path: root/include/configs/voiceblue.h
2009-06-12mtd: MTD related config header changes (mtdparts command)Stefan Roese
By changing the cmd_mtdparts to only use the MTD infrastructure and not the direct interface to the CFI NOR FLASH driver we now need to add the MTD infrastructure to all boards using those mtdparts commands. This patch adds those components: CONFIG_MTD_DEVICE (for all FLASH types) plus CONFIG_FLASH_CFI_MTD (for NOR FLASH) To all board maintainers: Please test this on your platforms and report any problems/issues found. Thanks. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ron Madrid <info@sheldoninst.com> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Martin Krause <martin.krause@tqs.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Ricardo Ribalda <ricardo.ribalda@uam.es>
2009-04-29arm925t: Fix CONFIG_SYS_HZ to 1000Ladislav Michl
Let CONFIG_SYS_HZ to have value of 1000 effectively fixing all users of get_timer. Changes since original version: * Set PTV=2 (divisor 8) for boards using 12MHz timer clock source to improve timer resolution. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2009-03-30OMAP: rename timer divisorLadislav Michl
Divisor field is called PTV not PVT. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZLadislav Michl
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-04ARM: Board voiceblue updateLadislav Michl
2007-07-09include/configs/[m-z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various [v-z]* named board config ↵Jon Loeliger
files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-05-03VoiceBlue update: use new MTD flash partitioning methods, use moreHeiko Schocher
reasonable TEXT_BASE, update default environment and enable keyed autoboot. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2005-04-07* Patch by Steven Scholz, 07 Apr 2005:wdenk
Add i2c_reg_write() and i2c_reg_write() for at91rm9200 I2C * Patch by Steven Scholz, 07 Apr 2005: Fix compiler warning in altera.c * Patch by Ladislav Michl, 06 Apr 2005: Fix voiceblue configuration.
2005-04-05* Patch by Ladislav Michl, 05 Apr 2005:wdenk
Add support for VoiceBlue board. * Patch by Ladislav Michl, 05 Apr 2005: Fix netboot_common() prototypes. * Cleanup.
