path: root/include/configs/titanium.h
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-08treewide: Convert CONFIG_HOSTNAME to a string optionMario Six
CONFIG_HOSTNAME is defined as a "plain" preprocessor string, but every use is couched by __stringify(...). Hence, convert it to a proper string option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-02-08Convert CONFIG_APBH_DMA et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_APBH_DMA CONFIG_APBH_DMA_BURST CONFIG_APBH_DMA_BURST8 Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Stefan Agner <stefan.agner@toradex.com> [trini: Add in MMC as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08Convert CONFIG_NAND_MXS to KconfigStefan Agner
This converts CONFIG_NAND_MXS to Kconfig. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-08-07configs: Replace deprecated Micrel defines with PHY_MICREL_KSZ90X1Alexandru Gagniuc
These boards will now use the ksz90x1 driver instead of the mess in ksz8xxx. This change is needed before the two drivers can be fully separated. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15Kconfig: USB: Migrate existing USB_EHCI_xxx optionsTom Rini
The following options are migrated over fully now: - USB_EHCI_ATMEL - USB_EHCI_MARVELL - USB_EHCI_MX6 - USB_EHCI_MX7 - USB_EHCI_MSM - USB_EHCI_ZYNQ - USB_EHCI_GENERIC This also requires fixing the depends on USB_EHCI_MARVELL as it's used by Orion5X and Kirkwood as well. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-28arm: Note vendor-required status of certain MACH_TYPE valuesTom Rini
In the cases of some boards, a MACH_TYPE number is used which is either not registered upstream or worse (for functionality) is re-using the number of a different (or reference) platform instead. Make sure we have a comment in these cases. Cc: Albert ARIBAUD <albert.aribaud@3adev.fr> Cc: Walter Schweizer <swwa@users.sourceforge.net> Cc: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2015-10-02I2C: mxc_i2c: make I2C1 and I2C2 optionalAlbert ARIBAUD \\(3ADEV\\)
The driver assumed that I2C1 and I2C2 were always enabled, and if they were not, then an asynchronous abort was (silently) raised, to be caught much later on in the Linux kernel. Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4 are. To make the change binary-invariant, declare I2C1 and I2C2 in every include/configs/ file which defines CONFIG_SYS_I2C_MXC. Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed (CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE) config options. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-05-26mx6: standardise CONFIG_CMD_CACHEPeter Robinson
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: generic MMC config options to mx6_commonPeter Robinson
Move all standard mx6 MMC configs to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: standardise filesystem and boot optionsPeter Robinson
Move all standard filesystem, partition and fdt options to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move generic miscellaneous and overwrite optionsPeter Robinson
Move generic miscellaneous options that are standard across most, if not all, mx6 boards to central mx6_common define to ensure consistent features. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: centralise common boot options in mx6_common.hPeter Robinson
Define common LOADADDR and BOOTDELAY to ensure a consistent experience across mx6 boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move MXC_GPIO define to mx6_common.hPeter Robinson
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move standard ATAG configs to mx6_common.hPeter Robinson
Define the standard ATAG consfigs in mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move generic imx6 options to mx6_common.hPeter Robinson
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move all standard includes to mx6_common.hPeter Robinson
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h, config_cmd_default.h includes are used fairly universally across imx6 boards so include them in mx6_common.h by default. We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-04-23driver/i2c/mxc: Enable I2C bus 3 and 4York Sun
Some SoCs have more than two I2C busses. Instead of adding ifdef to the driver, macros are put into board header file where CONFIG_SYS_I2C_MXC is defined. Signed-off-by: York Sun <yorksun@freescale.com> CC: Heiko Schocher <hs@denx.de>
2013-12-17ARM: mx6: Update non-Freescale boards to include CPU errata.Eric Nelson
The CPU errata expressed in include/configs/mx6_common.h apply to all i.MX6DQ and i.MX6DLS parts. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefan Roese <sr@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-10-17i2c: update config using mxc driver to new subsystemtrem
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
2013-04-22imx: Add titanium board support (i.MX6 based)Stefan Roese
Titanium is a i.MX6 based board from ProjectionDesign / Barco. This patch adds support for this board with the newly introduced NAND support for i.MX6. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
