Migrating our BSPs towards mainline U-Boot I noticed it suddenly booting
slower. With mainline Linux I noticed about a 1 to 2 second increase
while booting downstream L4T takes 10 to 15 seconds longer!
This reverts commit 858530a8c0a7ce7e573e513934804a00d6676813.
drivers/serial/Makefile
(cherry picked from commit 752aae30a791326581efafbb761c0cebaba8d3ea)
drivers/serial/serial_tegra.c
include/configs/tegra-common.h
(cherry picked from commit 4b97c4173ef96cfa4eb3ba4ea9121320efa90091)
CONFIG_SYS_STDIO_DEREGISTER
This option should never be enabled in SPL, so use
CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option.
[trini: Re-sync]
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
The Linux-for-Tegra kernel uses a very long command line.
The default value of CONFIG_SYS_CBSIZE is too small to printf out the
long command line and causes a message like:
bootarg overflow 602+0+0+1 > 512
on the console, and the board refuses to boot.
The default value of CONFIG_SYS_MAXARGS is too small to add a long
long command line, and the kernel won't boot without the complete
bootargs.
Increasing these two config options solves this problem.
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Signed-off-by: Peter Chubb <Peter.Chubb@data61.csiro.au>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Move this option to Kconfig and tidy up existing uses.
Future chips will contain different GPIO HW. This change will enable
future SoC support to select the appropriate GPIO driver for their HW,
in a future-looking fashion, using Kconfig.
TEGRA_GPIO is not simply selected by TEGRA_COMMON (even though all
current Tegra chips used this GPIO HW) to simplify the later addition
of support for Tegra SoCs that use different GPIO HW.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Zap CONFIG_NS16550_SERIAL, as the unification of ns16550 drivers
is completed.
Unify serial_tegra, and use the generic binding.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Enable the GPU node in the system-wide ft_system_setup() hook instead of
the board-specific ft_board_hook(). This allows us to enable GPU per SoC
generation instead of per-board as we did initially.
Reported-by: Stephen Warren <swarren@nvidia.com>
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Writing to files is a useful feature in general, so enable it everywhere.
The primary purpose is to make DFU useful on filesystems in addition to
raw devices.
Commit 52a7c98a1772 "tegra-common: increase malloc pool len by dfu mmc
file buffer size" updated the definition of CONFIG_SYS_MALLOC_LEN for
Tegra to take account of the DFU buffer size. However, this change had
no effect, since typical Tegra board config headers don't set the DFU-
related defines until after tegra-common.h is included. Fix this by
moving the affected conditional code to tegra-common-post.h, which is
included last. Also move the definition of SYS_NONCACHED_MEMORY since
it's a related and adjacent definition.
Fix the condition to test for the DFU feature, rather than specifically
MMC DFU support, so it applies in all cases.
Represent all available RAM in either one or two banks. The first bank
describes any RAM below 4GB. The second bank describes any RAM above 4GB.
This split is driven by the following requirements:
- The NVIDIA L4T kernel requires separate entries in the DT /memory/reg
property for memory below and above the 4GB boundary. The layout of that
DT property is directly driven by the entries in the U-Boot bank array.
- On systems with RAM beyond a physical address of 4GB, the potential
existence of a carve-out at the end of RAM below 4GB can only be
represented using multiple banks, since usable RAM is not contiguous.
While making this change, add a lot more comments re: how and why RAM is
represented in banks, and implement a few more "semantic" functions that
define (and perhaps later detect at run-time) the size of any carve-out.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
ARMv8 requires an architected timer to be present, so it can be used
instead of the Tegra US timer. This allows for better code reuse.
Signed-off-by: Thierry Reding <treding@nvidia.com>
For 64-bit ARM SoCs we rely on non-U-Boot code to bring up the CPU in
AArch64 mode so that we don't need the SPL. Non-cached memory is not
implemented (yet) for 64-bit ARM.
them from include/configs.
When setting up large environment variables we can exceed 16 arguemnts.
Increase this to avoid problems.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
At the very least when USB keyboard support is enabled, we need to enable
CONFIG_SYS_STDIO_DEREGISTER, so the "usb reset" is able to re-scan USB
ports and find new devices. Enable it everywhere per request from Simon
Glass.
README
The dfu mmc file buffer, which was static, now is allocated
by memalign(), so the malloc pool len should be also increased.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Tom Warren <twarren.nvidia@gmail.com>
Use the full driver model GPIO and serial drivers in SPL now that these are
supported. Since device tree is not available they will use platform data.
Remove the special SPL GPIO function as it is no longer needed.
This is all in one commit to maintain bisectability.
All boards need CONFIG_BOARD_EARLY_INIT_F, and many actively need
CONFIG_BOARD_LATE_INIT. Move both of these into tegra-common.h so that
board config headers don't need to repeatedly define them.
Later commits will add new code in board_late_init() which applies to
all boards, so CONFIG_BOARD_LATE_INIT should be enabled for all Tegra
boards.
Move this option to Kconfig and update all boards.
Remove driver model CONFIGs from the board config headers and use Kconfig
instead.
Some boards, most notably those with a PCIe ethernet NIC, require this
to avoid cache coherency problems. Since the option adds very little
code and overhead enable it across all Tegra generations. Other drivers
may also start supporting this functionality at some point, so enabling
it now will automatically reap the benefits later on.
This converts all Tegra boards over to use driver model for I2C. The driver
is adjusted to use driver model and the following obsolete CONFIGs are
removed:
- CONFIG_SYS_I2C_INIT_BOARD
- CONFIG_I2C_MULTI_BUS
- CONFIG_SYS_MAX_I2C_BUS
- CONFIG_SYS_I2C_SPEED
- CONFIG_SYS_I2C
This has been tested on:
- trimslice (no I2C)
- beaver
- Jetson-TK1
It has not been tested on Tegra 114 as I don't have that board.
Acked-by: Heiko Schocher <hs@denx.de>
The faster functions are not actually available in SPL and the code size
likely isn't worth it. Use the normal memcpy() in SPL.
The private libgcc is supported only on ARM, MIPS, PowerPC, SH, x86.
Those architectures should "select" HAVE_PRIVATE_LIBGCC and
CONFIG_USE_PRIVATE_LIBGCC should depend on it.
Currently, this option is enabled on Tegra boards and x86 architecture.
Move the definition from header files to Kconfig.
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Tom Warren <twarren@nvidia.com>
This converts the Tegra SPI drivers to use driver model. This is tested
on:
- Tegra20 - trimslice
- Tegra30 - beaver
- Tegra124 - dalmore
(not tested on Tegra124)
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Use architecture specific memcpy to speed up things.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Use driver model for serial ports.
Since Tegra now uses driver model for serial, adjust the definition of
V_NS16550_CLK so that it is clear that this is only used for SPL.
This is an implementation of GPIOs for Tegra that uses driver model. It has
been tested on trimslice and also using the new iotrace feature.
The implementation uses a top-level GPIO device (which has no actual GPIOS).
Under this all the banks are created as separate GPIO devices.
The GPIOs are named as per the Tegra datasheet/header files: A0..A7, B0..B7,
..., Z0..Z7, AA0..AA7, etc.
Since driver model is not yet available before relocation, or in SPL, a
special function is provided for seaboard's SPL code.
Allocate 1KB so that driver model can operate before relocation.
Becuase the board select menu in arch/arm/Kconfig is too big,
move the Tegra board select menu to tegra/Kconfig.
Insert the Tegra SoC select menu between the arch select and the
board select.
Architecture select
|-- Tegra Platform (Tegra)
|- Tegra SoC select (Tegra20 / 30 / 114 / 124)
|- Board select
Consolidate also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows:
config TEGRA
bool
select SPL
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig.
Remove the redundant definition in config headers.
We are about to switch to Kconfig in the next commit.
But there are something to get done beforehand.
In Kconfig, include/generated/autoconf.h defines boolean
CONFIG macros as 1.
CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1.
Otherwise, when switching to Kconfig, the build log
would be sprinkled with warning messages like this:
warning: "CONFIG_SPL" redefined [enabled by default]
Enable driver model for Tegra boards.
If CONFIG_API is ever to be enabled on Tegra, this define must be set,
since api/api_storage.c uses it.
A couple of annoyting things about CONFIG_SYS_MMC_MAX_DEVICE
1) It isn't documented in README. The same is true for a lot of similar
defines used by api_storage.c.
2) It doesn't represent MAX_DEVICE but rather NUM_DEVICES, since the
valid values are 0..n-1 not 0..n.
However, I this patch does not address those shortcomings.
