path: root/include/configs/ve8313.h
2010-09-23e300: increase CONFIG_SYS_BOOTMAPSZ to allow booting large kernelsIra W. Snyder
Newer Linux kernels can overrun the initial memory window used for booting with their BSS area. When this happens, they overwrite the FDT and silently fail to boot. On e300 CPUs, the Linux kernel uses an initial BAT covering the first 256MB of RAM. See arch/powerpc/kernel/head_32.S for details. Increase the value of CONFIG_SYS_BOOTMAPSZ to accommodate the maximum value allowed by Linux. This will allow very large kernels to boot. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-08-19powerpc/83xx: Fix build issue with ve8313 board due to lbus changesKumar Gala
We get two build errors: fsl_elbc_nand.c: In function 'fsl_elbc_run_command': fsl_elbc_nand.c:231: error: 'fsl_lbc_t' has no member named 'lsor' make[1]: *** [/work/wd/tmp-ppc/drivers/mtd/nand/fsl_elbc_nand.o] Error 1 and ve8313.c: In function 'initdram': ve8313.c:104: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token ve8313.c:104: error: 'lbc' undeclared (first use in this function) ve8313.c:104: error: (Each undeclared identifier is reported only once ve8313.c:104: error: for each function it appears in.) ve8313.c:104: error: 'immap_t' has no member named 'lbus' make[1]: *** [ve8313.o] Error 1 make: *** [board/ve8313/libve8313.a] Error 2 Due to changes to unifiy local bus struct definitions. Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-0983xx: add support for ve8313 boardHeiko Schocher
This patch add support for the ve8313 board based on Freescale MPC8313 CPU. - serial console on UART 1 - 128 MB DDR RAM - 32 MB NOR Flash - 16 MB NAND Flash - Ethernet MII Mode over on TSEC0 - micrel ksz804 phy - Hardware WDT MAX824 changes since v1 - Environment size = sector size - use red. environment - add comments from Kim Phillips - add MAKEALL, MAINTAINERS entry - Codingstyle issues fixed - inserted original Copyrights - PCI subsys vendor ID changed from 0x1057 (Motorola) to 0x1957 (Freescale) changes since v2 - add comments from Wolfgang Denk - fix Codingstyle and some comments - reworked WDT reset (just toggling the WD_TRIG pin) - Environment size now 16KiB - fixed RAMBOOT version - fixed CONFIG_SYS_LOAD_ADDR - renamed CONFIG_TSEC1_NAME to TSEC1 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
