path: root/include/configs/ti_omap3_common.h
2014-10-23dm: omap3: Move to driver model for GPIO and serialSimon Glass
Adjust the configuration for the am33xx boards, including beagleboard, to use driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Tom Rini <trini@ti.com>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-04-17TI:omap3: Convert omap3_beagle to ti_omap3_common.hTom Rini
Convert to using the common config files. This requires a little more flexibility in the common files than we had been using before. Signed-off-by: Tom Rini <trini@ti.com>
2014-04-17TI:armv7: Change Falcon Mode DT load addressTom Rini
In general, we want to load the DT at base+128MB, so that we ahve sufficient room for the kernel and a larger device tree. In the case of OMAP3, use 64MB instead as we have a number of boards with 128MB DDR. Signed-off-by: Tom Rini <trini@ti.com>
2014-01-24TI: OMAP3: Create common config files for TI OMAP3 platforms.Enric Balletbò i Serra
Create a new file, include/configs/ti_omap3_common.h, for everything common to the OMAP3 SoC leaving just the board specific part to board configuration file. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
