path: root/include/configs/uniphier.h
2020-08-18ARM: uniphier: rename include guard of include/configs/uniphier.hMasahiro Yamada
Make the include guard match to the file name. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-08-08Convert CONFIG_SYS_MMC_ENV_DEV et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MMC_ENV_DEV CONFIG_SYS_MMC_ENV_PART Note that with this conversion we now have consistent behavior with respect to ensuring that we have always selected the correct MMC device and hardware partition. Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-17Convert CONFIG_ARMV7_PSCI_1_0 and CONFIG_ARMV7_PSCI_0_2 to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ARMV7_PSCI_1_0 CONFIG_ARMV7_PSCI_0_2 Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-11ARM: uniphier: remove support for NOR Flash on support cardMasahiro Yamada
I actually do not see this used these days because eMMC or NAND is used for non-volatile devices. Dump the burden to maintain this crappy code. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-07-11ARM: uniphier: increase CONFIG_SYS_MONITOR_LEN to 2MBMasahiro Yamada
I increased the maximum U-Boot proper size from time to time, but configs/uniphier_v7_defconfig hit the current limit 832KB. Some historical info: In the initial support, the max size was 512MB. Commit 58d702274c09 ("ARM: uniphier: increase CONFIG_SYS_MONITOR_LEN") increased it to 576KB, and commit 3ce5b1a8d86d ("ARM: uniphier: move SPL stack address") moved the SPL stack location to avoid the memory map conflict. It was the solution to increase the size without changing the NOR boot image map. commit 1a4bd3a095b2 ("ARM: uniphier: increase CONFIG_SYS_MONITOR_LEN again") ended up with increasing the max size again, breaking the NOR boot image map. The limit was set to 832KB, otherwise the SPL stack would overwrite the U-Boot proper image: CONFIG_SPL_STACK - CONFIG_SYS_UBOOT_BASE + sizeof(struct image_header) = 0xd0000 To increase CONFIG_SYS_MONITOR_LEN even more, the SPL stack must be moved somewhere. I put it back to the original location prior to commit 3ce5b1a8d86d. With this change, there is no more practical size limit. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-02-28ARM: uniphier: add sdscript, sdboot, sdupdate environment variablesMasahiro Yamada
Add handy macros: - sdscript: source boot.scr in the file system of the SD media - sdboot : boot the kernel using the images in the file system of the SD media - sdscript: update the boot firmware in the SD media (in raw block sectors) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-02-01ARM: uniphier: use $loadaddr for source commandMasahiro Yamada
If the "source" command is not given the address, it uses CONFIG_SYS_LOAD_ADDR, which is compile-time determined. Using the "loadaddr" environment variable is handier because it is relocated according to the memory base when CONFIG_POSITION_INDEPENDENT is enabled. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-07-10ARM: uniphier: set {kernel, ramdisk, fdt}_addr_r at boot-timeMasahiro Yamada
The base of DRAM will be changed for the next generation SoC. The addresses needed for booting the kernel should be shifted according to the DRAM base. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-07-10ARM: uniphier: set loadaddr at boot-timeMasahiro Yamada
The base of DRAM will be changed for the next generation SoC. To support it along with existing SoCs in the single defconfig, set 'loadaddr' at boot-time by adding the offset to the DRAM base. CONFIG_SYS_LOAD_ADDR is still hard-coded for compilation, but the value from environment variable 'loadaddr' should be used. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-07-10ARM: uniphier: remove CONFIG_SYS_SDRAM_BASEMasahiro Yamada
The base address of DRAM was 0x80000000 for all the ARM SoCs of this family in the past. It will be changed to 0x20000000 for a planned new SoC. To support multiple SoCs by the single uniphier_v8_defconfig, the base must be run-time determined. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-07-10ARM: uniphier: remove empty #ifdef blockMasahiro Yamada
This is a remnant of commit f89d6133eef2 ("configs: move CONFIG_SPL_TEXT_BASE to Kconfig"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: remove commented linesTrevor Woerner
Eventually these configuration items will be converted to Kconfig, therefore there's little point in leaving commented-out versions of them in include/configs. Signed-off-by: Trevor Woerner <trevor@toganlabs.com>
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-02-22preboot: Introduce CONFIG_USE_PREBOOT and migrate CONFIG_PREBOOTMasahiro Yamada
This is the same migration path as commit b6251db8c3f0 ("Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMAND"). I also moved the description in README to the Kconfig help. I ripped off the sentence about 'LWMON' since it is gone already. I only let my boards migrate, leaving the rest to platform maintainers. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-12-29ARM: uniphier: add CONFIG_PREBOOTMasahiro Yamada
For more boot-flow flexibility, Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-12-29ARM: uniphier: allow to source boot script before distro-bootMasahiro Yamada
Some users might need additional setups before booting the kernel. If there is found a file 'boot.scr', run it before invoking the distro boot command. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-12-29ARM: uniphier: do not modify bootcmd environment variable at run-timeMasahiro Yamada
Some users might want to modify 'bootcmd' at compile-time by editing include/configs/uniphier.h, but overwriting it at run-time makes it impossible. Instead, set 'bootdev' at run-time, which contains the boot device the system is booting from, then indirectly reference it from 'bootcmd'. It is up to users whether to override 'bootcmd'. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-09-11ARM: uniphier: increase CONFIG_SYS_MONITOR_LEN againMasahiro Yamada
With the migration to distro-boot, the size of the U-Boot proper image for uniphier_v7_defconfig exceeded the current limit, 576KB. Increase it to 832KB. CONFIG_SYS_UBOOT_BASE must be moved as well to avoid the image over-wrap because the boot ROM of Pro4, Pro5, PXs2/LD6b loads the SPL to the physical address 0x100000. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-07-25ARM: uniphier: enable distro bootMasahiro Yamada
Switch to the distro boot for UniPhier platform. - Remove the environment vairalbes used to load images from raw block devices. - Keep the command to download images via tftp. This will be useful to boot the kernel when no valid kernel image is ready yet in the file system. - Use root.cpio.gz instead of root.cpio.uboot because we always know the file size of the init ramdisk; it is loaded via either a file system or network. - Rename fit_addr_r to kernel_addr_r, which the distro command checks to get the load address of FIT image. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-05-23ARM: uniphier: rename environment variable fdt_file to fdtfileMasahiro Yamada
For booting Linux in the generic distro mechanism, cmd/pxe.c retrieves the FDT file name from "fdtfile" environment variable. Rename "fdt_file" to "fdtfile" for easier migration to distro boot. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-24ARM: uniphier: move SPL stack addressMasahiro Yamada
Currently, the address region, 0xf8000 - 0x100000, is used for SPL stack for the 32bit SoCs. Because the U-Boot proper image starts from 0x70000, the maximum size of the U-Boot proper image is 544KB (0x70000 - 0xf8000) for the NOR boot mode. Now uniphier_v7_defconfig is almost hitting this size limit. Changing CONFIG_SPL_STACK can raise the size limit with less impact. With this, the size limit will increase to 576KB (0x70000 - 0x100000). If we need to increase it even more, we would be able to change CONFIG_SYS_UBOOT_BASE at the cost of the flashing command changes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-24ARM: uniphier: select a correct mmc device before flashing imagesMasahiro Yamada
Some boards support an SD card and an eMMC device at the same time. Since both belong to 'mmc', they are identified by a device number. When the device number of the eMMC is 1 instead 0, "mmc dev" command must be performed to switch the target device before flashing images. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-24ARM: uniphier: increase CONFIG_SYS_MONITOR_LENMasahiro Yamada
With the recent changes, the size of the U-Boot proper image for uniphier_v7_defconfig exceeded the current limit, 512KB, then SPL fails to load the whole of the U-Boot proper. Increase the size. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-15ARM: uniphier: change load addresses for bigger kernel imageMasahiro Yamada
The kernel size is getting bigger and bigger. Because the Android common kernel is even bigger than the vanilla one, so images overlap in the current memory layout. Adjust the load address for a bigger kernel image. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-03-15ARM: uniphier: increase the firmware size in update command environmentMasahiro Yamada
If a bigger EL32 is used, fip.bin can be larger than the currently assumed boot firmware size. Adjust the update commands. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-01-09ARM: uniphier: hide memory top by platform hook instead of CONFIGMasahiro Yamada
I do not see a good reason to do this by a CONFIG option that affects all SoCs. The ram_size can be adjusted by dram_init() at run-time. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-12-26Move CONFIG_PANIC_HANG to KconfigMasahiro Yamada
Freescale (NXP) boards have lots of defconfig files per board. I used "imply PANIC_HANG" for them. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-11-29ARM: uniphier: remove unused NAND CONFIG optionsMasahiro Yamada
The Denali NAND driver does not use these options any more. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-23ARM: uniphier: remove verify=n from environmentsMasahiro Yamada
If the environment "verify" is set to n, the image verification is entirely skipped. Remove it as a preparation for verified boot. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-23ARM: uniphier: increase CONFIG_SYS_BOOTM_LEN to 32MBMasahiro Yamada
The default value of CONFIG_SYS_BOOTM_LEN, 0x800000, causes error when uncompressing Image.gz out of FIT image. Uncompressing Kernel Image ... Error: inflate() returned -5 Image too large: increase CONFIG_SYS_BOOTM_LEN Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-20net: Add SMC911X driver to Kconfig, convertAdam Ford
We add the various SMC91XX symbols to drivers/net/Kconfig and then this converts the following to Kconfig: CONFIG_SMC911X CONFIG_SMC911X_BASE CONFIG_SMC911X_16_BIT CONFIG_SMC911X_32_BIT Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Apply to the rest of the tree, re-squash old and new patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-02Kconfig: Add EEPROM options to Kconfig when I2C_EEPROM is setAdam Ford
Add the following options to drivers/misc/Kconfig: SYS_I2C_EEPROM_ADDR SYS_I2C_EEPROM_BUS SYS_EEPROM_SIZE SYS_EEPROM_PAGE_WRITE_BITS SYS_EEPROM_PAGE_WRITE_DELAY_MS SYS_I2C_EEPROM_ADDR_LEN SYS_I2C_EEPROM_ADDR_OVERFLOW This does not migrate any boards, but provides a foundations for those who want/need these options Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Migrate uniphier] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-30ARM: uniphier: remove unneeded NAND config optionsMasahiro Yamada
CONFIG_NAND_DENALI select's CONFIG_SYS_NAND_SELF_INIT, so the NAND initialization process is driven by the driver itself. CONFIG_SYS_NAND_MAX_CHIPS and CONFIG_SYS_NAND_BASE are unused. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-08-20ARM: uniphier: remove sLD3 SoC supportMasahiro Yamada
This SoC is too old. It is difficult to maintain any longer. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-07-28configs: Remove CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS in all boardsBin Meng
Now that xHCD does not use CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS, remove it in all boards' config files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-26ARM: uniphier: remove SPL support for ARMv8 SoCsMasahiro Yamada
It has been a while since ARM Trusted Firmware supported UniPhier SoC family. U-Boot SPL was intended as a temporary loader that runs in secure world. It is a maintenance headache to support two different boot mechanisms. Secure firmware is realm of ARM Trusted Firmware and now U-Boot only serves as a non-secure boot loader for UniPhier ARMv8 SoCs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
