path: root/include/configs/vcoreiii.h
2019-04-12configs: vcoreiii: Change CONFIG_ENV_SIZEHoratiu Vultur
Shrink the environment size for 3 reasons: - reading the environment it is slow, therefore having a smaller env improves the speed. - usually in the environment there are only few variables, therefore the enviromnent is almost empty. - because the same image can run on different boards which may have different flashes with different page sizes, the CONFIG_ENV_SECT_SIZE can't be change, it is set to least common multiple of the page sizes. Adding this change improves the boot time. Before update for reading the entire environment it took ~850 msec, after the change it takes ~40 msecs. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-04-12net: Add MSCC Jaguar2 network driver.Horatiu Vultur
Add network driver for Microsemi Ethernet switch. It is present on Jaguar2 SoCs. Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-01-23MSCC: Add support for Serval SoC family.Horatiu Vultur
As Ocelot, Servalt, Luton and Jaguar2, this family of SoCs are found in Microsemi Switches solution. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-01-16mips: mscc: luton+ocelot: Remove board config options, do probingLars Povlsen
As we are moving to multi-dtb and board detection, remove static board config options, and introduce board probing instead. Luton: This add single-binary support for the two MSCC luton-based reference boards - pcb090 and pcb091. The SoC chip ID is used to determine the board type. Ocelot: This add single-binary support for the two MSCC ocelot-based reference boards - pcb120 and pcb123. The PHY ids on specific ports are used to determine the board type. Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com>
2018-12-19MSCC: add board support for the Ocelots based evaluation boardsGregory CLEMENT
Adding the support for 2 boards sharing common code for Ocelot chip: PCB120 and PCB123 Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
