path: root/include/configs/tegra-common.h
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-08treewide: Remove CONFIG_SYS_UBOOT_START from configs board filesPatrice Chotard
As previous CONFIG_SYS_UBOOT_START is now set by default to CONFIG_SYS_TEXT_BASE when not defined, CONFIG_SYS_UBOOT_START can be removed from include/configs board files. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: Lukasz Majewski <lukma@denx.de>
2019-02-20tegra: cleanup dangling comments in include/configsPeter Robinson
There's a number of dangling comments in various tegra configs post migrations of various configs so lets clean them up. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Peter.Chubb@data61.csiro.au Cc: Lucas Stach <dev@lynxeye.de> Cc: Stefan Agner <stefan.agner@toradex.com> Cc: Alban Bedel <alban.bedel@avionic-design.de> Cc: Allen Martin <amartin@nvidia.com> Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-23Remove config_distro_defaults.hAdam Ford
With the contents of config_distro_defaults.h migrated to Kconfig, we can remove this header file completely Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-12ARM: tegra: use CONFIG_SYS_INIT_SP_BSS_OFFSETStephen Warren
Enable CONFIG_SYS_INIT_SP_BSS_OFFSET for all 64-bit Tegra boards. Place the stack/... 512KiB from the end of the U-Boot binary. This should be plenty to accommodate the current DTBs (max 64 KiB), early malloc region (6KiB), stack usage, and plenty of slack, while still not placing it too far away from the U-Boot binary. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2018-01-12ARM: tegra: remove SPL config for non-SPL SoCsStephen Warren
No 64-bit Tegra uses SPL. Remove various unused definitions from config headers. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-16ARM: tegra: Remove unused define CONFIG_ARMCORTEXA9Tuomas Tynkkynen
This macro isn't used by anything, and in fact hasn't ever been used according to the Git logs. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-31Kconfig: Finish migration of hashing commandsDaniel Thompson
Currently these (board agnostic) commands cannot be selected using menuconfig and friends. Fix this the obvious way. As part of this, don't muddle the meaning of CONFIG_HASH_VERIFY to mean both 'hash -v' and "we have a hashing command" as this makes the Kconfig logic odd. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> [trini: Re-apply, add imply for a few cases, run moveconfig.py, also migrate CRC32_VERIFY] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_ENTERRCM to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENTERRCM Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27clean-up: Remove uselsess mentions of CONFIG_COMMAND_HISTORYAlexey Brodkin
These were reminders that somehow slipped through the cracks or were erroneously introduced after previous clean-ups. Getting rid of then once again. Hopefully for good now :) Where missing and appropriate replace with CONFIG_CMDLINE_EDITING which really enables shell history as of now. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Peter Griffin <peter.griffin@linaro.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Jon Mason <jon.mason@broadcom.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-14Convert CONFIG_SPL_RAM_DEVICE to defconfigStefan Agner
This converts the following to Kconfig: CONFIG_SPL_RAM_DEVICE Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-12-16Kconfig: Move USE_ARCH_MEMCPY/MEMSET to KconfigFabio Estevam
Move USE_ARCH_MEMCPY/MEMSET options to Kconfig. Make it "default y" for the ARMv7 architecture and make it depend on !ARM64 && !SPL. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-27ARM: tegra: increase console buffer size and sys args numBryan Wu
The Linux-for-Tegra kernel uses a very long command line. The default value of CONFIG_SYS_CBSIZE is too small to printf out the long command line and causes a message like: bootarg overflow 602+0+0+1 > 512 on the console, and the board refuses to boot. The default value of CONFIG_SYS_MAXARGS is too small to add a long long command line, and the kernel won't boot without the complete bootargs. Increasing these two config options solves this problem. Signed-off-by: Bryan Wu <pengw@nvidia.com> Signed-off-by: Peter Chubb <Peter.Chubb@data61.csiro.au> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-05-31ARM: tegra: convert CONFIG_TEGRA_GPIO to KconfigStephen Warren
Future chips will contain different GPIO HW. This change will enable future SoC support to select the appropriate GPIO driver for their HW, in a future-looking fashion, using Kconfig. TEGRA_GPIO is not simply selected by TEGRA_COMMON (even though all current Tegra chips used this GPIO HW) to simplify the later addition of support for Tegra SoCs that use different GPIO HW. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-11-21ns16550: zap CONFIG_NS16550_SERIALThomas Chou
Zap CONFIG_NS16550_SERIAL, as the unification of ns16550 drivers is completed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-21ns16550: unify serial_tegraThomas Chou
Unify serial_tegra, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-12ARM: tegra: simplify GPU setupAlexandre Courbot
Enable the GPU node in the system-wide ft_system_setup() hook instead of the board-specific ft_board_hook(). This allows us to enable GPU per SoC generation instead of per-board as we did initially. Reported-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-09-11ARM: tegra: enable filesystem writingStephen Warren
Writing to files is a useful feature in general, so enable it everywhere. The primary purpose is to make DFU useful on filesystems in addition to raw devices. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-09-11ARM: tegra: fix malloc region sizingStephen Warren
Commit 52a7c98a1772 "tegra-common: increase malloc pool len by dfu mmc file buffer size" updated the definition of CONFIG_SYS_MALLOC_LEN for Tegra to take account of the DFU buffer size. However, this change had no effect, since typical Tegra board config headers don't set the DFU- related defines until after tegra-common.h is included. Fix this by moving the affected conditional code to tegra-common-post.h, which is included last. Also move the definition of SYS_NONCACHED_MEMORY since it's a related and adjacent definition. Fix the condition to test for the DFU feature, rather than specifically MMC DFU support, so it applies in all cases. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-08-13ARM: tegra: represent RAM in 1 or 2 banksStephen Warren
Represent all available RAM in either one or two banks. The first bank describes any RAM below 4GB. The second bank describes any RAM above 4GB. This split is driven by the following requirements: - The NVIDIA L4T kernel requires separate entries in the DT /memory/reg property for memory below and above the 4GB boundary. The layout of that DT property is directly driven by the entries in the U-Boot bank array. - On systems with RAM beyond a physical address of 4GB, the potential existence of a carve-out at the end of RAM below 4GB can only be represented using multiple banks, since usable RAM is not contiguous. While making this change, add a lot more comments re: how and why RAM is represented in banks, and implement a few more "semantic" functions that define (and perhaps later detect at run-time) the size of any carve-out. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
