path: root/include/configs/tnetv107x_evm.h
2010-11-19DaVinci: remove bogus DEF_BOOTM definitionWolfgang Denk
Some boar config files defined DEF_BOOTM but this was not used anywhere in the code. Remove this bogus define. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-08TI: TNETV107X EVM initial supportCyril Chemparathy
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a bunch on on-chip integrated peripherals. This patch adds support for the TNETV107X EVM board. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
