path: root/include/configs/tqma6_wru4.h
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-17configs: tqma6x_mba6x: update default configs for device modelMichael Krummsdorf
Fixes compilation for WRU4 board. Signed-off-by: Michael Krummsdorf <michael.krummsdorf@ew.tq-group.com>
2019-10-08watchdog: move WATCHDOG_TIMEOUT_MSECS to KconfigHeiko Schocher
move WATCHDOG_TIMEOUT_MSECS to Kconfig and fix all board defconfigs. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Martyn Welch <martyn.welch@collabora.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-10-22Kconfig: Convert CONFIG_IMX_WATCHDOG to KconfigXiaoliang Yang
Move this option to Kconfig and tidy up the config file of eight boards which use it. Signed-off-by: Xiaoliang Yang <xiaoliang.yang_1@nxp.com>
2018-02-25bootcount: Migrate CONFIG_SYS_BOOTCOUNT_ADDRTom Rini
Migrate the users of CONFIG_SYS_BOOTCOUNT_ADDR to Kconfig. We can provide a default for BOOTCOUNT_AM33XX as that's a specific part of the RTC in use. We can also provide a default for ARCH_LS1043A and ARCH_LS1021A as they had been previously calculated and their symbols are in Kconfig. In the case of other QE-enabled platforms, they are not so we must update the relevant defconfig files. The previous default only applied in some cases, even on a specific SoC family. Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Alex Kiernan <alex.kiernan@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2018-02-13spi: Migrate CONFIG_MXC_SPI to KconfigTuomas Tynkkynen
2017-06-09rtc: ds1337: drop "SYS" from config variablesChris Packham
There is some inconsistency between uses of CONFIG_RTC_DS13xx and CONFIG_SYS_RTC_DS13xx. Address this by dropping the "SYS" from these variables. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-22Drop digital thermometer and thermostat (DTT) driversSimon Glass
This subsystem is quite old. It has been replaced with a driver-model version (UCLASS_THERMAL). Boards are free to convert to that if required, but here is a removal patch that could be applied in the meantime. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2016-10-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: common/Kconfig configs/dms-ba16_defconfig
2016-10-26config: Move CONFIG_DEFAULT_FDT_FILE to defconfigsJagan Teki
- Add DEFAULT_FDT_FILE kconfig entry - Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-23config: Drop CONFIG_CONSOLE_DEVSimon Glass
This is not really a config. Rename it to avoid confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-02arm: mx6: Remove SPI support from WRU-IV baseboardStefan Roese
This patch removes the SPI support from the WRU-IV baseboard as its not used at all. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Clemens Gruber <clemens.gruber@pqgruber.com> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Stefano Babic <sbabic@denx.de> Tested-by: Clemens Gruber <clemens.gruber@pqgruber.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-07-26arm: mx6: tqma6: Add WRU-IV baseboard for the TQMa6 SoMStefan Roese
This patch adds support for the "OHB System AG" baseboard with is equipped with the TQMa6S SoM. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Stefano Babic <sbabic@denx.de>
