path: root/include/configs/tplink_wdr4300.h
2018-07-19hush: Remove default CONFIG_SYS_PROMPT_HUSH_PS2 setting from board filesMichal Simek
There is no reason to define default option for this macro which is already done in common/cli_hush.c. 86 #ifndef CONFIG_SYS_PROMPT_HUSH_PS2 87 #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " 88 #endif Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_LZMA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_LZMA Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-24Move CONFIG_SYS_HUSH_PARSER to Kconfig for last 4 boardsMasahiro Yamada
I still see some defines of this config in board headers. Move them to defconfigs (+ renaming to CONFIG_HUSH_PARSER) to complete this migration. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-02mips: wdr4300: Move the CONFIG_USE_PRIVATE_LIBGCC to KconfigMarek Vasut
This fixes the last remaining libgcc warning, where the symbol was defined twice. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-31MIPS: Move cache sizes to KconfigPaul Burton
Move details of the L1 cache line sizes & total sizes into Kconfig, defaulting to 0. A new CONFIG_SYS_CACHE_SIZE_AUTO Kconfig entry is introduced to allow platforms to select auto-detection of cache sizes, and it defaults to being enabled if none of the cache sizes are set by the configuration (ie. sizes are all the default 0), and code is adjusted to #ifdef on that rather than on the definition of the sizes (which will always be defined even if 0). Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-26MIPS: Move CONFIG_SYS_TEXT_BASE to KconfigPaul Burton
Move CONFIG_SYS_TEXT_BASE to Kconfig, and add default values in board Kconfig files matching what was present in their config headers. This will make it cleaner to conditionalise the value for Malta based on 32 vs 64 bit builds. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-21mips: ath79: Add support for TPLink WDR4300Marek Vasut
Add support for the TPLink WDR4300 router, which is based on the AR9344 MIPS 74Kc CPU and has 128 MiB of RAM. The USB is supported on this system as well. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Wills Wang <wills.wang@live.com>
