path: root/include/configs/vexpress_ca15_tc2.h
2016-09-07ARM: armv7: move ARMV7_PSCI_NR_CPUS to KconfigMasahiro Yamada
Move this option to Kconfig and set its default value to 4; this increases the number of supported CPUs for some boards. It consumes 1KB memory per CPU for PSCI stack, but it should not be a big deal, given the amount of memory used for the modern OSes. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-16configs: Add more CONFIG_ARMV7_PSCI_NR_CPUS entriesTom Rini
The code had assumed 4 CPUS before and now we have this configurable. For now, set this to the previous default. Cc: Chander Kashyap <k.chander@samsung.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com>
2016-05-27net: Move the VCI and client arch values to KconfigAlexander Graf
We have a bunch of boards that define their vendor class identifier and client archs in the board files or in the distro config. Move everything to the generic Kconfig options. We're missing the distinction between i386 and x86_64, as I couldn't find any config variable that would tell us the difference. Is that really important to people? I guess not, so I left it out. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-08-12Move setting CONFIG_BOOTP_VCI_STRING to before including the vexpress-common ↵Dennis Gilmore
header Signed-off-by: Dennis Gilmore <dennis@ausil.us>
2014-11-24ARM: Add arch/arm/cpu/armv7/Kconfig with non-secure and virt optionsHans de Goede
Add arch/arm/cpu/armv7/Kconfig with non-secure and virt options, this is a preparation patch for adding an env variable to choose between secure / non-secure boot on non-secure boot capable systems, specifically this prepares for adding CONFIG_ARMV7_BOOT_SEC_DEFAULT as a proper Kconfig option. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2013-10-03ARM: VExpress: enable ARMv7 virt support for VExpress A15Andre Przywara
To enable hypervisors utilizing the ARMv7 virtualization extension on the Versatile Express board with the A15 core tile, we add the required configuration variable. Also we define the board specific smp_set_cpu_boot_addr() function to set the start address for secondary cores in the VExpress specific manner. There is no need to provide a custom smp_waitloop() function here. This also serves as an example for what to do when adding support for new boards. Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-10-03ARM: add assembly routine to switch to non-secure stateAndre Przywara
While actually switching to non-secure state is one thing, another part of this process is to make sure that we still have full access to the interrupt controller (GIC). The GIC is fully aware of secure vs. non-secure state, some registers are banked, others may be configured to be accessible from secure state only. To be as generic as possible, we get the GIC memory mapped address based on the PERIPHBASE value in the CBAR register. Since this register is not architecturally defined, we check the MIDR before to be from an A15 or A7. For CPUs not having the CBAR or boards with wrong information herein we allow providing the base address as a configuration variable. Now that we know the GIC address, we: a) allow private interrupts to be delivered to the core (GICD_IGROUPR0 = 0xFFFFFFFF) b) enable the CPU interface (GICC_CTLR[0] = 1) c) set the priority filter to allow non-secure interrupts (GICC_PMR = 0xFF) Also we allow access to all coprocessor interfaces from non-secure state by writing the appropriate bits in the NSACR register. The generic timer base frequency register is only accessible from secure state, so we have to program it now. Actually this should be done from primary firmware before, but some boards seems to omit this, so if needed we do this here with a board specific value. The Versatile Express board does not need this, so we remove the frequency from the configuration file here. After having switched to non-secure state, we also enable the non-secure GIC CPU interface, since this register is banked. Since we need to call this routine also directly from the smp_pen later (where we don't have any stack), we can only use caller saved registers r0-r3 and r12 to not mess with the compiler. Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-05-23ARM: vexpress: add support for Versatile Express Cortex-A15-TC2Andre Przywara
This adds support for the Cortex-A15-TC2 core tile for the Versatile Express board by ARM. This is mostly a copy of the A5 support file, but will be extended later with A15 specific options. Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
