path: root/include/configs/theadorable-x86-conga-qa3-e3845.h
2017-08-08x86: theadorable-x86: Add header file for common defines and envStefan Roese
This patch adds the common header include file theadorable-x86-common.h for the theadorable-x86 targets to define all common options and the default environment. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-08x86: conga: Add option to select different config headers for baseboardsStefan Roese
This patch adds the infrastructure to define different config headers with different configurations and default environment for the baseboards that can now be selected via Kconfig. The new configuration for the theadorable-x86-conga-qa3-e3845 is also added. Also the new defconfig file for this new target is added. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
