path: root/include/configs/trats2.h
2013-12-31board:trats2: fix default partitions and mmc envPiotr Wilczek
This patch add uuid disk to defualt partions necessary to restore gpt partitions and fixes mmcdev environmental variable. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: board/samsung/trats2/trats2.c include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2013-12-05driver:i2c:s3c24x0: adapt driver to new i2cPiotr Wilczek
This patch adapts the s3c24x0 driver to the new i2c framework. Config file is modified for all the boards that use the driver. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Heiko Schocher <hs@denx.de> CC: Inderpal Singh <inderpal.singh@linaro.org> CC: David Müller <d.mueller@elsoft.ch> CC: Chander Kashyap <k.chander@samsung.com> CC: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Reviewed-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
2013-12-03board: trats2: update Tizen partition definitionsPiotr Wilczek
This patch updates Tizen partions layout. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-03board: trats2: fix environmental variablesPiotr Wilczek
In this patch variable names are used instead of hardcoded names Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-03board: trats2: remove unused defines from config filePiotr Wilczek
2013-12-02trats2: enable dfu and thor protocol for Tizen downloadPiotr Wilczek
Trats2 config is updated to support DFU mode. Malloc pool must be increased for DFU buffer allocation. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-02trats2: enable ums support on Trats2Piotr Wilczek
This patch adds support for USB and enables 'ums' command on Trats2 board. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-09-25samsung: trats2: add support for new board Trats2Piotr Wilczek
This patch add support for a new Samsung board Trats2. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
