path: root/include/configs/tegra20-common.h
2015-10-02ARM: tegra: expand all SPL sizes to be consistentStephen Warren
The size allocation for SPL is increased in all cases to match the already-expanded value used on Tegra124. This is both for general consistency, and because the seaboard build trips over the limit already when using one of the ARM compilers packaged with 14.04. For the record, when building Seaboard: arm-linux-gnueabi- SPL is too big by 0x36 bytes arm-linux-gnueabihf- SPL fits by 0x2a bytes arm-none-eabi- SPL fits by 0xa bytes (Those figures are from builds with the expanded SPL size allocation, relative to the non-expanded SPL size limit; they're better by about 6 bytes in the more constrained build.) Fixes: ba521994229c ("tegra124: Expand SPL space by 8KB") Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13ARM: tegra: CONFIG_{SYS_, }LOAD{_, }ADDR rationalizationStephen Warren
As best I can tell, CONFIG_SYS_LOAD_ADDR and CONFIG_LOADADDR/$loadaddr serve essentially the same purpose. Roughly, if a command takes a load address, then CONFIG_SYS_LOAD_ADDR or $loadaddr (or both) are the default if the command-line does not specify the address. Different U-Boot commands are inconsistent re: which of the two default values they use. As such, set the two to the same value, and move the logic that does this into tegra-common-post.h so it's not duplicated. A number of other non- Tegra boards do this too. The values chosen for these macros are no longer consistent with anything in MEM_LAYOUT_ENV_SETTINGS. Regain consistency by setting $kernel_addr_r to CONFIG_LOADADDR. Older scripts tend to use $loadaddr for the default kernel load address, whereas newer scripts and features tend to use $kernel_addr_r, along with other variables for other purposes such as DTBs and initrds. Hence, it's logical they should share the same value. I had originally thought to make the $kernel_addr_r and CONFIG_LOADADDR have different values. This would guarantee no interference if a script used the two variables for different purposes. However, that scenario is unlikely given the semantic meaning associated with the two variables. The lowest available value is 0x90200000; see comments for MEM_LAYOUT_ENV_SETTINGS in tegra30-common-post.h for details. However, that value would be problematic for a script that loaded a raw zImage to $loadaddr, since it's more than 128MB beyond the start of SDRAM, which would interfere with the kernel's CONFIG_AUTO_ZRELADDR. So, let's not do that. The only potential fallout I could foresee from this patch is if someone has a script that loads the kernel to $loadaddr, but some other file (DTB, initrd) to a hard-coded address that the new value of $loadaddr interferes with. This seems unlikely. A user should not do that; they should either hard-code all load addresses, or use U-Boot-supplied variables for all load addresses. Equally, any fallout due to this change is trivial to fix; simply modify the load addresses in that script. Cc: Paul Walmsley <pwalmsley@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Paul Walmsley <pwalmsley@nvidia.com> Reviewed-by: Simon Glass Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-05ARM: tegra: implement bootcmd_pxeStephen Warren
This retrieves a PXE config file over the network, and executes it. This allows an extlinux config file to be retrieved over the network and executed, whereas the existing bootcmd_dhcp retrieves a U-Boot script. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-03-05ARM: tegra: set CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTSStephen Warren
Tegra's EHCI controllers only have a single PORTSC register. Configure U-Boot to know this. This prevents e.g. ehci_shutdown() from touching non-existent registers. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-03-05ARM: tegra: move CONFIG_TEGRAnnStephen Warren
<asm/arch-tegra/tegra.h> needs to use CONFIG_TEGRA* to conditionalize some definitions, since some modules moved between generations. Move the definition of CONFIG_TEGRAnn to a header that's included earlier, so that it's set by the time tegra.h needs to use it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-08-19ARM: tegra: Make cache line size SoC specificThierry Reding
Currently all Tegra SoCs are assumed to have 32 byte cache lines. This isn't true for Tegra114, however, which uses 4 Cortex-A15 cores and therefore uses a cache line size of 64 bytes. Move the cache line size setting to the per-SoC common configuration file. Signed-off-by: Thierry Reding <treding@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-05-28Tegra: Remove unused/non-existent spl linker script referenceTom Warren
Tegra builds use the common u-boot-spl.lds now. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-22ARM: tegra: enable workaround for ARM erratum 716044Stephen Warren
Tegra20 requires the workaround for this erratum. Enable it. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-03-15Merge branch 'u-boot-tegra/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-14ARM: tegra: enable a common set of disk-related commands everywhereStephen Warren
Enable a common set of partition types, filesystems, and related commands in tegra-common.h, so that they are available on all Tegra boards. This allows boot.scr (loaded and executed by the default built-in environment) on those boards to assume that certain features are always available. Do this in tegra-common.h, so that individual board files can undefine the features if they really don't want any of them. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-03-14ARM: tegra: make bounce buffer option commonStephen Warren
All Tegra devices will need CONFIG_BOUNCE_BUFFER. Move it to tegra-common.h to ensure it's always set. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-03-13ARM: tegra: enable some CPU errata workaroundsStephen Warren
Tegra20 has a Cortex A9 r1p1, and Tegra30 has a Cortex A9 r2p9. As such, some CPU errata exist, and must be worked around. These must be worked around in the bootloader, since in general, the kernel (especially a multi-platform kernel) needs to support being launched in non-secure mode (normal world), and hence may not be able to write to the CP15 register to enable these workarounds. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-01-16Tegra30: Add/enable Cardhu build (T30 reference board)Tom Warren
This build is stripped down. It boots to the command prompt. GPIO is the only peripheral supported. Others TBD. include/configs/tegra-common.h now holds common config options for Tegra SoCs. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2012-12-10Merge branch 'master' of git://git.denx.de/u-boot into resolveMinkyu Kang
Conflicts: README board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-11-27mmc: tegra: use bounce buffer APIsStephen Warren
Tegra's MMC driver does DMA, and hence needs cache-aligned buffers. In some cases (e.g. user load commands) this cannot be guaranteed by callers of the MMC APIs. To solve this, modify the Tegra MMC driver to use the new bounce_buffer_*() APIs. Note: Ideally, all U-Boot code will always provide address- and size- aligned buffers, so a bounce buffer will only ever be needed for user- supplied buffers (e.g. load commands). Ensuring this removes the need for performance-sucking bounce buffer cache management and memcpy()s. The one known exception at present is the SCR buffer in sd_change_freq(), which is only 8 bytes long. Solving this requires enhancing struct mmc_data to know the difference between buffer size and transferred data size, or forcing all callers of mmc_send_cmd() to have allocated buffers using ALLOC_CACHE_ALIGN_BUFFER(), which while true in this case, is not enforced in any way at present, and so cannot be assumed by the core MMC code. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-11-20tegra: move TEGRA_DEVICE_SETTINGS to tegra-common-post.hAllen Martin
Move environment settings for stdin/stdout/stderr to tegra-common-post.h and generate them automaticaly based on input device selection. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2012-11-20boards: remove the no longer used CONFIG_EHCI_DCACHEJeroen Hofstee
CONFIG_EHCI_DCACHE was removed by commit b8adb12 "USB: Drop cache flush bloat in EHCI-HCD". Remove the defines from the boards configs as well. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> cc: Marek Vasut <marex@denx.de> cc: Stefan Roese <sr@denx.de> cc: Tom Rini <trini@ti.com> cc: Wolfgang Denk <wd@denx.de> cc: Thierry Reding <thierry.reding@avionic-design.de> cc: Tom Warren <twarren@nvidia.com> cc: Stephen Warren <swarren@nvidia.com> cc: Stefano Babic <sbabic@denx.de>
2012-11-19tegra: Align LCD frame buffer to section boundarySimon Glass
For tegra we want to enable the cache for the LCD. This is easier if we can avoid using L2 page tages, so align the LCD to a section boundary. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-29tegra: move to common SPL frameworkAllen Martin
Change tegra SPL to use common SPL framework. Any tegra specific initialization is now done in spl_board_init() instead of board_init_f()/board_init_r(). Only one SPL boot target is supported on tegra, which is boot to RAM image. jump_to_image_no_args() must be overridden on tegra so the host CPU can be initialized. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Tested-by: Lucas Stach <dev@lynxeye.de> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-29ARM: tegra: derive CONFIG_SPL_MAX_SIZE instead of hard-coding itStephen Warren
For Tegra, the SPL and main U-Boot are concatenated together to form a single memory image. Hence, the maximum SPL size is the different in TEXT_BASE for SPL and main U-Boot. Instead of manually calculating SPL_MAX_SIZE based on those two TEXT_BASE, which can lead to errors if one TEXT_BASE is changed without updating SPL_MAX_SIZE, simply perform the calculation automatically. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Allen Martin <amartin@nvidia.com> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-29tegra: nand: make ONFI detection workLucas Stach
Add the missing bits to the Tegra NAND driver to make ONFI detection work properly. Also add it to the Tegra default config, as it seems to be a reasonable thing to have it available on all boards that use any kind of NAND. Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-29ARM: tegra: define CONFIG_SYS_BOOTMAPSZStephen Warren
This define indicates the size of the memory region where it is safe to place data passed to the Linux kernel (ATAGs, DTB, initrd). The value needs to be: a) Less than or equal to RAM size. b) Small enough that the area is not within the kernel's highmem region, since the kernel cannot access ATAGs/DTB/initrd from highmem. c) Large enough to hold the kernel+DTB+initrd. 256M seems large enough for (c) in most circumstances, and small enough to satisfy (a) and (b) across any possible Tegra board. Note that the user can override this value via environment variable "bootm_mapsize" if needed. The advantage of defining BOOTMAPSZ is that we no longer need to define variable fdt_high in the default environment. Previously, we defined this to prevent the DTB from being relocated to the very end of RAM, which on most Tegra systems is within highmem, and hence which would cause boot failures. A user can still define this variable themselves if they want the FDT to be either left in-place wherever loaded, or copied to some other specific location. Similarly, there should no longer be a strict requirement for the user to define initrd_high if using an initrd. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15tegra: enable CONFIG_CMD_PARTStephen Warren
This is extremely likely to be used from the boot.scr that Tegra's default bootcmd locates and executes. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15Tegra20: Move some include files to arch-tegra for sharing with Tegra30Tom Warren
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h. Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20' 'root' file. All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15COMMON: Use __stringify() instead of rest of implementationsMarek Vasut
Fix up the rest of implementations of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-09-07tegra: Enable NAND on SeaboardSimon Glass
This enables NAND support for the Seaboard. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01tegra20: enable SPL for tegra20 boardsAllen Martin
Add SPL options to tegra20 config files and enable SPL build for tegra20 boards. Also remove redundant code from u-boot that is not contained in SPL. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: rename CONFIG_MACH_TEGRA_GENERICAllen Martin
Rename CONFIG_MACH_TEGRA_GENERIC to the less confusing CONFIG_TEGRA. The meaning of the config options is now: CONFIG_TEGRA - Any tegra chip CONFIG_TEGRA20 - A tegra20 family chip CONFIG_TEGRA30 - A tegra30 family chip (not added yet) Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
