path: root/include/configs/topic_miami.h
2018-08-06spi: Kconfig: Create ISSI Kconfig entryMichal Simek
Add ISSI to Kconfig to make it selectable via menuconfig. Also convert all current platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-01i2c: Added kconfig support for CONFIG_ZYNQ_I2C0 and CONFIG_ZYNQ_I2C1Vipul Kumar
This patch added Kconfig support for CONFIG_ZYNQ_I2C0 and CONFIG_ZYNQ_I2C1 and enabled it in respective defconfig. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-12topic_miami: Remove CONFIG_CMD_BOOTZ undefFabio Estevam
CONFIG_CMD_BOOTZ option has been converted to defconfig, so there is no need to undefine it in board config file anymore. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-06-20arm: zynq: Move CONFIG_SF_DUAL_FLASH to defconfigMike Looijmans
Move the only use of CONFIG_SF_DUAL_FLASH to defconfig. This makes the associated topic_miamiplus.h header obsolete, so remove that as well. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-05-22Convert CONFIG_CMD_FPGA_LOADBP et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FPGA_LOADBP CONFIG_CMD_FPGA_LOADFS CONFIG_CMD_FPGA_LOADMK CONFIG_CMD_FPGA_LOADP Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_CMD_AES et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_AES CONFIG_AES Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Add select AES to CMD_AES] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-17zynq: Move zynq to clock frameworkStefan Herbrechtsmeier
Move the zynq to clock framework and remove unused functions as well as the CONFIG_ZYNQ_PS_CLK_FREQ configuration. Signed-off-by: Stefan Herbrechtsmeier <stefan.herbrechtsmeier@weidmueller.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-02-10configs/topic_miami.h: Correct kernel_size in default environmentMike Looijmans
The kernel partition in QSPI is 0x440000 large, not 0x400000. Fix this in the environment, otherwise the kernel will fail to boot if it occupies more space. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-15ARM: zynq: Add support for the topic-miami system-on-modules and carrier boardsMike Looijmans
The topic-miami SoMs contain a Zynq xc7z015 or xc7z030 SoC, 1GB DDR3L RAM, 32MB QSPI NOR flash and 256MB NAND flash. The topic-miamiplus SoMs contain a Zynq xc7z035, xc7z045 or xc7z100 SoC, 2x 1GB DDR3L RAM, 64MB dual-parallel QSPI flash, clock sources and a fan controller. The "Florida" carrier boards add SD, USB, ethernet and other interfaces. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
