First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
It is quite confusing that CONFIG_SYS_I2C selects the legacy I2C and
CONFIG_DM_I2C selects the current I2C. The deadline to migrate I2C is less
than a year away.
Also we want to have a CONFIG_I2C for U-Boot proper just like we have
CONFIG_SPL_I2C for SPL, so we can simplify the Makefile rules.
Rename this symbol so it is clear it is going away.
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
Fixes compilation for WRU4 board.
Signed-off-by: Michael Krummsdorf <michael.krummsdorf@ew.tq-group.com>
move WATCHDOG_TIMEOUT_MSECS to Kconfig and fix
all board defconfigs.
Acked-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Martyn Welch <martyn.welch@collabora.com>
Move this option to Kconfig and tidy up the config file of eight
boards which use it.
Signed-off-by: Xiaoliang Yang <xiaoliang.yang_1@nxp.com>
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Migrate the users of CONFIG_SYS_BOOTCOUNT_ADDR to Kconfig. We can
provide a default for BOOTCOUNT_AM33XX as that's a specific part of the
RTC in use. We can also provide a default for ARCH_LS1043A and
ARCH_LS1021A as they had been previously calculated and their symbols
are in Kconfig. In the case of other QE-enabled platforms, they are not
so we must update the relevant defconfig files. The previous default
only applied in some cases, even on a specific SoC family.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Alex Kiernan <alex.kiernan@gmail.com>
CONFIG_BOOTCOUNT_LIMIT
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
There is some inconsistency between uses of CONFIG_RTC_DS13xx and
CONFIG_SYS_RTC_DS13xx. Address this by dropping the "SYS" from
these variables.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
This subsystem is quite old. It has been replaced with a driver-model
version (UCLASS_THERMAL). Boards are free to convert to that if required,
but here is a removal patch that could be applied in the meantime.
[trini: default y if DM_RTC, re-sync]
Move all of the status LED feature to drivers/led/Kconfig.
The LED status definitions were moved from the board configuration
files to the defconfig files.
TBD: Move all of the definitions in the include/status_led.h to the
relevant board's defconfig files.
Tested boards: CL-SOM-AM57x, CM-T335
Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
common/Kconfig
configs/dms-ba16_defconfig
- Add DEFAULT_FDT_FILE kconfig entry
- Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
This is not really a config. Rename it to avoid confusion.
Reviewed-by: Jagan Teki <jteki@openedev.com>
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
This patch removes the SPI support from the WRU-IV baseboard as its
not used at all.
Cc: Clemens Gruber <clemens.gruber@pqgruber.com>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Tested-by: Clemens Gruber <clemens.gruber@pqgruber.com>
This patch adds support for the "OHB System AG" baseboard
with is equipped with the TQMa6S SoM.
