path: root/include/configs/versatile.h
2014-11-20ARM: remove CONFIG_ARM926EJS definesMasahiro Yamada
CONFIG_CPU_ARM926EJS was introduced into Kconfig by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). This commit removes all the defines of CONFIG_ARM926EJS and replaces the only reference in arch/arm/lib/cache.c with CONFIG_CPU_ARM926EJS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-13ARM: versatile: pass console setting to the kernelLinus Walleij
The Versatiles come up with the primary UART set to ttyAMA0 at 38400 baud, and unless we pass this to the kernel it will assume it is set to 9600 baud which will be quite awkward for the terminal, let's try to be helpful and inform the kernel what setting is used. Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-11-04ARM: versatile: convert to common timer codeRob Herring
Convert versatile to use the commmon timer code. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-10-18versatile: board configs: Use buffered writes on flash402jagan@gmail.com
This patch provides a support to use buffered writes on flash for versatile and vexpress boards. This will certainly increase the flash writes. Signed-off-by: Jagannadha Sutradharudu Teki <402jagan@gmail.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-09-04ARM: versatilepb : drop warnings due to double definitionsStefano Babic
CONFIG_ARCH_VERSATILE_PB is defined twice - drop the define from config.h. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-08-04ARM: versatile: fix board supportStefano Babic
Versatile board is used as example to run u-boot under qemu. The patch fixes relocation for all versatile boards and adds a versatileqemu target to be used under qemu. Patch tested only under qemu, not on real boards. Tested with QEMU emulator version 0.14.50. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Alessandro Rubini <rubini-list@gnudd.com> CC: Loïc Minier <loic.minier@linaro.org>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-12versatile: update config and merge to cfi flash driverJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Peter Pearse <peter.pearse@arm.com> Cc: Catalin Marinas <catalin.marinas@arm.com>
2009-07-12versatile: specify the board type on the promptJean-Christophe PLAGNIOL-VILLARD
2009-07-06versatile: config coding style cleanupJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Peter Pearse <peter.pearse@arm.com>
2009-03-29Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-09-09Moved conditional compile into MakefileAndreas Engel
Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
2007-07-09include/configs/[m-z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various [v-z]* named board config ↵Jon Loeliger
files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2004-10-11* Patch by Philippe Robin, 28 Sept 2004:wdenk
Fix Flash support for Versatile. * Patch by Roger Blofeld, 16 Sep 2004: Fix timeout for DHCP command retry
2004-08-02* Patch by Andreas Engel, 12 Jul 2004:wdenk
Replaced hardcoded PL011 clock frequency with config variable. Fixed wrong CONFIG_CMD_DFL doc. * Patch by Thomas Viehweger, 09 Jun 2004: make it possible to remove chpart when there is only one partition
2004-04-25* Patch by Christian Hohnstaedt, 23 Apr 2004:wdenk
JFFS2 speed enhancements: - repair header CRC calculation in jffs2_1pass.c - add eraseblock size to the partition information to skip empty eraseblocks if we find more then 4k of free space. - The JFFS2 scanner is now fast enough to remove the spinning wheel so #ifdef-ed out. - add watchdog calls in long running loops * Patch by Philippe Robin, 22 Apr 2004: Fix ethernet configuration for "versatile" board * Patch by Kshitij Gupta, 21 Apr 2004: Remove busy loop and use MPU timer fr usleep() on OMAP1510/1610 boards * Patch by Steven Scholz, 24 Feb 2004: Fix a bug in AT91RM9200 ethernet driver: The MII interface is now initialized before accessing the PHY. * Cleanup PCI ID's
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-03-14* Patch by Philippe Robin, 09 Mar 2004:wdenk
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference Platform support. * Patch by Masami Komiya, 08 Mar 2004: Don't overwrite server IP address or boot file name when the boot server does not return values * Patch by listmember@orkun.us, 5 Mar 2004: Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
