path: root/include/configs/tuxx1.h
2015-11-18powerpc/83xx: add support for kmtepr2 boardChristoph Dietrich
This board is similar to TUXX1, but it has differend FPGAs. Signed-off-by: Christoph Dietrich <christoph.dietrich@keymile.com> Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2013-02-15powerpc/83xx/km: add support for kmopti2 boardHolger Brunck
This board is similar to TUXX1 but it has a different sized second FPGA. Therefore the configuration for the third chipselect is different. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15powerpc/83xx/km: cleanup tuxx1 supportHolger Brunck
This is a preparation for the upcoming kmopti2 board. This board has also a second fpga on board which is different to the tuxx1 target. But we want to use the same header file. So remove the config option KM_DISABLE_APP2 and simply use the board names to distinguish the features. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2012-06-15powerpc/83xx/km: use tuxx1.h for kmsupx5 targetHolger Brunck
This additional header is unneeded, we can use the tuxx1.h for this target. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-01-09powerpc/83xx/km: add support for 8321 based tuge1 boardHolger Brunck
This board is similar to our tuxx1 target. But on this board there is only one application specific chip select configured. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-01-09powerpc/83xx/km: merge tuxa and tuda1 boards to tuxx1Holger Brunck
These boards are from a u-boot point of view identical. So collect the two headerfiles to one, to decrease maintenance. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
