path: root/include/configs/uc100.h
2008-04-13Add CONFIG_MII_INIT support to related boardsTsiChung Liew
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in cmd_init.c. Add CONFIG_MII_INIT to board configuration files that use mii_init() in cmd_init.c. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-07-09include/configs/[m-z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-08Clear up confusion over the CMD_POST and POST_DIAG mess.Jon Loeliger
For some reason, CONFIG_POST permeated as CONFIG_CMD_POST_DIAG when it really means just CONFIG_CMD_DIAG. There is no CMD_POST. Clear this mess up some. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-05include/configs: Use new CONFIG_CMD_* in various t* and u* named board ↵Jon Loeliger
config files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2004-12-19Renamed UC100 => uc100LABEL_2004_12_19_1100wdenk
