path: root/include/configs/theadorable.h
2019-04-12mvebu: drop dangling SPI flash comments and #ifdefsBaruch Siach
Following commits abe66b1b5dec ("Convert CONFIG_ENV_SPI_* to Kconfig") and 14453fbfadc2f ("Convert CONFIG_SF_DEFAULT_* to Kconfig") remove dandling comment lines and empty #ifdef sections. Cc: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-02-05arm: mvebu: theadorable: Enable video / LCD support with the new DM driverStefan Roese
With the new DM_VIDEO support in the Armada XP LCD driver, this patch adds the needed DT node for the LCD controller to the theadorable dts file. This DT property is not added to the Armada XP dtsi files, as this LCD feature is pretty unusual for this SoC and I personally know of no other board that uses this controller. This patch also enables CONFIG_BMP_16BPP/24BPP/32BPP, as the "old" bmp command supported these BMP files. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Anatolij Gustschin <agust@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2019-02-05pci: pci_mvebu: Add DM_PCI support and move CONFIG_PCI_MVEBU to defconfigStefan Roese
This patch adds DM_PCI support to the MVEBU PCIe driver. This is necessary, since all PCI drivers have to be moved to DM (driver model) until the v2019.07 release. To not break git bisect'ablility, this patch also moves CONFIG_PCI_MVEBU from config headers to the defconfig files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Mario Six <mario.six@gdsys.cc> Cc: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Phil Sutter <phil@nwl.cc> Cc: Marek BehĂșn <marek.behun@nic.cz> Cc: VlaoMao <vlaomao@gmail.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-24Convert CONFIG_BOOTCOUNT_RAM to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_BOOTCOUNT_RAM Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2018-01-22fs: fat: Drop CONFIG_SUPPORT_VFATTuomas Tynkkynen
fat.h unconditionally defines CONFIG_SUPPORT_VFAT (and has done since 2003), so as a result VFAT support is always enabled regardless of whether a board config defines it or not. Drop this unnecessary option. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-12-12ata: Migrate CONFIG_LIBATA to KconfigTuomas Tynkkynen
This symbol enables some library code used by various SATA drivers, so make this a non-user-visible symbol select'ed by the respective drivers, and let moveconfig handle the rest. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-12-12ata: Migrate CONFIG_SATA_MV to KconfigTuomas Tynkkynen
2017-07-26kconfig: Convert FPGA and FPGA_ALTERA configuration to KconfigTien Fong Chee
This converts the following to Kconfig: CONFIG_FPGA CONFIG_FPGA_ALTERA Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
2017-07-11Convert CONFIG_CMD_SATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-22Kconfig: Drop CONFIG_CMD_ENVSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONFIG_CFB_CONSOLE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-26spl: Remove unused CONFIG_SPL_SPI_* definitionsChris Packham
As of commit 88e34e5 ("spl: replace CONFIG_SPL_SPI_* with CONFIG_SF_DEFAULT_*") these defines are not used. Remove them to avoid confusion. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-07-01autoboot: remove CONFIG_ZERO_BOOTDELAY_CHECKMasahiro Yamada
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2 means the autoboot with no delay, with no abort check even if CONFIG_ZERO_BOOTDELAY_CHECK is defined. To sum up, the autoboot behaves as follows: [1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n autoboot with no delay, with no check for abort [3] CONFIG_BOOTDELAY=-1 disable autoboot [4] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort As you notice, [2] and [4] come to the same result, which means we do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the cases only by CONFIG_BOOTDELAY, like this: [1] CONFIG_BOOTDELAY=0 autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=-1 disable autoboot [3] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort This commit converts the logic as follow: CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n --> CONFIG_BOOTDELAY=-2 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Christian Riesch <christian.riesch@omicronenergy.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2016-05-20arm: mvebu: theadorable: Enable CONFIG_ZERO_BOOTDELAY_CHECKStefan Roese
Enable bootdelay 0 check so that booting can be interrupted even with bootdelay configured to 0. Signed-off-by: Stefan Roese <sr@denx.de>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-12arm: mvebu: theadorable: Add PEX-switch detection and reset codeStefan Roese
Sometimes the PCIe link for the PEX-switch will not come-up. In this case, the board is not in a usable state. This patch makes sure that in this case a soft-reset is issued. If this soft-reset does not result in the PEX-switch being detected after some soft-reset cycles, an I2C message is sent to the uC to issue a complete power-cycle of the board. Signed-off-by: Stefan Roese <sr@denx.de>
2016-04-12arm: mvebu: theadorable: Enable 2nd I2C controllerStefan Roese
This patch enables the 2nd I2C controller on the Armada XP theadorable board. Signed-off-by: Stefan Roese <sr@denx.de>
2016-04-12arm: mvebu: theadorable: Add bootcounter supportStefan Roese
This patch adds bootcount support to the MVEBU theadorable board. Since no reset-safe registers seem to be available, it uses the last 4KiB of SDRAM for the bootcounter location. Signed-off-by: Stefan Roese <sr@denx.de>
2016-03-24arm: mvebu: theadorable: Add StratixV FPGA programming supportStefan Roese
This patch adds support for Altera StratixV bitstream programming. 2 FPGAs are connected to the SPI busses. This patch uses board specific write code to program the bitstream via SPI direct write mode. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
