Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Fix sniper and kc1 migration]
CONFIG_SYS_CONSOLE_INFO_QUIET
[trini: Make this default n, re-run the migration]
Move SPL_OS_BOOT to Kconfig and cleanup existing
uses.
Authentication of images in Falcon Mode is not supported. Do not enable
SPL_OS_BOOT when TI_SECURE_DEVICE is enabled. This prevents attempting
to directly load kernel images which will fail, for security reasons,
on HS devices, the board is locked if a non-authenticatable image load
is attempted, so we disable attempting Falcon Mode.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Previously we had been adjusting CONFIG_SYS_MALLOC_LEN based on if
CONFIG_DFU_MMC has been set or not. However, for quite some time this
has not been the case as we often include <configs/ti_armv7_common.h>
prior to setting CONFIG_DFU_MMC so we would always use 16MiB and then
not have enough room for to DFU files. Given the amount of memory we
always have, setting a minimum size of 32MiB for malloc is reasonable.
However, in the SPL case not only do we not need that much we start
running into overlap problems and then will fail to boot. Since we
don't need 16MiB in the SPL case, bring this down to 8MiB.
Move this option to Kconfig and tidy up existing uses.
move VERSION_VARIABLE from board config file into a
Kconfig option.
On all TI platforms the ROM defines a "downloaded image" area at or near
the start of SRAM which is followed by a reserved area. As it is at
best bad form and at worst possibly harmful in corner cases to write in
this reserved area, we stop doing that by adding in the define
NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image
area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this.
At current we define the end of scratch space at 0x228 bytes past the
start of scratch space this this gives us a lot of room to grow. As
these scratch uses are non-optional today, all targets are modified to
respect this boundary.
Tested on OMAP4 Pandaboard, OMAP3 Beagle xM
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Thomas Weber <weber@corscience.de>
Cc: Hannes Schmelzer <oe5hpm@oevsv.at>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Sam Protsenko <semen.protsenko@linaro.org>
Cc: Samuel Egli <samuel.egli@siemens.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Cc: Ben Whitten <ben.whitten@gmail.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Cc: "B, Ravi" <ravibabu@ti.com>
Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Ash Charles <ashcharles@gmail.com>
Cc: "Kipisz, Steven" <s-kipisz2@ti.com>
Cc: Daniel Allred <d-allred@ti.com>
Tested-by: Lokesh Vutla <lokeshvutla@ti.com>
Tested-by: Ladislav Michl <ladis@linux-mips.org>
Enable i2c driver model for am335x_boneblack_vboot as omap i2c
supports driver model. Also enable CONFIG_DM_I2C_COMPAT for
legacy drivers of i2c devices.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Since omap's spl doesn't support DM currently, do not define
DM_I2C for spl build.
Avoid use of hard coded mmcdev value, use bootpart
instead, so finduuid works based on bootpart set
for a specific platform.
Signed-off-by: Ravi Babu <ravibabu@ti.com>
We cannot change the long standing hard-coded offset for raw boot mode
for everyone to accommodate how Android expects things to be done here.
This reverts commit ef5ebe951bec72631cdbc7cef9079e6c684e5d0b.
According to common eMMC partition table for Android boot (see
PARTS_DEFAULT definition in include/configs/dra7xx_evm.h), "bootloader"
partition (where u-boot.img is stored) starts at 256 KiB. Which is equal
to 512 sectors (as 1 MMC sector size is 512 bytes).
This patch fixes CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR constant so that
it points to correct address of "bootloader" partition and SPL is able to
read, parse and run u-boot.img correctly.
This change was originally done as part of patch [1] in omapzoom u-boot.
Without this patch, SPL fails to parse U-Boot header with next error:
mkimage signature not found - ih_magic = 4814325a
While at it, also fix U-Boot partition size, which is 384 KiB (as stated in
include/configs/dra7xx_evm.h).
[1] http://omapzoom.org/?p=repo/u-boot.git;a=commit;h=742b82d0c0aa0ed8096c2225a00e9f350212efa9
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Support for loading bootscript and text env file is duplicated in all TI
platforms. Add this information to DEFAULT_MMC_TI_ARGS so that it can be
reused in all TI platforms.
Given that with config_distro_defaults.h we always have ext4 read
support, add in write support.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
CONFIG_BOOTDELAY is defined in config_distro_defaults.h
Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
[trini: Drop omap3_logic.h settings which were a warning and no longer
correct usage].
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Add mandatory address variables for loading scripts and pxe configuration as
per README.distro
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Linux kernel can enumerate mmc sd as either mmcblk0 or mmcblk1.
But u-boot default environment assumes that sd always populates
as mmcblk0. With this the root fs is not being mounted when
mmc sd is enumerated as mmcblk1.
So use partuuid to update root= option in default environment.
Reported-by: Yan Liu <yan-liu@ti.com>
Define default mmc args in ti_armv7_common.h so that all
TI platforms can reuse.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
Try to maintain as much commonality by conditionally including stuff
in armv7_common as necessary and removing the common defines from
keystone2 header.
Note: as part of this change, all keystone2 platforms will now start
using the generic u-boot prompt instead of the custom prompt.
Signed-off-by: Nishanth Menon <nm@ti.com>
Commit bd2c4522c26d5 ("ti: armv7: enable EXT support in SPL (using
ti_armv7_common.h)") enabled thumb mode only for SPL builds, however,
All TI armv7 platforms do support thumb, and there is no reason why the
space savings cannot be exploited for u-boot as well.
Reported-by: Murali Karicheri <m-karicheri2@ti.com>
Suggested-by: Tom Rini <trini@konsulko.com>
TI armv7 based SoCs are based on two architectures - one based on OMAP
generation architecture and others based on Keystone architecture.
Many of the options are architecture specific, however a lot are common
with v7 architecture. So, step 1 will be to move out OMAP specific stuff
from ti_armv7_common into a ti_armv7_omap.h header which is then used
by all the relevant architecture headers.
Palmas power support is required for OMAP5 devices such as the OMAP5 uEVM, that
need to e.g. enable MMC power at SPL stage.
This is especially important when booting from a peripheral (such as USB, UART),
where the bootrom will not enable power for the MMC device that will hold the
main U-Boot.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
them from include/configs.
Tested on Pandaboard (rev. A3) and Beagleboard xM (rev. B).
Compilation tested on TI armv7 boards and OMAP boards from other vendors.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Currently there is no default value for NETARGS if CONFIG_CMD_NET=y isn't set.
This results in build errors which was first discovered when trying to run
make env.
By defining a blank NETARGS these errors can be avoided.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Tested-by: Maxin B. John <maxin.john@enea.com>
Across several devices network environment variables are duplicated.
Move these variables to a common include file which insures the environment
variables are reused and insures devices across product lines share the same
values.
The dfu mmc file buffer, which was static, now is allocated
by memalign(), so the malloc pool len should be also increased.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Currently in some cases SDRAM init requires global_data to be available
and soon this will not be available prior to board_init_f(). Adjust the
code paths in these cases to be correct. In some cases we had the SPL
stack be in DDR as we might have large stacks (due to Falcon Mode +
Environment). In these cases switch to CONFIG_SPL_STACK_R. In other
cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these
cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also
in SRAM) so drop those lines.
Tested on Beagleboard, Beagleboard xM
Tested-by: Matt Porter <mporter@konsulko.com>
Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard
Tested-by: Tom Rini <trini@konsulko.com>
Enable UUID and partition support for scripted handling platforms with
MMC and eMMC and varied partitioning schemes
And remove it from headers that end up redefining it.
CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION ought to be called
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION to keep it consistent with other config
options such as: CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR.
In addition, it is not related to raw mode booting but to fs mode instead.
Reviewed-by: Tom Rini <trini@ti.com>
Cc: Tom Rini <trini@ti.com>
