path: root/include/configs/vme8349.h
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-03-17mpc83xx: preempt premature board support removal by setting GENERIC_BOARDKim Phillips
Boards that haven't been converted to GENERIC_BOARD does *not* mean they should be removed. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2014-01-24powerpc: mpc83xx: remove redundant CONFIG_MPC83xx definitionMasahiro Yamada
We do not have to define CONFIG_MPC83xx in board config headers because it is defined in arch/powerpc/cpu/mpc83xx/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-07-03powerpc/mpc83xx: increment malloc heap sizeKim Phillips
extention of commit 3b6b256 "powerpc/mpc83xx: increment malloc heap size for the MPC832x MDS boards" to all other mpc83xx based boards. It fixes "Unable to save the rest of sector" messages when trying to save the environment to flash. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-11-03mpc83xx: Cleanup usage of LBC constantsJoe Hershberger
Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-11-03mpc83xx: Cleanup usage of DDR constantsJoe Hershberger
2011-11-03mpc83xx: Cleanup usage of BAT constantsJoe Hershberger
2011-11-03mpc83xx: cosmetic: vme8349.h checkpatch complianceJoe Hershberger
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-10-18mkconfig: change CONFIG_MK_ prefix into plain CONFIG_Wolfgang Denk
When planning for more generalization and Makefile cleanup it became obvious that the introduction of a separate CONFIG_MK_ name space for config options that were set through scripting in the Makefile was not a good idea. Originally the idea was to provide a script-free approach to supply configuration options - there was no real need for a separate name space. But when we now convert the existing Makefile entries to make use of this approach, it would mean that we have to touch a large number of board config files and add #ifdef / #define sequences to "convert" from the CONFIG_MK_ to the CONFIG_ name space. It seems much cleaner to get rid of this somewhat arbitrary _MK string now for the few boards that actually use it. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-09-23e300: increase CONFIG_SYS_BOOTMAPSZ to allow booting large kernelsIra W. Snyder
Newer Linux kernels can overrun the initial memory window used for booting with their BSS area. When this happens, they overwrite the FDT and silently fail to boot. On e300 CPUs, the Linux kernel uses an initial BAT covering the first 256MB of RAM. See arch/powerpc/kernel/head_32.S for details. Increase the value of CONFIG_SYS_BOOTMAPSZ to accommodate the maximum value allowed by Linux. This will allow very large kernels to boot. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-04-22mpc83xx: turn on icache in core initialization to improve u-boot boot timeKim Phillips
before, MPC8349ITX boots u-boot in 4.3sec: column1 is elapsed time since first message column2 is elapsed time since previous message column3 is the message 0.000 0.000: U-Boot 2010.03-00126-gfd4e49c (Apr 11 2010 - 17:25:29) MPC83XX 0.000 0.000: 0.000 0.000: Reset Status: 0.000 0.000: 0.032 0.032: CPU: e300c1, MPC8349E, Rev: 1.1 at 533.333 MHz, CSB: 266.667 MHz 0.032 0.000: Board: Freescale MPC8349E-mITX 0.032 0.000: UPMA: Configured for compact flash 0.032 0.000: I2C: ready 0.061 0.028: DRAM: 256 MB (DDR1, 64-bit, ECC off, 266.667 MHz) 1.516 1.456: FLASH: 16 MB 2.641 1.125: PCI: Bus Dev VenId DevId Class Int 2.652 0.011: 00 10 1095 3114 0180 00 2.652 0.000: PCI: Bus Dev VenId DevId Class Int 2.652 0.000: In: serial 2.652 0.000: Out: serial 2.652 0.000: Err: serial 2.682 0.030: Board revision: 1.0 (PCF8475A) 3.080 0.398: Net: TSEC1: No support for PHY id ffffffff; assuming generic 3.080 0.000: TSEC0, TSEC1 4.300 1.219: IDE: Bus 0: .** Timeout ** after, MPC8349ITX boots u-boot in 3.0sec: 0.010 0.010: U-Boot 2010.03-00127-g4b468cc-dirty (Apr 11 2010 - 17:47:29) MPC83XX 0.010 0.000: 0.010 0.000: Reset Status: 0.010 0.000: 0.017 0.007: CPU: e300c1, MPC8349E, Rev: 1.1 at 533.333 MHz, CSB: 266.667 MHz 0.017 0.000: Board: Freescale MPC8349E-mITX 0.038 0.020: UPMA: Configured for compact flash 0.038 0.000: I2C: ready 0.038 0.000: DRAM: 256 MB (DDR1, 64-bit, ECC off, 266.667 MHz) 0.260 0.222: FLASH: 16 MB 1.390 1.130: PCI: Bus Dev VenId DevId Class Int 1.390 0.000: 00 10 1095 3114 0180 00 1.390 0.000: PCI: Bus Dev VenId DevId Class Int 1.400 0.010: In: serial 1.400 0.000: Out: serial 1.400 0.000: Err: serial 1.400 0.000: Board revision: 1.0 (PCF8475A) 1.832 0.432: Net: TSEC1: No support for PHY id ffffffff; assuming generic 1.832 0.000: TSEC0, TSEC1 3.038 1.205: IDE: Bus 0: .** Timeout ** also tested on these boards (albeit with a less accurate boottime measurement method): seconds: before after 8349MDS ~2.6 ~2.2 8360MDS ~2.8 ~2.6 8313RDB ~2.5 ~2.3 #nand boot 837xRDB ~3.1 ~2.3 also tested on an 8323ERDB. v2: also remove the delayed icache enablement assumption in arch ppc's board.c, and add a CONFIG_MPC83xx define in the ITX config file for consistency (even though it was already being defined in 83xx' config.mk). Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-04-22mpc83xx: enable command line autocompletionKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-03-02mpc83xx: vme8349: fix incorrect BR0_PRELIM port size commentKim Phillips
commit 98d92d8c9f4021629a45261ad5ec3f3595f3a27a "sbc8349: fix incorrect comment" missed this one. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-01-07mpc83xx: Add support for MPC8349 esd caddy2Reinhard Arlt
The caddy2 is a variant of the already supported vme8349. So we just add the differences to this board port. To better support those two boards we switched from fixed SDRAM configuration to usage of spd_sdram(). This is done by providing a board specific SPD EEPROM routine with different values for both boards. Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de> changed to use mkconfig -t option instead, plus misc codingstyle fixes. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-10-09mpc83xx: cosmetic comment update relating to SPD EEPROMPaul Gortmaker
commit 6d0f6bcf337c5261c08fabe12982178c2c489d76 did the big rename of CFG_ macros to CONFIG_SYS macros. But it missed a couple of instances within comments. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-09-26mpc83xx: retain POR values of non-configured ACR, SPCR, SCCR, and LCRR bitfieldsKim Phillips
some LCRR bits are not documented throughout the 83xx family RMs. New board porters copying similar board configurations might omit setting e.g., DBYP since it was not documented in their SoC's RM. Prevent them bricking their board by retaining power on reset values in bit fields that the board porter doesn't explicitly configure via CONFIG_SYS_<registername>_<bitfield> assignments in the board config file. also move LCRR assignment to cpu_init_r[am] to help ensure no transactions are being executed via the local bus while CLKDIV is being modified. also start to use i/o accessors. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-08-21mpc83xx: accommodate larger kernel sizes by defaultKim Phillips
linux mpc83xx_defconfig kernels are getting bigger, accommodate for their growth by adjusting default load and fdt addresses. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-08-21mpc83xx: mpc8349 - delete unused SYS_MID_FLASH_JUMPPaul Gortmaker
This was introduced with the MPC8349EMDS board, and then copied to a couple other boards by nature of being the reference implementation. u-boot$git grep CONFIG_SYS_MID_FLASH_JUMP include/configs/MPC8349EMDS.h:#define CONFIG_SYS_MID_FLASH_JUMP 0x7F000000 include/configs/sbc8349.h:#define CONFIG_SYS_MID_FLASH_JUMP 0x7F000000 include/configs/vme8349.h:#define CONFIG_SYS_MID_FLASH_JUMP 0x7F000000 u-boot$ It currently isn't used, so delete it before it spreads further. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-27mpc83xx: Add esd VME8349 board supportReinhard Arlt
This patch adds support for the esd VME8349 board equipped with the MPC8349. It's a VME PMC carrier board equipped with the Tundra TSI148 VME-bridge. Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
