path: root/include/configs/tegra2-common.h
2012-07-07gpio: tegra2: rename tegra2_gpio.* to tegra_gpio.*Tom Warren
In anticipation of Tegra3 support, continue removing/renaming Tegra2-specific files. No functional changes (yet). Updated copyrights to 2012. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: flesh out bootcmdStephen Warren
This implements a useful bootcmd for Tegra. The boot order is: * If USB enabled, USB storage * Internal MMC (SD card or eMMC) * If networking is enabled, BOOTP/TFTP When booting from USB or MMC, the boot script is assumed to be in partition 1 (although this may be overridden via the rootpart variable), both ext2 and FAT filesystems are supported, the boot script may exist in either / or /boot, and the boot script may be named boot.scr.uimg or boot.scr. When booting over the network, it is assumed that boot.scr.uimg exists on the TFTP server. There is less flexibility here since those setting up network booting are expected to need less hand-holding. In all cases, it is expected that the initial file loaded is a U-Boot image containing a script that will load the kernel, load any required initrd, load any required DTB, and finally bootm the kernel. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: remove some cruft from CONFIG_EXTRA_ENV_SETTINGSStephen Warren
console isn't used by anything, and the kernel should be set appropriately by whatever script is booting the kernel, not imposed by the bootloader. mem might be useful, but the current value is pretty bogus, since it includes nvmem options that make no sense for an upstream kernel, and equally should not be required for any downstream kernel. Either way, this is also best left to the kernel boot script. smpflag isn't used by anything, and again was probably intended to be a kernel command-line option better set by the kernel boot script. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-05-15tegra: Switch on console mux and use environment for consoleSimon Glass
All tegra boards will use these options by default. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-05-15tegra: Enable LP0 on SeaboardSimon Glass
This enables LP0 to support suspend / resume on Seaboard. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: i2c: Select number of controllers for Tegra2 boardsSimon Glass
The Tegra 2x SOC has four ports, so define TEGRA_I2C_NUM_CONTROLLERS in the shared config file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: usb: Add common USB defines for tegra2 boardsSimon Glass
All Tegra2 boards should include tegra2-common. This adds the required USB config to that file. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Change CONFIG_SYS_TEXT_BASE to 0x00108000.Thierry Reding
NVIDIA's flashing tools assume that the bootloader is loaded at address 0x00108000. Instead of requiring non-standard builds of those tools which allow a load address of 0x00E08000, this commit just switches all Tegra2 boards to use the standard load address. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Tested-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Enable SPI environment on SeaboardSimon Glass
This uses the SPI flash on Seaboard to store an 8KB environment. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Remove unneeded config optionSimon Glass
CONFIG_ENABLE_CORTEXA9 and CONFIG_SKIP_RELOCATE_UBOOT are not needed, so remove them. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Add arch_cpu_init() to fire up Cortex-A9Simon Glass
We want to move away from a special Tegra2 start-up, and just use arch_cpu_init() instead. However, if we run board_init_f() from boot we need to build it for ARMv4T, since the Tegra's AVP start-up CPU does not support ARMv7. The effect of this is to do the AVP init earlier, and in arch_cpu_init(), rather that board_early_init_f(). Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-11-03sandbox/tegra2: fix typo in autocomplete defineMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Simon Glass <sjg@chromium.org>
2011-10-25tegra: define CONFIG_SYS_CACHELINE_SIZE for tegraAnton staaf
Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Tom Warren <twarren.nvidia@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Change-Id: I5c4bcfc0bfe59158ff249fe3be6640eec6d3cc76 Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-04arm: Tegra2: GPIO: enable GPIO for Tegra2 boardsTom Warren
2011-07-04armv7: rename cache related CONFIG flagsAneesh V
Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF Signed-off-by: Aneesh V <aneesh@ti.com> V2: * Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE V4: * Changed all three flags to the final names suggested as above and accordingly changed the commit message
2011-04-28Add CONFIG_OF_LIBFDT to more boards.Grant Likely
The following boards gain device tree support with this patch: ca9x4_ct_vxp - Versatile Express i.mx5 boards: efikamx mx51evk mx53evk OMAP boards: devkit8000 igep0020 igep0030 omap3_overo omap3_pandora omap4_sdp3430 omap3_zoom1 omap3_zoom2 omap4_panda omap4_sdp4430 Tegra boards: Harmony Signed-off-by: Grant Likely <grant.likely@linaro.org>
2011-04-27arm: Tegra2: add support for A9 CPU initTom Warren
2011-02-21arm: Tegra2: Add support for NVIDIA Harmony boardTom Warren
