path: root/include/configs/tt01.h
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-02-27tt01: fix hush parser config, add release configHelmut Raiger
Add PREBOOT, SILENT_CONSOLE and DEVICE_NULLDEV for release build. Fixed bug in CONFIG_SYS_HUSH_PARSER define. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2012-02-27tt01: add video supportHelmut Raiger
The video setup for the Epson display is provided. Addtionally some extra info is displayed next to the Linux logo. Make get_cpu_rev() publicly available (added to sys_proto.h). Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2012-02-27tt01: fix environment sizeHelmut Raiger
size of environment must match erasable block size in the flash. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2012-02-12tt01: add MMC supportHelmut Raiger
board_mmc_init() initializes the pins of SDHC1 and turns on V_MMC1 of the PMIC. Config adds support for EXT2 and FAT. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2012-01-26NAND: Remove additional (CONFIG_SYS)_NAND_MAX_CHIPSScott Wood
NAND_MAX_CHIPS has been replaced by CONFIG_SYS_NAND_MAX_CHIPS, and the latter defaults to 1. Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-12-06MX: serial_mxc: cleanup removing nasty #ifdefStefano Babic
The serial driver for iMX SOCs is continuosly changed if a new SOC or not yet used port is used. CONFIG_SYS_<SOC>_<UART Port> defines were used only to find the base address for the selected UART. Instead of that, move the base address to the board configuration file and drop all #ifdef from driver. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Marek Vasut <marek.vasut@gmail.com> CC: Wolfgang Denk <wd@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> CC: Helmut Raiger <helmut.raiger@hale.at> CC: John Rigby <jcrigby@gmail.com> CC: Matthias Weisser <weisserm@arcor.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-11-03mx31: Add board support for HALE TT-01Helmut Raiger
This adds basic board support for TT-01 based on the Bluetechnix i.MX31 SOM. Currently only NOR-Flash boot is implemented. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
