At this point in the conversion there should be no need to have logic to
disable some symbol during the SPL build as all symbols should have an
SPL counterpart.
The main real changes done here are that we now must make proper use of
CONFIG_IS_ENABLED(DM_SERIAL) rather than many of the odd tricks we
developed prior to CONFIG_IS_ENABLED() being available.
Perform a simple rename of CONFIG_EXTRA_ENV_SETTINGS to CFG_EXTRA_ENV_SETTINGS
CONFIG_TPS6586X_POWER
CONFIG_TWL6030_POWER
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS namespace do
not easily transition to Kconfig. In many cases they likely should come
from the device tree instead. Move these out of CONFIG namespace and in
to CFG namespace.
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_NS16550
namespace do not easily transition to Kconfig. In many cases they likely
should come from the device tree instead. Move these out of CONFIG
namespace and in to CFG namespace.
CONFIG_SPL_NS16550_MIN_FUNCTIONS
CONFIG_SYS_NS16550_MEM32
CONFIG_SYS_NS16550_PORT_MAPPED
CONFIG_SYS_NS16550_REG_SIZE
CONFIG_SYS_NS16550_SERIAL
To do this we also introduce CONFIG_SPL_SYS_NS16550_SERIAL so that
platforms can enable the legacy driver here for SPL.
This converts CONFIG_SYS_L2_PL310 to Kconfig.
For omap2 and mvebu the 'select SYS_L2_PL310' locations were
determined using ./tools/moveconfig -i CONFIG_SYS_L2_PL310.
For mx6 I manually chose ARCH_MX6 as 'select' location. The
correctness has been verified using
$ ./tools/moveconfig.py -f ARCH_MX6 ~SYS_L2_PL310 ~SYS_L2CACHE_OFF
0 matches
That means whenever an ARCH_MX6 board had SYS_L2_PL310 disabled, this
was correctly reflected in SYS_L2CACHE_OFF. Thus it's safe to insert
the 'select' statement under ARCH_MX6.
Signed-off-by: Philip Oberfichtner <pro@denx.de>
CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS
CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION
CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS
With the exception of how PowerPC handles SPL and TPL (which has its own
issues), we cannot safely hide options under CONFIG_SPL_BUILD. Largely
remove the places that have this test today.
CONFIG_SYS_SPL_ARGS_ADDR
In doing so, we also consistently use this variable for SPL_OS_BOOT and
not CONFIG_SYS_FDT_BASE in some cases.
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
It is quite confusing that CONFIG_SYS_I2C selects the legacy I2C and
CONFIG_DM_I2C selects the current I2C. The deadline to migrate I2C is less
than a year away.
Also we want to have a CONFIG_I2C for U-Boot proper just like we have
CONFIG_SPL_I2C for SPL, so we can simplify the Makefile rules.
Rename this symbol so it is clear it is going away.
The usbtty functionality is not currently used on these two platforms,
disable it.
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Link: https://lore.kernel.org/r/20210708014348.4010-1-trini@konsulko.com
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
CONFIG_CONS_INDEX
We have existing entries for this option in a number of places, with
different guards on them. They're also sometimes used for things not
directly inside of the serial driver. First, introduce a new symbol to
guard the use of CONFIG_CONS_INDEX, so that in the case where we don't
need this for the serial driver, but for some other use, we can still do
it. Next, consolidate all of these into the single entry in
drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that
we can imply a correct value here to make the defconfig side of this
smaller.
[trini: Rework a lot of the logic here, such that I took authorship from
Adam, but kept his S-o-B line]
CONFIG_USB_MUSB_HCD
CONFIG_USB_MUSB_UDC
CONFIG_USB_DAVINCI
CONFIG_USB_OMAP3
CONFIG_USB_DA8XX
CONFIG_USB_AM35X
We first introduce CONFIG_USE_BOOTCOMMAND, similar to
CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most
CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex
scheme around this usage, and these have been defered for the moment so
that platform maintainers can work on a migration plan.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
CONFIG_NAND_MXC
CONFIG_NAND_OMAP_GPMC
CONFIG_NAND_OMAP_GPMC_PREFETCH
CONFIG_NAND_OMAP_ELM
CONFIG_SPL_NAND_AM33XX_BCH
CONFIG_SPL_NAND_SIMPLE
CONFIG_SYS_NAND_BUSWIDTH_16BIT
[trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues,
add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT]
With the hierarchical defaults set up, we remove these from the header
files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits
the changes.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_SYS_I2C_OMAP24XX
While there are a few different OMAP4 SoCs, today we always set
CONFIG_OMAP4430 and CONFIG_OMAP44XX. Convert the few test of
CONFIG_OMAP4430 to CONFIG_OMAP44XX.
Cc: Paul Kocialkowski <contact@paulk.fr>
Introduce include/environment/ti/mmc.h that
consolidates environment variable definitions
for various TI boards that support MMC/SD.
This allows reuse of same environment variables
on non-ARMv7 TI platforms like OMAP-L138 for
example.
While at it, move DFU-related environment variable
includes to only non-SPL builds for AM335x and
AM437x since they are not really used for SPL
today.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for
various reasons. We also have cases where we only build SPL in Thumb2 mode due
to size constraints and wish to build the rest of the system in ARM mode. So
in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to
control if we build everything or just SPL (or in theory, just U-Boot) in
Thumb2 mode.
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
FIT is a new image format which is a Tree like structure and gives more
flexibility in handling of various images. Mainly used for unification of
multiple images in a single blob and provide security information for each
image.
U-Boot already has support for loading such images, so adding the environment
support to load FIT image on all TI platforms.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Support for loading images from mmc is duplicated in all TI platforms.
Add this information to DEFAULT_MMC_TI_ARGS so that it can be reused
This moves what was in arch/arm/cpu/armv7/omap-common in to
arch/arm/mach-omap2 and moves
arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2
as subdirectories. All refernces to the former locations are updated to
the current locations. For the logic to decide what our outputs are,
consolidate the tests into a single config.mk rather than including 4.
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
Move this option to Kconfig and tidy up existing uses. Also add a function
comment to the header file.
On all TI platforms the ROM defines a "downloaded image" area at or near
the start of SRAM which is followed by a reserved area. As it is at
best bad form and at worst possibly harmful in corner cases to write in
this reserved area, we stop doing that by adding in the define
NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image
area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this.
At current we define the end of scratch space at 0x228 bytes past the
start of scratch space this this gives us a lot of room to grow. As
these scratch uses are non-optional today, all targets are modified to
respect this boundary.
Tested on OMAP4 Pandaboard, OMAP3 Beagle xM
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Thomas Weber <weber@corscience.de>
Cc: Hannes Schmelzer <oe5hpm@oevsv.at>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Sam Protsenko <semen.protsenko@linaro.org>
Cc: Samuel Egli <samuel.egli@siemens.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Cc: Ben Whitten <ben.whitten@gmail.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Cc: "B, Ravi" <ravibabu@ti.com>
Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Ash Charles <ashcharles@gmail.com>
Cc: "Kipisz, Steven" <s-kipisz2@ti.com>
Cc: Daniel Allred <d-allred@ti.com>
Tested-by: Lokesh Vutla <lokeshvutla@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Tested-by: Ladislav Michl <ladis@linux-mips.org>
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all
cases we are mirroring the values used by the Linux Kernel here. Also,
so long as (and in this case, it is true) we implement flushes in hunks
that are no larger than the smallest implementation (and given that we
mirror the Linux Kernel, again we are fine) it is OK to align higher.
The biggest changes here are that we always use 64 bytes for CPU_V7 even
if for example the underlying core is only 32 bytes (this mirrors
Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the
Linux Kernel) as we do not need multi-platform support (to this degree)
and only the Cavium ThunderX 88xx series has a use for such large
alignment.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Stefan Agner <stefan.agner@toradex.com>
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Paul Kocialkowski <contact@paulk.fr>
Acked-by: "Pali Rohár" <pali.rohar@gmail.com>
Cc: Grazvydas Ignotas <notasas@gmail.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Robert Baldyga <r.baldyga@samsung.com>
Cc: David Feng <fenghua@phytium.com.cn>
Cc: Alison Wang <b18965@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com>
Cc: Mingkai Hu <mingkai.hu@nxp.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Cc: Aneesh Bansal <aneesh.bansal@freescale.com>
Cc: Saksham Jain <saksham.jain@nxp.com>
Cc: Qianyu Gong <qianyu.gong@nxp.com>
Cc: Wang Dongsheng <dongsheng.wang@nxp.com>
Cc: Alex Porosanu <alexandru.porosanu@freescale.com>
Cc: Hongbo Zhang <hongbo.zhang@nxp.com>
Cc: tang yuantian <Yuantian.Tang@freescale.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Josh Wu <josh.wu@atmel.com>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Christophe Ricard <christophe-h.ricard@st.com>
Cc: Anand Moon <linux.amoon@gmail.com>
Cc: Beniamino Galvani <b.galvani@gmail.com>
Cc: Carlo Caione <carlo@endlessm.com>
Cc: huang lin <hl@rock-chips.com>
Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Cc: Xu Ziyuan <xzy.xu@rock-chips.com>
Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com>
Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar>
Cc: Kever Yang <kever.yang@rock-chips.com>
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bernhard Nortmann <bernhard.nortmann@web.de>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Alexander Graf <agraf@suse.de>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: "Andrew F. Davis" <afd@ti.com>
Cc: Murali Karicheri <m-karicheri2@ti.com>
Cc: Carlos Hernandez <ceh@ti.com>
Cc: Gong Qianyu <Qianyu.Gong@freescale.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-by: Chin Liang See <clsee@altera.com>
Be sure to load the zImage and fdtfile prior to actually booting in
case we are doing a legacy boot.
Signed-off-by: Ash Charles <ashcharles@gmail.com>
Support for loading bootscript and text env file is duplicated in all TI
platforms. Add this information to DEFAULT_MMC_TI_ARGS so that it can be
reused in all TI platforms.
save_omap_boot_params is called from spl_board_init in the SPL context. Thus,
there is no reason to duplicate that call on arch_cpu_init.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Based on the am335x_evm conversion, switch to config_distro_bootcmd for
mmc and pxe. Tested with Fedora 23.
Zap CONFIG_NS16550_SERIAL, as the unification of ns16550 drivers
is completed.
Unify serial_omap, and use the generic binding.
Tested on Pandaboard
Define default mmc args in ti_armv7_common.h so that all
TI platforms can reuse.
Reported-by: Yan Liu <yan-liu@ti.com>
All TI SoCs expect filesystem to be ext4, omap4_common is the only one
with ext3. move omap4 to ext4 so that we can start consolidating MMC
arguments.
USB-related options are usually prefixed with CONFIG_USB and platform-specific
adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so
this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for
consistency.
TI armv7 based SoCs are based on two architectures - one based on OMAP
generation architecture and others based on Keystone architecture.
Many of the options are architecture specific, however a lot are common
with v7 architecture. So, step 1 will be to move out OMAP specific stuff
from ti_armv7_common into a ti_armv7_omap.h header which is then used
by all the relevant architecture headers.
Signed-off-by: Nishanth Menon <nm@ti.com>
This introduces OMAP3 support for the common omap boot code, as well as a
major cleanup of the common omap boot code.
First, the omap_boot_parameters structure becomes platform-specific, since its
definition differs a bit across omap platforms. The offsets are removed as well
since it is U-Boot's coding style to use structures for mapping such kind of
data (in the sense that it is similar to registers). It is correct to assume
that romcode structure encoding is the same as U-Boot, given the description
of these structures in the TRMs.
The original address provided by the bootrom is passed to the U-Boot binary
instead of a duplicate of the structure stored in global data. This allows to
have only the relevant (boot device and mode) information stored in global data.
It is also expected that the address where the bootrom stores that information
is not overridden by the U-Boot SPL or U-Boot.
The save_omap_boot_params is expected to handle all special cases where the data
provided by the bootrom cannot be used as-is, so that spl_boot_device and
spl_boot_mode only return the data from global data.
All of this is only relevant when the U-Boot SPL is used. In cases it is not,
save_boot_params should fallback to its weak (or board-specific) definition.
save_omap_boot_params should not be called in that context either.
them from include/configs.
