path: root/include/configs/twister.h
2017-01-28arm: Clean up MACH_TYPE_xxx usage after re-sync of mach-typesTom Rini
With the latest mach-types values we have many instances where we no longer need to define a value and a few cases where the name (but not value) have changed slightly. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2014-01-07ARM: twister: add missing gpio clock initJeroen Hofstee
Commit f33b9bd3984fb11e1d8566a866adc5957b1e1c9d breaks boards which do not explicitly enable the gpio clocks. This causes the twister spl to hang, since it uses the no longer enabled gpio 55. Add CONFIG_OMAP3_GPIO_2 to unbrick the board. Cc: Stefano Babic <sbabic@denx.de> Cc: Tapani Utriainen <tapani@technexion.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Stefano Babic <sbabic@denx.de>
2013-03-01OMAP3: drop CONFIG_SPL_OS_BOOT_KEY and use local defineStefano Babic
CONFIG_SPL_OS_BOOT_KEY is used only in board files. It is not required to have a general CONFIG_ option. Rename it and define it in board directory. Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2012-03-27OMAP3: twister: add support to boot Linux from SPLStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> CC: Wolfgang Denk <wd@denx.de> CC: Simon Schwarz <simonschwarzcor@gmail.com>
2011-12-24ARM: omap3: add support to Technexion twister boardStefano Babic
The twister board is a development board using the TAM3517 SOM. Support for NAND, 2 Ethernet (EMAC and SMC911), USB (EHCI_OMAP). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tapani Utrianen <tapani@technexion.com> CC: Tom Rini <tom.rini@gmail.com> CC: Sandeep Paulraj <s-paulraj@ti.com>
