CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
Migrate the option CONFIG_SPL_FRAMEWORK and make this gate most of the
current set of options we have in Kconfig. We will need to have some
options available for SPL and !SPL_FRAMEWORK so this is important. In a
few cases we re-order existing options so that we have less escapes from
the SPL_FRAMEWORK guard.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
CONFIG_SYS_OMAP24_I2C_SLAVE
CONFIG_SYS_OMAP24_I2C_SPEED
Reviewed-by: Paul Kocialkowski <contact@paulk.fr>
Freescale (NXP) boards have lots of defconfig files per board.
I used "imply PANIC_HANG" for them.
Reviewed-by: York Sun <york.sun@nxp.com>
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
CONFIG_NAND_MXC
CONFIG_NAND_OMAP_GPMC
CONFIG_NAND_OMAP_GPMC_PREFETCH
CONFIG_NAND_OMAP_ELM
CONFIG_SPL_NAND_AM33XX_BCH
CONFIG_SPL_NAND_SIMPLE
CONFIG_SYS_NAND_BUSWIDTH_16BIT
[trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues,
add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT]
CONFIG_EMIF4
CONFIG_SDRC
Reviewed-by: Stefano Babic <sbabic@denx.de>
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be
equal to CONFIG_SYS_CBSIZE in numerous configuration files.
We remove such definitions in two situations:
- CONFIG_SYS_CBSIZE is otherwise not defined in the board
configuration file, which means the default value of
CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value
of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is
larger.
- CONFIG_SYS_CBSIZE is defined in the board configuration file, but
to a value equal or less than 512. In this case, the default value
of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it
is equal or larger.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Now that include/config_fallbacks.h define a sane fallback for
CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all
configurations that were using the default value.
Now that the fallback value of CONFIG_SYS_PBSIZE in
include/config_fallbacks.h has been adjusted, remove its definition
from a large number of board configuration files.
CONFIG_BCH
With the hierarchical defaults set up, we remove these from the header
files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits
the changes.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_SYS_I2C_OMAP24XX
The driver is for all boards 24XX and up, so let's eliminate the
extra option called CONFIG_SYS_I2C_OMAP34XX since the driver checks
for CONFIG_OMAP34XX we don't need CONFIG_SYS_I2C_OMAP34XX.
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
CONFIG_CMD_JFFS2
CONFIG_CMD_EEPROM
CONFIG_CMD_EEPROM_LAYOUT
CONFIG_EEPROM_LAYOUT_HELP_STRING
[trini: Rework Kconfig logic slightly, define EEPROM location on TI eval
platforms]
CONFIG_SPL_BOARD_INIT
Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
[trini: Update the Kconfig logic]
The symbols CONFIG_OMAP3_GPIO_X control if we enable the clocks for a
given GPIO bank in U-Boot. select the required banks for each target.
In some cases we need to also migrate from CONFIG_USB_EHCI (deprecated,
in include/configs/) to CONFIG_USB_EHCI_HCD as we only require the GPIO
bank to be enabled if USB is also enabled.
This driver is used often enough such that we want to have this enabled
by default on any ARCH_OMAP2PLUS board, and this only compiles on
ARCH_OMAP2PLUS due to required defines, so mark that as the depends.
In the two cases in the code where we use CONFIG_OMAP as a useful test
currently we can make use of CONFIG_ARCH_OMAP2PLUS instead. With that
changed we can drop all defines of CONFIG_OMAP. While in here,
CONFIG_OMAP3430 is only defined and then never used, so drop.
With the addition of Kconfig now having CONFIG_TWL4030_POWER and
with that being the default when OMAP34XX is selected, this
is no longer needed in include/configs and can be removed from the
whitelist.
This has only been tested on logic PD DM3730 using ti_omap3_common.h
Move this in to Kconfig with a default of 115200.
[trini: Run moveconfig.py, reword commit slightly]
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for
various reasons. We also have cases where we only build SPL in Thumb2 mode due
to size constraints and wish to build the rest of the system in ARM mode. So
in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to
control if we build everything or just SPL (or in theory, just U-Boot) in
Thumb2 mode.
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
This moves all of the current ARM errata from various header files and in to
Kconfig. This allows for a minor amount of cleanup as we had some instances
where both a general common header file was enabling errata as well as the
board config. We now just select these once at the higher level in Kconfig
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC.
Let's create an entry for "config GENERIC_MMC" with "default MMC",
then convert all macro defines in headers to Kconfig. Almost all
of the defines will go away.
I see only two exceptions:
configs/blanche_defconfig
configs/sandbox_noblk_defconfig
They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something
might be wrong with these two boards, so should be checked later.
Anyway, this is the output of the moveconfig tool.
[1] create a config entry in drivers/mmc/Kconfig
[2] tools/moveconfig.py -r HEAD GENERIC_MMC
[3] manual clean-up of garbage comments in doc/README.* and
include/configs/*.h
This reverts commit 70b26cd057f42c7126088b49d4285955c8a00eae.
This is not a strict revert as it is easier to fix
board/atmark-techno/armadillo-800eva/armadillo-800eva.c to now the
correct name (same value) than to revert that change too.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
Move all of the status LED feature to drivers/led/Kconfig.
The LED status definitions were moved from the board configuration
TBD: Move all of the definitions in the include/status_led.h to the
relevant board's defconfig files.
Tested boards: CL-SOM-AM57x, CM-T335
Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
Before we can sync with the latest mach-types.h file from the Linux
Kernel we need to remove some instances of MACH_TYPE_xxx from our
sources. As these values have been removed from the canonical upstream
source we should not be using them either, so drop.
Cc: Tom Warren <twarren@nvidia.com>
Cc: Lucas Stach <dev@lynxeye.de>
Cc: Luka Perkov <luka@openwrt.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Thomas Weber <weber@corscience.de>
Cc: Lucile Quirion <lucile.quirion@savoirfairelinux.com>
Cc: Matthias Weisser <weisserm@arcor.de>
Cc: Suriyan Ramasami <suriyan.r@gmail.com>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Nick Thompson <nick.thompson@gefanuc.com>
Cc: Erik van Luijk <evanluijk@interact.nl>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Move (and rename) the following CONFIG options to Kconfig:
CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI)
CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS)
CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC)
CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS)
CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA)
CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI)
They are the same option names as used in Linux.
[1] Rename the options with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e '
s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g
s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g
s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g
s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g
s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g
s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g
[2] Commit the changes
[3] Create entries in driver/mmc/Kconfig.
(copied from Linux)
[4] Move the options with the following command
tools/moveconfig.py -y -r HEAD \
MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI
[5] Sort and align drivers/mmc/Makefile for readability
Commit 7a777f6d6f35 ("mmc: Add generic Kconfig option") created
a Kconfig entry for this option without any actual moves, then
commit 44c798799f66 ("sunxi: Use Kconfig CONFIG_MMC") moved
instances only for SUNXI.
We generally do not like such partial moves. This kind of work
is automated by tools/moveconfig.py, so it is pretty easy to
complete this move.
I am adding "default ARM || PPC || SANDBOX" (suggested by Tom).
This shortens the configs and will ease new board porting.
[1] Edit Kconfig (remove the "depends on", add the "default",
copy the prompt and help message from Linux)
[2] Run 'tools/moveconfig.py -y -s -r HEAD MMC'
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
With the move to arch/arm/mach-omap2 there are now very few uses of
CONFIG_OMAP_COMMON and further they can all be replaced with
CONFIG_ARCH_OMAP2, so do so.
This moves what was in arch/arm/cpu/armv7/omap-common in to
arch/arm/mach-omap2 and moves
arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2
as subdirectories. All refernces to the former locations are updated to
the current locations. For the logic to decide what our outputs are,
consolidate the tests into a single config.mk rather than including 4.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Fix sniper and kc1 migration]
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
Reviewed-by: Jagan Teki <jteki@openedev.com>
[trini: Re-migrate, update common/console.c logic]
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
Move this option to Kconfig and tidy up existing uses.
