path: root/include/configs/tegra124-common.h
2017-07-28configs: Remove CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS in all boardsBin Meng
Now that EHCD does not use CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS, remove it in all boards' config files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2015-08-06ARM: tegra: move VPR configuration to a later stageAlexandre Courbot
U-boot is responsible for enabling the GPU DT node after all necessary configuration (VPR setup for T124) is performed. In order to be able to check whether this configuration has been performed right before booting the kernel, make it happen during board_init(). Also move VPR configuration into the more generic gpu.c file, which will also host other GPU-related functions, and let boards specify individually whether they need VPR setup or not. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-07-27tegra124: Expand SPL space by 8KBSimon Glass
We are getting very close to running out of space in SPL, and with the currently Chrome OS gcc 4.9 we exceed the limit. Add a litle more space. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13ARM: tegra: CONFIG_{SYS_, }LOAD{_, }ADDR rationalizationStephen Warren
As best I can tell, CONFIG_SYS_LOAD_ADDR and CONFIG_LOADADDR/$loadaddr serve essentially the same purpose. Roughly, if a command takes a load address, then CONFIG_SYS_LOAD_ADDR or $loadaddr (or both) are the default if the command-line does not specify the address. Different U-Boot commands are inconsistent re: which of the two default values they use. As such, set the two to the same value, and move the logic that does this into tegra-common-post.h so it's not duplicated. A number of other non- Tegra boards do this too. The values chosen for these macros are no longer consistent with anything in MEM_LAYOUT_ENV_SETTINGS. Regain consistency by setting $kernel_addr_r to CONFIG_LOADADDR. Older scripts tend to use $loadaddr for the default kernel load address, whereas newer scripts and features tend to use $kernel_addr_r, along with other variables for other purposes such as DTBs and initrds. Hence, it's logical they should share the same value. I had originally thought to make the $kernel_addr_r and CONFIG_LOADADDR have different values. This would guarantee no interference if a script used the two variables for different purposes. However, that scenario is unlikely given the semantic meaning associated with the two variables. The lowest available value is 0x90200000; see comments for MEM_LAYOUT_ENV_SETTINGS in tegra30-common-post.h for details. However, that value would be problematic for a script that loaded a raw zImage to $loadaddr, since it's more than 128MB beyond the start of SDRAM, which would interfere with the kernel's CONFIG_AUTO_ZRELADDR. So, let's not do that. The only potential fallout I could foresee from this patch is if someone has a script that loads the kernel to $loadaddr, but some other file (DTB, initrd) to a hard-coded address that the new value of $loadaddr interferes with. This seems unlikely. A user should not do that; they should either hard-code all load addresses, or use U-Boot-supplied variables for all load addresses. Equally, any fallout due to this change is trivial to fix; simply modify the load addresses in that script. Cc: Paul Walmsley <pwalmsley@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Paul Walmsley <pwalmsley@nvidia.com> Reviewed-by: Simon Glass Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-05ARM: tegra: set CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTSStephen Warren
Tegra's EHCI controllers only have a single PORTSC register. Configure U-Boot to know this. This prevents e.g. ehci_shutdown() from touching non-existent registers. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-03-05ARM: tegra: move CONFIG_TEGRAnnStephen Warren
<asm/arch-tegra/tegra.h> needs to use CONFIG_TEGRA* to conditionalize some definitions, since some modules moved between generations. Move the definition of CONFIG_TEGRAnn to a header that's included earlier, so that it's set by the time tegra.h needs to use it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-02-03ARM: tegra: fix "bootp" issue for Tegra124 tooJim Lin
Fix the timeout issue after running "bootp" command in U-Boot console. TXFIFOTHRES bits of TXFILLTUNING register should be set to 0x10 after a controller reset and before RUN bit is set (per technical reference manual). Signed-off-by: Jim Lin <jilin@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-02-03ARM: tegra: add Venice2 (Tegra124) boardTom Warren
These are the board files for Venice2 (Tegra124), plus the AS3722 PMIC files. PMIC init will be moved to pmic_common_init later. This builds/boots on Venice2, SPI/MMC/USB/I2C all work. Audio, display and WB/LP0 are not supported yet. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
