driverMarek Vasut
2011-09-04PXA: vpac270: Remove re-defined CONFIG_SYS_TEXT_BASEMarek Vasut
2010-10-22PXA: vpac270: Add missing CONFIG_SYS_TEXT_BASEMarek Vasut
2010-10-19Build: PXA: Fix Vpac270 build variantsMarek Vasut
2010-10-19PXA: Fix vpac270 OneNAND booterMarek Vasut
NOTE: The modification in Makefile will be superseded by a pending patch! Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-19PXA: Fix vpac270 for RelocMarek Vasut
2010-10-19PXA: Add necessary information for RELOCMarek Vasut
2010-10-19PXA: fix environment sector size, kernel and environment location for vpac270Mikhail Kshevetskiy
Define ENV_ADDR as MONITOR_BASE + MONITOR_LEN. Fix environment sector size (NOR: 32Kb for first four sectors and 128Kb for other; OneNAND: 128Kb). Last but not least: we have MONITOR_LEN = 0x40000 and one sector for environment (size = 0x20000), so the kernel may start from 0x00060000 only. Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com>
2010-10-19PXA: cleanup vpac270 config and set CONFIG_SYS_HZ to 1000Mikhail Kshevetskiy
* CONFIG_SYS_CLKS_IN_HZ is not used anywhere, so removing it * CONFIG_SYS_HZ is set to 1000 on most architectures, so it seems to be the safe default Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com>
2010-10-19PXA: Voipac270 improvementsMarek Vasut
128MB NOR module support. Define __io to get harddrive working. Fix saving of environment into OneNAND. Boot from harddrive when possible. Add missing MAINTAINERS entry. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-08-09PXA: Declare __io for vpac270 IDEMarek Vasut
2010-07-14PXA: Voipac PXA270 SupportMarek Vasut
This patch adds support for the Voipac PXA270 board. The support includes: - Ethernet - USB - MMC - NOR Booting - OneNAND Booting - LCD - HDD Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com>
