NVIDIA's flashing tools assume that the bootloader is loaded at address
0x00108000. Instead of requiring non-standard builds of those tools
which allow a load address of 0x00E08000, this commit just switches all
Tegra2 boards to use the standard load address.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
This uses the SPI flash on Seaboard to store an 8KB environment.
CONFIG_ENABLE_CORTEXA9 and CONFIG_SKIP_RELOCATE_UBOOT are not needed,
so remove them.
We want to move away from a special Tegra2 start-up, and just use
arch_cpu_init() instead. However, if we run board_init_f() from boot
we need to build it for ARMv4T, since the Tegra's AVP start-up CPU
does not support ARMv7.
The effect of this is to do the AVP init earlier, and in
arch_cpu_init(), rather that board_early_init_f().
Signed-off-by: Anton Staaf <robotboy@chromium.org>
Cc: Tom Warren <twarren.nvidia@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Change-Id: I5c4bcfc0bfe59158ff249fe3be6640eec6d3cc76
Replace the cache related CONFIG flags with more meaningful
names. Following are the changes:
CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF
CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF
Signed-off-by: Aneesh V <aneesh@ti.com>
V2:
* Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE
V4:
* Changed all three flags to the final names suggested as above
and accordingly changed the commit message
The following boards gain device tree support with this patch:
ca9x4_ct_vxp - Versatile Express
i.mx5 boards:
efikamx
mx51evk
mx53evk
OMAP boards:
devkit8000
igep0020
igep0030
omap3_overo
omap3_pandora
omap4_sdp3430
omap3_zoom1
omap3_zoom2
omap4_panda
omap4_sdp4430
Tegra boards:
Harmony
Signed-off-by: Grant Likely <grant.likely@linaro.org>
