These boards will now use the ksz90x1 driver instead of the mess in
ksz8xxx. This change is needed before the two drivers can be fully
separated.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
CONFIG_CMD_SATA
CONFIG_CMD_BMODE
[trini: Make this default y and depend on mx5/6/7]
In the cases of some boards, a MACH_TYPE number is used which is either
not registered upstream or worse (for functionality) is re-using the
number of a different (or reference) platform instead. Make sure we
have a comment in these cases.
Cc: Albert ARIBAUD <albert.aribaud@3adev.fr>
Cc: Walter Schweizer <swwa@users.sourceforge.net>
Cc: Stefan Roese <sr@denx.de>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
CONFIG_BOARD_EARLY_INIT_F
Signed-off-by: Jagan Teki <jagan@openedev.com>
Move this option to Kconfig and tidy up existing uses.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
That way the FS can also be ext2/3/4
Signed-off-by: Oscar Curero <oscar@naiandei.net>
Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
Use dd'ed SPL and u-boot.img by default.
Signed-off-by: Peter Vicman <peter.vicman@gmail.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
Currently we need to build one U-boot image for each of the udoo
variants: quad and dual-lite.
By switching to SPL we can support all two variants with a single binary.
Based on the SPL for wandboard.
Tested with OpenELEC (Open Embedded Linux Entertainment Center)
on both boards.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Reviewed-by: Tom Rini <trini at konsulko.com>
Move all standard mx6 MMC configs to mx6_common.
Move all standard filesystem, partition and fdt options to mx6_common.
Move generic miscellaneous options that are standard across most, if not all,
mx6 boards to central mx6_common define to ensure consistent features.
Define common LOADADDR and BOOTDELAY to ensure a consistent experience
across mx6 boards
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common
Define the standard ATAG consfigs in mx6_common.
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO
and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h,
config_cmd_default.h includes are used fairly universally across imx6 boards
so include them in mx6_common.h by default.
We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we
don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere.
Since commit 0defddc851ed (config: Add a default CONFIG_SYS_PROMPT),
each board header does not need to define CONFIG_SYS_PROMPT
as long as it uses the default prompt "=> ".
Enable CONFIG_SYS_GENERIC_BOARD, so that we get rid of the following warning on
boot:
"Warning: Your board does not use generic board. Please read
doc/README.generic-board and take action. Boards not
upgraded by the late 2014 may break or be removed."
Copied from Linux sources "include/linux/sizes.h" commit
413541dd66d51f791a0b169d9b9014e4f56be13c
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Tom Rini <trini@ti.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Acked-by: Tom Rini <trini@ti.com>
[trini: Add bcm Kona platforms to the patch]
Makefile
drivers/net/npe/Makefile
These two conflicts arise from commit 0b2d3f20
("ARM: NET: Remove the IXP NPE ethernet driver") and are
resolved by deleting the drivers/net/npe/Makefile file
and removing the CONFIG_IXP4XX_NPE line from Makefile.
This commit removes platform CONFIG_SYS_HZ definition for the
remainders of part1 (commit cdb23792) and part2 (commit f232950f).
Cc: Rob Herring <rob.herring@calxeda.com>
Change the default environment to use zImage instead of uImage, this
requires changes to the default environment to load a file named
zImage instead of uImage, and to use the 'bootz' command instead of
'bootm' when booting the kernel.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
This patch fixes allow for the DeviceTree and initrd relocation fixing
the boot of FSL 3.10.9-1.0.0-alpha kernel.
This changes following boards:
- mx6sabreauto
- mx6sabresd
- wandboard
- udoo
- nitrogen6x
- cgtqmx6eval
The reasoning, as explained by Hui Liu, is:
| The FDT blob will be placed at DDR physical addr: 0x11000000. When Linux kernel
| Boot up, it will decompress the compressed kernel image and place the decompressed
| kernel image at the low end of the DDR memory and start running from it. If the
| decompressed kernel image is bigger for example than 16M, it may over written the
| fdt blob which u-boot loaded to the DDR memory @0x11000000 with fdt_addr=0x11000000
| To expand the fdt_addr from 0x11000000 to 0x18000000, which can avoid the override
| Since we will not likely have one kernel image larger than 128MB.
The CPU errata expressed in include/configs/mx6_common.h apply
to all i.MX6DQ and i.MX6DLS parts.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Add SATA support on uDoo Board.
Signed-off-by: Giuseppe Pagano <giuseppe.pagano@seco.com>
CC: Stefano Babic <sbabic@denx.de>
CC: Fabio Estevam <fabio.estevam@freescale.com>
Add Ethernet and networking support on uDoo board (FEC +phy Micrel KSZ9031).
Ethernet speed is currently limited to 10/100Mbps.
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Add basic support for mx6q udoo board.
For further information about Udoo board:
http://www.udoo.org/
Tested booting a mainline device tree kernel and a Yocto rootfs from mmc.
