path: root/include/configs/tricorder.h
2013-08-15ARM: OMAP: Add CONFIG_OMAP_COMMONLokesh Vutla
Adding a new CONFIG_OMAP_COMMON which is included by all boards that needs to build cpu/armv7/omap-common folder. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-04-08tricorder: enable hw assisted BCH8 in SPL and u-bootAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com> Cc: Thomas Weber <weber@corscience.de> Cc: Ilya Yanok <ilya.yanok@cogentembedded.com> Cc: Scott Wood <scottwood@freescale.com>
2013-03-04ubifs: Allow ubifsmount volume reference by numberJoe Hershberger
UBI can mount volumes by name or number The current code forces you to name the volume by prepending every name with "ubi:". >From fs/ubifs/super.c * There are several ways to specify UBI volumes when mounting UBIFS: * o ubiX_Y - UBI device number X, volume Y; * o ubiY - UBI device number 0, volume Y; * o ubiX:NAME - mount UBI device X, volume with name NAME; * o ubi:NAME - mount UBI device 0, volume with name NAME. Now any name passed in any of the above forms are allowed. Also update the configs that referenced ubifsmount. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-01-29Remove unused CONFIG_SYS_I2C_BUS[_SELECT]Michael Jones
"CONFIG_SYS_I2C_BUS" and "CONFIG_SYS_I2C_BUS_SELECT" don't appear anywhere outside of config files. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-01-08Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
This required manual merging drivers/mtd/nand/Makefile and adding am335x_evm support for CONFIG_SPL_NAND_DRIVERS
2012-12-10OMAP3: Remove unused PHYS_SDRAM_1_SIZEThomas Weber
Remove the unused PHYS_SDRAM_1_SIZE from OMAP3 config files. Signed-off-by: Thomas Weber <thomas@tomweber.eu>
2012-11-26spl/nand: introduce CONFIG_SPL_NAND_DRIVERS, _BASE, and _ECC.Scott Wood
Some small SPLs do not use nand_base.c, and a subset of those also require a special driver. Some SPLs need software ECC but others can't fit it. All existing boards that specify CONFIG_SPL_NAND_SUPPORT have these symbols added to preserve existing behavior. Signed-off-by: Scott Wood <scottwood@freescale.com> -- v2: use positive logic for including bits of NAND, rather than a MINIMAL symbol that excludes things.
2012-10-23configs: Fix usage of mmc rescanAndrew Bradford
Fix usage of 'mmc rescan' by many configs. Proper use is 'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan the device. 'mmc rescan' itself does not take any arguments. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-09-27SPL: Move the omap SPL framework to common/splTom Rini
Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL framework, enable on all of the previously using boards. We move the spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave the NAND one in-place as we plan to replace it later in this series. We use common/spl to avoid linker problems with respect to merging constant strings in objects. Otherwise all strings in common/ will be linked in and kept which grows SPL in size too much. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-05-15ARM: omap3: Add CONFIG_SPL_BOARD_INIT for CONFIG_SPL_MMC_SUPPORTTom Rini
As originally reported against beagleboard we currently have the following error message reported in SPL: U-Boot SPL 2012.04-00020-gb8310b9-dirty (Apr 25 2012 - 18:49:57) Texas Instruments Revision detection unimplemented OMAP SD/MMC: 0 timed out in wait_for_bb: I2C_STAT=1000 reading u-boot.img .... The reason for above message is that when booting from MMC, I2C needs to be initialized to talk with the TWL4030. On OMAP3 I2C is only initalized in SPL if CONFIG_SPL_BOARD_INIT is set. Cc: Thomas Weber <weber@corscience.de> Cc: Steve Sakoman <sakoman@gmail.com> Original patch for Beagleboard is: Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com> Extended to cover all other boards: Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15ARM: omap3: Set SPL stack size to 8KB, image to 54KB.Tom Rini
With older toolchains it is possible to not fit entirely into the 45KB that we had assigned to SPL. Adjust to allow for 8KB of stack (which should be more than required) and 54KB of text/data. Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Thomas Weber <weber@corscience.de> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Vaibhav Hiremath <hvaibhav@ti.com>
2012-04-16tricorder: Load kernel from ubifsBernhard Walle
Signed-off-by: Bernhard Walle <walle@corscience.de>
2012-04-16tricorder: Add UBIFSBernhard Walle
Since kernel should be in a ubifs partition, we need UBIFS. The greater malloc size is needed for UBIFS. Signed-off-by: Bernhard Walle <walle@corscience.de> Squashed two commits (UBIFS enabled and malloc size increased) into one. Signed-off-by: Thomas Weber <weber@corscience.de>
2012-02-27OMAP3: Remove unused CONFIG_SYS_NAND_ECCSTEPS/TOTALThomas Weber
2012-02-27Tricorder: Switch env to generic mmc driverThomas Weber
Because the tricorder uses the CONFIG_OMAP_HSMMC the initialization command is mmc rescan and not mmc init. Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-02-12OMAP3: Add Corscience Tricorder boardThomas Weber
Tricorder is a board which is very similar to the Devkit8000. It is designed as a base platform for further medical devices. www.corscience.de/en/medical-engineering/products/multiparameter/mp10-board.html Signed-off-by: Thomas Weber <weber@corscience.de>
