path: root/include/configs/tqma6.h
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Drop digital thermometer and thermostat (DTT) driversSimon Glass
This subsystem is quite old. It has been replaced with a driver-model version (UCLASS_THERMAL). Boards are free to convert to that if required, but here is a removal patch that could be applied in the meantime. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-15Kconfig: USB: Migrate existing USB_EHCI_xxx optionsTom Rini
The following options are migrated over fully now: - USB_EHCI_ATMEL - USB_EHCI_MARVELL - USB_EHCI_MX6 - USB_EHCI_MX7 - USB_EHCI_MSM - USB_EHCI_ZYNQ - USB_EHCI_GENERIC This also requires fixing the depends on USB_EHCI_MARVELL as it's used by Orion5X and Kirkwood as well. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-17arm: imx6: tqma6: add support for TQMa6DL variantMarkus Niebel
This adds support for TQMa6DL using i.MX6DL and 1GiB DRAM Since The module will use the same devicetree, we patch the ram size in ft_board_setup. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2017-03-17arm: imx6: tqma6: use CONFIG_TQM6x for SOM specific settingsMarkus Niebel
We have a Kconfig name for the module types. Let's Use it. Some feature selections and configurations are based on the module. Module selection selects the CPU type. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2017-02-19tqma6: [cosmetic] sanitize environment definesMarkus Niebel
2017-02-19tqma6: fix rounding in envMarkus Niebel
need to add before div in mmc update scripts. Otherwise we could write one block more ba acident Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2017-02-19mx6: tqma6: add rootfsmode environment for mmc / sdMarkus Niebel
2017-02-19mx6: tqma6: fix typo in envMarkus Niebel
there was a double bracketed var ref. fix this. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2017-02-19imx6: tqma6: rely on default setting for tftp and nfsMarkus Niebel
Playing with USB-to-Ethernet dongles it turns out, that these will not work with special settings Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2017-02-19arm: imx6: tqma6: add configurable CMA sizeMarkus Niebel
depending on the use case different CMA sizes are needed for linux. Add env var to enable passing CMA size via kernel command line Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2016-10-23config: Drop CONFIG_CONSOLE_DEVSimon Glass
This is not really a config. Rename it to avoid confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2016-05-17ARM: mx6: Enable MMC and SATA extfs boot supportMarek Vasut
Enable support for booting U-Boot image from ext filesystem when either SD/MMC or SATA support is compiled into the SPL. This will allow easy transition from loading U-Boot image from ad-hoc offset on the card to loading U-Boot image from the filesystem. VFAT support is intently not enabled. The boot order is tweaked so that raw is tested first and if the raw has no signature, FS boot is attempted. To install just the SPL on i.MX6 board, perform the following operation $ dd if=SPL of=/dev/sdX seek=2 bs=512 To install the U-Boot image, copy u-boot.img to the first partition of the SD/MMC/SATA drive. The partition must be formated to extfs. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Peng Fan <van.freenix@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@konsulko.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-02I2C: mxc_i2c: make I2C1 and I2C2 optionalAlbert ARIBAUD \\(3ADEV\\)
The driver assumed that I2C1 and I2C2 were always enabled, and if they were not, then an asynchronous abort was (silently) raised, to be caught much later on in the Linux kernel. Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4 are. To make the change binary-invariant, declare I2C1 and I2C2 in every include/configs/ file which defines CONFIG_SYS_I2C_MXC. Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed (CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE) config options. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-07-26arm: mx6: tqma6: Add WRU-IV baseboard for the TQMa6 SoMStefan Roese
This patch adds support for the "OHB System AG" baseboard with is equipped with the TQMa6S SoM. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Stefano Babic <sbabic@denx.de>
2015-07-10imx6: standardise OCOTP and fuse config to mx6_commonPeter Robinson
According to README.mxc_ocotp the OCOTP is a stanard i.MX6 SoC feature so centralise the config in mx6_common.h so functionality is standard across all boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-07-03Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Conflicts: configs/tbs2910_defconfig configs/tqma6q_mba6_mmc_defconfig configs/tqma6q_mba6_spi_defconfig configs/tqma6s_mba6_mmc_defconfig configs/tqma6s_mba6_spi_defconfig include/configs/mx6_common.h Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-27arm: imx6: tqma6: add kconfig to board headerMarkus Niebel
this is needed later to have Kconfig generated stuff as define. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2015-06-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-06-08mx6_common: Fix LOADADDR and SYS_TEXT_BASE for MX6SL and MX6SXFabio Estevam
Commit 8183058188cd2d942 ("imx6: centralise common boot options in mx6_common.h") broke boot on mx6sl and mx6sx by assuming that all mx6 SoCs use the same LOADADDR/SYS_TEXT_BASE range, which is not correct. DDR on mx6sx/mx6sl starts at 0x80000000. Adjust LOADADDR/SYS_TEXT_BASE to the proper values for mx6sx/mx6sl, so that these SoCs can boot again. Also, TQMA6 requires a custom CONFIG_SYS_TEXT_BASE value, so move its setting prior to the inclusion of mx6_common.h. Signed-off-by: Fabio Estevam <fabio.estevam at freescale.com>
2015-06-01arm: mx6: tqma6: use default CONFIG_SYS_PBSIZEMarkus Niebel
this removes a config entry and uses the default value defined in config_fallbacks.h. This implements the same behaviour as a patch series for other i.MX6 boards from Freescale Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2015-05-26mx6: standardise CONFIG_CMD_CACHEPeter Robinson
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: generic MMC config options to mx6_commonPeter Robinson
Move all standard mx6 MMC configs to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: standardise filesystem and boot optionsPeter Robinson
Move all standard filesystem, partition and fdt options to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move generic miscellaneous and overwrite optionsPeter Robinson
Move generic miscellaneous options that are standard across most, if not all, mx6 boards to central mx6_common define to ensure consistent features. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: centralise common boot options in mx6_common.hPeter Robinson
Define common LOADADDR and BOOTDELAY to ensure a consistent experience across mx6 boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move MXC_GPIO define to mx6_common.hPeter Robinson
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
