path: root/include/configs/tuge1.h
2019-05-21keymile: Factor out common includes againMario Six
Not that the Kconfig conversion of a lot of variables is done, we can factor out the common include files for the keymile boards again (which now contain hardly any #ifdef logic at all). Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21keymile: Remove CONFIG_SYS_APP{1, 2}_{BASE, SIZE}Mario Six
CONFIG_SYS_APP1_BASE, CONFIG_SYS_APP2_BASE, CONFIG_SYS_APP1_SIZE, and CONFIG_SYS_APP2_SIZE are no longer used in the keymile config files (they were used for setting values, which were converted to Kconfig earlier in the series). Remove them from the configs and the whitelist. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_SYS_LBC_*Mario Six
Except for one counter example, CONFIG_SYS_LBC_LBCR always has a value of either 0x00040000 or 0x00000000. CONFIG_SYS_LBC_MRTPR always has the value 0x20000000. CONFIG_SYS_LBC_LSDMR_{1,2,4,5} are not set for any mpc83xx board. CONFIG_SYS_LBC_LSRT is set by one board (to 0x32000000). To simplify the configuration files, hardcode the setting of these values for mpc83xx. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_SYS_DDR_SDRAM_BASEMario Six
CONFIG_SYS_DDR_SDRAM_BASE is set to the same value as CONFIG_SYS_SDRAM_BASE on all existing boards. Just use CONFIG_SYS_SDRAM_BASE instead. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_SYS_DDR_BASEMario Six
CONFIG_SYS_DDR_BASE is specific to mpc83xx an is always set to the same value as CONFIG_SYS_SDRAM_BASE. Just use CONFIG_SYS_SDRAM_BASE instead. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_LCRR_* to KconfigMario Six
Migrate the CONFIG_LCRR_* settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate arbiter config to KconfigMario Six
Migrate the arbiter configuration to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_SYS_IMMR to KconfigMario Six
Migrate CONFIG_SYS_IMMR to Kconfig for MPC83xx. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate HID config to KconfigMario Six
Mirate the HID configuration settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_SYS_{BR, OR}*_PRELIM to KconfigMario Six
Migrate the BR/OR settings to Kconfig. These must be known at compile time, so cannot be configured via DT. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Simplify BR,OR linesMario Six
Re-format all BR,OR #define lines into single lines. This makes them harder to read, but accessible to semi-automatic replacement. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Normalize BR/OR option linesMario Six
All BR/OR option lines should have the same layout to make them easier to migrate to Kconfig. This includes using the same option macros everywhere. The normalize the lines, * replace function macros with their results, and * replace hardcoded hex values with standard macros Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate LBLAW_* to KconfigMario Six
The LBLAW_* values determine the window configuration of the memory controller. Hence, they must be known at compile time, and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate BATS config to KconfigMario Six
The BATs (block address translation registers) determine the initial memory window mappings. Hence, they must be known at compile time and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21powerpc: Migrate HIGH_BATS to KconfigMario Six
Migrate the CONFIG_HIGH_BATS variable to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Kconfig: Migrate HRCW to KconfigMario Six
The HRCW (hardware reset configuration word) is a constant that must be hard-coded into the boot loader image. So, it must be available at compile time, and cannot be migrated to the DT mechanism, but has to be kept in Kconfig. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-20keymile: Unroll km/km83xx-common.hMario Six
Simplify the keymile config files once more by unrolling the km/km83xx-common.h, and resolve the #ifdef logic as needed. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-20keymile: Make distinct kmsupx5, tuge1, kmopti2, and kmtepr2 configsMario Six
The kmsupx5, tuge1, kmopti2, and kmtepr2 boards all build from the same include config file with lots of #ifdef logic. To ease Kconfig migration, create new config include files for these boards, and resolve the #ifdef logic as needed. Signed-off-by: Mario Six <mario.six@gdsys.cc>
