path: root/include/configs/ti_am335x_common.h
2018-02-25bootcount: Migrate CONFIG_SYS_BOOTCOUNT_ADDRTom Rini
Migrate the users of CONFIG_SYS_BOOTCOUNT_ADDR to Kconfig. We can provide a default for BOOTCOUNT_AM33XX as that's a specific part of the RTC in use. We can also provide a default for ARCH_LS1043A and ARCH_LS1021A as they had been previously calculated and their symbols are in Kconfig. In the case of other QE-enabled platforms, they are not so we must update the relevant defconfig files. The previous default only applied in some cases, even on a specific SoC family. Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Alex Kiernan <alex.kiernan@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15watchdog: Migrate OMAP_WATCHDOG to KconfigTom Rini
Move this entry to Kconfig. As it is a hardware watchdog, select HW_WATCHDOG. While we could default to enabling this for all platforms, it is currently only enabled by default on AM33XX, so keep that logic today. Cc: Roger Meier <r.meier@siemens.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-11configs: am335x_evm: Enable SPL_DMLokesh Vutla
Enable SPL_DM on all AM335x based TI platforms. http://patchwork.ozlabs.org/patch/751300/ Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-01-08am335x: configs: Use ISW_ENTRY_ADDR to set SPL_TEXT_BASEAndrew F. Davis
The SPL load address changes based on boot type in HS devices, ISW_ENTRY_ADDR is used to set this address for AM43xx based SoCs for similar reasons. Add this same logic for AM33xx devices. Also make the default value for ISW_ENTRY_ADDR correct for GP devices based on SoC, HS devices already pick the correct value in their defconfig. Signed-off-by: Andrew F. Davis <afd@ti.com>
2016-10-02Kconfig: Separate AM33XX SOC config from target board configAndrew F. Davis
The config option AM33XX is used in several boards and should be defined as a stand-alone option for this SOC. We break this out from target boards that use this SoC and common headers then enable AM33XX on in all the boards that used these targets to eliminate any functional change with this patch. This is similar to what has already been done in 9de852642cae ("arm: Kconfig: Add support for AM43xx SoC specific Kconfig") and is done for the same reasons. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-06TI: Rework SRAM definitions and maximumsTom Rini
On all TI platforms the ROM defines a "downloaded image" area at or near the start of SRAM which is followed by a reserved area. As it is at best bad form and at worst possibly harmful in corner cases to write in this reserved area, we stop doing that by adding in the define NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this. At current we define the end of scratch space at 0x228 bytes past the start of scratch space this this gives us a lot of room to grow. As these scratch uses are non-optional today, all targets are modified to respect this boundary. Tested on OMAP4 Pandaboard, OMAP3 Beagle xM Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Paul Kocialkowski <contact@paulk.fr> Cc: Enric Balletbo i Serra <eballetbo@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Heiko Schocher <hs@denx.de> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: "B, Ravi" <ravibabu@ti.com> Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: "Kipisz, Steven" <s-kipisz2@ti.com> Cc: Daniel Allred <d-allred@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Ladislav Michl <ladis@linux-mips.org>
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15am335x: configs: Fix usb ether boot supportLokesh Vutla
CONFIG_SPL_NET_VCI_STRING is available only with BOOTP. So if CMD_DHCP is enabled for SPL in usb ether boot, it will not pass the right vendor name and failing to download the right file. Also all the net CMD_* are not required in SPL builds. So defining these only for non-SPL builds. Reported-by: Yan Liu <yan-liu@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Sekhar Nori <nsekhar@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-21ns16550: zap CONFIG_NS16550_SERIALThomas Chou
Zap CONFIG_NS16550_SERIAL, as the unification of ns16550 drivers is completed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-21ns16550: unify serial_omapThomas Chou
Unify serial_omap, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-27configs: split ti_armv7_common into a omap generic headerNishanth Menon
TI armv7 based SoCs are based on two architectures - one based on OMAP generation architecture and others based on Keystone architecture. Many of the options are architecture specific, however a lot are common with v7 architecture. So, step 1 will be to move out OMAP specific stuff from ti_armv7_common into a ti_armv7_omap.h header which is then used by all the relevant architecture headers. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: omap3: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Add CMD_DM and CMD_DEMO to KconfigSimon Glass
Add Kconfig settings for these two options. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-29rsa: Use checksum algorithms from struct hash_algoRuchika Gupta
Currently the hash functions used in RSA are called directly from the sha1 and sha256 libraries. Change the RSA checksum library to use the progressive hash API's registered with struct hash_algo. This will allow the checksum library to use the hardware accelerated progressive hash API's once available. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Fixed build error in am335x_boneblack_vboot due to duplicate CONFIG_DM) Change-Id: Ic44279432f88d4e8594c6e94feb1cfcae2443a54
2014-10-23dm: am33xx: Move to driver model for GPIO and serialSimon Glass
Adjust the configuration for the am33xx boards, including beaglebone black to use driver model. This can be extended to other OMAP boards once platform data is provided for them. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Tom Rini <trini@ti.com>
2014-06-06arm:am33xx: Rework s_init and add board_early_init_fTom Rini
With the changes to the i2c framework (and adopting the omap24xx_i2c driver to them) we can no longer call i2c functions prior to gd having been set and cleared. When SPL booting, this is handled by setting gd to point to SRAM in s_init. However in the cases where we are loaded directly by ROM (memory mapped NOR or QSPI) we need to make use of the normal hooks to slightly delay these calls. Signed-off-by: Tom Rini <trini@ti.com>
2014-04-17TI:armv7: Change Falcon Mode DT load addressTom Rini
In general, we want to load the DT at base+128MB, so that we ahve sufficient room for the kernel and a larger device tree. In the case of OMAP3, use 64MB instead as we have a number of boards with 128MB DDR. Signed-off-by: Tom Rini <trini@ti.com>
2014-03-04ARM: AM335x: add support for reading cpsw 2nd mac address from efuseMugunthan V N
Adding support for reading cpsw 2nd mac address from efuse and pass it to kernel via dtb which will be used in dual emac mode of cpsw. Also adding mii command support to am335x common config. Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2014-02-21am335x: Initial support for Silica Pengwyn boardLothar Felten
This patch add support for the Silica Pengwyn board [1] The board is based on a TI AM3354 CPU [2] All jumpers removed it will boot from the SDcard, the console is on UART1 accessible via the FDTI -> USB. The on board NAND flash is supported and can act as boot medium, depending on jumper settings. USB Host, USB Device and Ethernet are also provided but untested. [1] http://www.silica.com/product/silica-pengwyn-board.html [2] http://www.ti.com/product/am3354 Signed-off-by: Lothar Felten <lothar.felten@gmail.com> [trini: Move CONFIG_BOARD_LATE_INIT into am335x_evm.h, drop unused spi0_pin_mux from Pengwyn support] Signed-off-by: Tom Rini <trini@ti.com>
2014-01-24TI: armv7: Move ELM support to SoC configuration file.Enric Balletbò i Serra
The ELM hardware engine wihich is used for ECC error detections is not present on OMAP3 SoC, so move the CONFIG_SPL_NAND_AM33XX_BCH from ti_armv7_common.h to SoC configuration file. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-11-11am33xx: Make SoC bootcount driver have its own symbolTom Rini
Some am33xx boards may not use the RTC block for bootcount (as it may not be wired up for the board) and use some other facility. So add another symbol for the bootcount driver for the IP block. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2013-11-11arm, am33x: make RTC32K OSC enable configurableHeiko Schocher
As http://www.denx.de/wiki/view/U-Boot/DesignPrinciples#2_Keep_it_Fast states: "Initialize devices only when they are needed within U-Boot" enable the RTC32K OSC only, if CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC is enabled. Enable this in ti_am335x_common.h, so all boards in mainline should work as before. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com>
2013-11-01am335x: Enable CONFIG_OMAP_WATCHDOG supportTom Rini
There is a board-specific portion for calling watchdog enable itself, in main U-Boot. Signed-off-by: Tom Rini <trini@ti.com>
2013-11-01TI:am33xx: Add bootcount support to ti_am335x_common.hTom Rini
Enable the bootcount driver for am335x in general. We leave adding a bootlimit and altbootcmd to the environment to the board ports. Signed-off-by: Tom Rini <trini@ti.com>
2013-08-28TI:am33xx: Move SPL YMODEM support to the per-board configTom Rini
2013-08-28TI:am335x: Better comment and organize the networking related optionsTom Rini
While in here, drop CONFIG_BOOTP_DEFAULT as it is unused in the code. Signed-off-by: Tom Rini <trini@ti.com>
2013-08-28am33xx: Correct and expand comments on CONFIG_SPL_MAX_SIZETom Rini
We had been allowing the max size to be larger than actually allowed by the ROM. Expand the commentary here to explain why we set these locations. Signed-off-by: Tom Rini <trini@ti.com>
2013-08-15TI:am33xx: Create common config files for TI ARMv7 platforms, and AM33xxTom Rini
We create two new files, include/configs/ti_armv7_common.h for all of the common IP blocks and related features / commands we share in virtually all of our platforms. We then create include/configs/ti_am335x_common.h for everything common to the am335x SoC leaving just the board specific parts to include/configs/ti_am335x_common.h. Signed-off-by: Tom Rini <trini@ti.com>
