This changes enable ONFI detection. The Read ID command now allows
one address byte which is needed for ONFI detection. To read the
ONFI parameter page, the NAND_CMD_PARAM need to be supported. The
CMD code enables one command and one address byte along with reading
data from flash using R/B#, as specified by ONFI.
This commit allows users to enable/disable the Freescale NFC
controller found in systems like Vybrid (VF610), MPC5125, MCF54418
or Kinetis K70 via Kconfig with more detailed help docs.
Some MTD defines are repeated twice; once with UBI and then with MTD.
Remove the duplicate MTD defines from the UBI grouping.
Signed-off-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
Boot from SD-card (and probably also from NAND) was broken since
commit d6d07a9bec ("arm: vf610: add NAND support for vf610twr").
It looks like the increased size of U-Boot lead to a situation
where the boot ROM overwrote its own stack/heap while loading
U-Boot from the SD-card to the SRAM. However, U-Boot worked fine
when loaded through USB serial loader directly into SRAM. It
looks like loading from SD-card uses other stack/heap location
then the serial loader (or maybe no stack or heap at all).
This fix moves U-Boot to gfxRAM, which is 512kB in size and is not
used by the boot ROM nor the SD-card loader of it.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Acked-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
This adds NAND support for the Vybrid tower system (TWR-VF65GS10)
provided by the vf610_nfc driver. Full 16-Bit bus width is
supported. Also an aditional config vf610twr_nand is introduced
which gets the environment from NAND. However, booting U-Boot from
NAND is not yet possible due to missing boot configuration block
(BCB).
Add QSPI support for VF610TWR, such as clock and iomux.
Signed-off-by: Alison Wang <Huan.Wang@freescale.com>
Signed-off-by: Chao Fu <b44548@freescale.com>
Change the default environment to use zImage instead of uImage, this
requires changes to the default environment to load a file named
zImage instead of uImage, and to use the 'bootz' command instead of
'bootm' when booting the kernel.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
This patch adds I2C support for Vybrid VF610 platform and adds
I2C0 support to VF610TWR board.
Signed-off-by: Alison Wang <b18965@freescale.com>
We've been dropping SoC name from U-Boot prompt as it increase
complexity for automatic testing and makes line longer for no good
reason.
Tested-by: Andy Voltz <andy.voltz@timesys.com>
This adds a default environment which should be able to support both
3.0.15 from Timesys and upcoming 3.11.
VF610TWR is a board based on Vybrid VF610 SoC.
This patch adds basic support for Vybrid VF610TWR board.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
